Belt CP E-Sky Belt CP
Old 03-14-2009, 08:20 PM   #1 (permalink)
Default Main Shaft
There is a collar just above the frame that the main shaft slides through. Does anybody know what the collar is for and should it be just above frame? Esky belt cp v2. Thanks guys!
jeepharley is offline        Reply With Quote Quick reply to this message
Old 03-14-2009, 09:02 PM   #2 (permalink)
hi there yeah its really just security, it also helps eliminate any play in the shaft and when inverted stops the shaft pushing through the bottom of the frame.
fits where you stated
lex
lex7919 is offline        Reply With Quote Quick reply to this message
Old 03-14-2009, 09:21 PM   #3 (permalink)
You need it! It keeps the upper bearing in place. the upper bearing can slide up in flight. It will also keep the shaft from moving up and down.
MSR-X, Nano CPX, Belt CP Metal Edition w/g10 DTS align compatible frame, Trex 450 pro v2 w/metal upgrades, TREX 550e v2 w/ kde upgrades.
CUSTOM CNC MACHINING... Inquire within.
onehot69stepside is offline        Reply With Quote Quick reply to this message
Old 03-14-2009, 09:36 PM   #4 (permalink)
+1 on the others. Thae collar keeps the shaft from dropping down which would cause the main gear to interact with the tail gear. Not a good thing. If the tail gear was not there the main shaft would drop all the way down till the gears hit the bottom of the frame or the swash was all the way up in the head.
Matt
Junk Yard 450,
Blade MSR
GAUI 200 (under reconstruction)
Trex 450 (sponsered by Pittjitsu)
creteus is offline        Reply With Quote Quick reply to this message
