Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 60/70/90
Thunder Tiger 60/70/90 Raptor 60/70/90 Helicopters
Old 11-02-2008, 03:52 PM   #1 (permalink)
Default 90 clutch replacement
Well,I feel very stupid ,but i cooked the clutch today on my fairly new R90 !! I forgot to cut the receiver switch on !!!!!! What a dummy !!!! Oh well,better than a head on connection with the ground I guess. I shut it down pretty quickly but not before blue clutch material was everywher. Is it neccessary to flush the engine or does it usually affect the engine ? Also,what clutch would you reccomend ? I am thinking of replacing the clutch,clutch bell to make sure I didn't warp anything. How touchy is it to get these lined up again ? Thanks for the help. Wayne
wayneparrish is offline        Reply With Quote Quick reply to this message
Old 11-02-2008, 06:34 PM   #2 (permalink)
Don't feel too bad Wayne. I guarantee most of us have done the same thing, If it were me, I would definately flush the engine. You would be amazed at where all those little particles can go. As far as the clutch and bell, I would just buy stock replacement parts. They are cheaper, and work just fine. As far as the alignment of the two, I do not use a high point balancer like some guys do, and have never had a problem on my two 50's and two 90's getting good run out. Just tighten everything evenly, and then adjust the engine position in relationship to the clutch bell like the manual says. Good luck with your rebuild.
Mike: Rap-90 3D x 2, Rap-50 x 2, Fury 55, Rex-450, Hirobo Squark.
"Depression is nothing more than anger, without enthusiasm"
Badger50 is offline        Reply With Quote Quick reply to this message
Old 11-02-2008, 07:08 PM   #3 (permalink)
Thanks Mike,I appreciate the feedback and will open the engine and flush
Old 11-03-2008, 09:14 PM   #4 (permalink)
Mike,I got the Raptor 90 apart tonight in prep for the new parts tomorrow. That is not an easy,quick job to remove the clutch bell from a 90 ! Oh well,I got it and flushed the engine,etc. so it should be ready to go after the new parts arrive,It had torn out all of the liner material,so I will probably put the new bell in to make sure it's true. Thanks again for the reply yesterday. Wayne
Old 11-05-2008, 09:39 PM   #5 (permalink)
QUESTION ,why does the Raptor 50 clutch come complete with the liner already installed and yet the top of the line Rap 90 does not come installed ? I asked Ace today and they couldn't give me a decent answer,except that some people like to set up the clutches differently and it may cost more !!! Give me a break !
Old 11-06-2008, 08:15 AM   #6 (permalink)
"I asked Ace today and they couldn't give me a decent answer,except that some people like to set up the clutches differently and it may cost more !!! "
I would agree with Ace on this one. Personally, I set my clutch gap clearance to be +.003 to +.005 per side. Ace can't hold those tolerance with the glued-in clutch material and mass manufacturing. It is more important that the clutch fit and be a little on the loose side than if it were too tight and the customer could not even start the motor.
When they come glued in, like the case of the R50, I'll turn down half the existing liner, glue in a second and then size that to my specifications.
I've never broken a clutch shoe using my process. Personal preference, I guess.
-Mike
Team QuickUK Pilot
Team Heliproz
MikeSherman is offline        Reply With Quote Quick reply to this message
Old 11-06-2008, 10:36 AM   #7 (permalink)
Sounds like a very good idea,BUT,only for the ones of us that happen to have a lathe to make that modification. I have found that people tend to get bored,disgruntled,or whatever you want to call it,when they have to fight too much to get something going. I am only thinking that it would be a convenience factor for the customer.As far as holding tolerences,I really don't see a problem in holding a + or - tolerence on a simple clutch. Just my thoughts.
Old 11-06-2008, 10:42 AM   #8 (permalink)
Sure, if they could hold a tight tolerance - it would benefit the customer, no doubt!
Unfortunately, there is more to it than just holding the tolerance of the clutch. The ID of the clutch bell, the glue/epoxy thickness and the clutch material thickness all add to the overall tolerance gap. Now add runout and concentricity tolerance and you can see how quickly that gap increases.
Typically speaking, the tighter the tolerance, the higher the cost of manufacturing.
-Mike
Team QuickUK Pilot
Team Heliproz
Old 11-06-2008, 06:08 PM   #9 (permalink)
I do understand that.
Old 11-09-2008, 06:25 AM   #10 (permalink)
If re-lining a clutch bell, my suggestion would be to just use one thick piece of paper behind the blue liner. (A strip of paper from the R90 manual works beautifully.) Epoxy the paper to the bell and then the liner to the paper. Then wrap your clutch with two layers of electrical tape and put it in the bell. (Might want to put the start shaft through the bell and the clutch to make sure things are lined up straight.) Let dry and then pull the clutch and remove the tape (Be sure to clean any leftover residue that might be on the clutch from the electrical tape).
The clutch might be a smidge tight on that first start up so be sure to have a firm grip on the rotorhead. Within one flight though things should be seated perfectly and you won't have to worry about the clutch breaking due to the clutch to liner gap being too big.
Kinger is offline        Reply With Quote Quick reply to this message
Old 11-09-2008, 06:22 PM   #11 (permalink)
Thanks guys for the info and advice. Its flying great
Old 11-12-2008, 01:35 PM   #12 (permalink)
Was the origional really loose?
You can get different thicknesses of clutch liner. 1mm and 1.5mm. You might have the smaller one that is not designed for you clutch. It won't hurt anything but causes the problems you described.. Just a thought.
Charles
Youngblood is offline        Reply With Quote Quick reply to this message
