Old 01-09-2014, 04:45 AM   #41 (permalink)
What caused it finally?
-רחל is offline        Reply With Quote Quick reply to this message
Old 01-09-2014, 08:26 AM   #42 (permalink)
Not sure but no matter what I did, model type or settings, the left
Roll was somehow effected by dual rates, throttle and flight
Mode switch. At some combinations of these switches, there was some left roll, some none and others uncontrollable roll to the right.
This is on rf7 btw.
Bubba
Goblin 700
Jeti DS-16
Bubbasanjohn is offline        Reply With Quote Quick reply to this message
Old 01-28-2014, 03:39 PM   #43 (permalink)
Finally got time to solder and set this up. The soldering was a snap thanks to the great pictures and HF trail blazers in this forum!
Programming Jeti and RF7 was somewhat of a challenge. For some reason my channel 1 was always acting funky in RF, even though it looked perfect from the Jeti. I worked around this by not using channel 1 and moving aileron (roll) to channel 7. All good now.
I played with the PPM frame rate between 10 and 30 ms with no improvement on this flakey channel 1 problem. Settled on 20ms as recommended.
Bubbasanjohn,
Was that the same problem and fix you came up with?
Jay - Diligentia, Vis, Celeritas
Lynx / OXY Team Pilot, Zeal Team Pilot
jmackey is offline        Reply With Quote Quick reply to this message
Old 01-28-2014, 03:48 PM   #44 (permalink)
yes I did fix it. Its kind of convoluted. let me go get TX and Ill post back the solution.
Bubba
Goblin 700
Jeti DS-16
Old 01-28-2014, 04:07 PM   #45 (permalink)
Ok, here is what works for me.
RX
set up I am using a r3-ex. I have output mode to ppm negative, output period of 20ms, channels 8. (selected ppm - as we are setting up a futaba radio)
TX.
Set up a heli model named realflight. Mechanical swash, standard flight modes and typical throttle curves.
servo assignments:
1=roll
2=elevator
3= throttle
4=yaw
5=2 pos switch
6= flap (7 knob on my tx)
7= 2nd 2 position switch
8= 3 pos switch.
I did have to add +64% right roll trim to compensate for realflight fubarness.
Realflight
Set up in RF, Futaba TX, edit to the following
RF ch1= 1aileron
ch2= 2 elev
3= throttle
4= rudder
5= dual rates
6=flaps
7= REVERSED 7 smoke
8=mode.
I have both check boxes below enabled to allow software radio mixes and enable software radio dual rates and expo.
Save as another TX name, I used jeti.
That should do it.
Bubba
Goblin 700
Jeti DS-16
Old 01-29-2014, 04:39 PM   #46 (permalink)
So this my be a dumb question but I need to ask....
My RF 6.5 came with a remote, not small USB box like my phonix did. Where did you guys get the small black dongle for RF ??
Spinny02 is offline        Reply With Quote Quick reply to this message
Old 01-29-2014, 07:42 PM   #47 (permalink)
Part of RF7 might be available separate but I doubt it??
Dansy is offline        Reply With Quote Quick reply to this message
Old 01-29-2014, 08:18 PM   #48 (permalink)
Here is where I got mine.
http://www3.towerhobbies.com/cgi-bin...&I=LXDUNJ&P=ML
Old 01-29-2014, 09:39 PM   #49 (permalink)
Yeah dongles are not interchangeable. Rf 7 is better than 6.5 IMHO. Also easier to set up with jeti.
Bubba
Goblin 700
Jeti DS-16
Old 02-01-2014, 09:03 PM   #50 (permalink)
RF7 Upgrade for $49 comes with the new dongle?
Old 02-01-2014, 09:10 PM   #51 (permalink)
Not sure. Most likely not.
Bubba
Goblin 700
Jeti DS-16
Old 02-02-2014, 08:35 AM   #52 (permalink)
On the Tower site it says Interlink not included !
Old 02-02-2014, 09:17 AM   #53 (permalink)
Default Re: USB wireless to RealFlight
Upgrade does not have a new dongle. The full version no tx does.
I just got my upgrade last week. No dongle.
sent from my Verizon Samsung Galaxy Note 2
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 12-16-2015, 12:37 AM   #54 (permalink)
Wiring up my InterLink tonight with these screenshots. I'll let you know how it goes.
Protos Max 700, Logo 550SX, Goblin 570
MSH USA Flight Team, MSH Brain, Jeti Model, Cyclone
soniczen is offline        Reply With Quote Quick reply to this message
Old 12-16-2015, 09:47 AM   #55 (permalink)
My real flight 7.5 has a calibration mode that lets you move sticks and find centers. That may fix bubba's roll problem. It's under the same menu that lets you select another receiver to work with real flight. At least you can watch inputs and see what they do. Dan
No-Team; Non-Rep, no-skill. Free advice worth every penny.
dogbreath is offline        Reply With Quote Quick reply to this message
