Old 03-06-2012, 05:05 PM   #1 (permalink)
Default DFC head upgrade to 500ESP
Hi All
Just though I'd make some notes on what I need to do and the parts required to build a complete 500DFC head and fit it to an older (pre EFL/Pro) T500.
The first thing you need to realise is the DFC head upgrade kit is not a complete new head, it is a kit with only the bare minimum parts required to upgrade a 500EFL head. It could also be used on a 500Pro FB heli as an FBL head upgrade.
As such there are a lot of parts missing as the kit assumes you are pulling the old head apart to do the upgrade.
I wanted to build a complete head, and also see what other things may be required to fit it to the older style frames.
So first, The parts you will need:
The Kit (H50181)comes with a main shaft (much shorter), a head block (pre fitted with sleeve and dampers, the grip arms, and all the links down to the swash.
So you will need the following to complete the head:
1 set Pro Blade Holders H50150
1 Feather Shaft H50023 (you get two spindles AND one set of grip bolts/washers)
1 Thrust Bearing Set H50004
1 Damper Black H50022
The Damper set may seem weird, but neither the upgrade kit or the Grips include in them the brass grip spacer that goes between the dampers and the grips. The only way I found you can guy it is packaged with the black dampers.
The head itself is easy enough to build, just as you would normally. I won't go into those details here.
NOTE the control links and grip arms come pre-assembled BUT do not have any loctite on then, so make sure you strip down and loctite everything. Also don't forget the grease the thrust bearings.
That gets you a complete head. except for another minor issue. There is a new Jesus Bolt supplied with the DFC kit, but this is the lower Jesus Bolt. The upper Jesus lot on this head is slightly shorter. Its the same Jesus bolt used in the various FBL heads. Luckily I had a spare, I am not sure how you would get one as a single part.
Now for the ESP upgrade you will also need a set of Pro Main Shaft Shims (H50157)
The reason for this is you are going to be using the new main shaft, and on the Pro/EFL models the main shaft has a fixed ring instead of the adjustable collar on the older main shafts.
So the next step is to pull the head off the ESP, then pop the servo links off the swash and remove it from the main shaft. Then undo the lower Jesus Bolt and pull the main shaft out.
Take the thinner of the two shims (they come in two sizes in the pack) put it over the lower section of the new main shaft and fit it to the heli. Fit the Jesus bolt and then see if you have any up/down play in the main shaft, if you do then try the other shim. I actually had to use both. to get 0 free play.
Once that is done refit the swash then the news head can go on the heli.
Now reset 0 pitch, check your FBL controller settings and enjoy.
Before (the 3G FBL head with the short main shaft)
And after
Dave
Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro
MutliWiiCopter Scarab Stealth Armour,Scarab Stealth Reconn V3, Scarab TriiKopta, Scarab Octa, Scarab Vampire
Deet is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 05:15 PM   #2 (permalink)
Thanks for the tips Dave! I am not planning to install that head however the only thing I am not very comfortable is the main shaft fixed ring and shims. In my opinion the older method was not bad at all.
Hope you can tell us how it performs vs the older 3G head.
Mateyhv is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 05:24 PM   #3 (permalink)
I would rather stick to the old collar too, but that's just how it is
BTW I also did some testing of how much movement there is in the head, I couldn't make it flex...
Dave
Old 03-06-2012, 06:34 PM   #4 (permalink)
Looks great but seems pricey after all the additional pieces.
Actually I added it all up to about $120. Would that be right Deet?
Rapid Helis Australia
Lighty is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 06:40 PM   #5 (permalink)
its cheaper than the old Align FBL head
Dave
Old 03-06-2012, 06:54 PM   #6 (permalink)
I also feel its too expensive. I think its a matter of time to see other brands lowered heads out there if this one is a success.
Old 03-06-2012, 07:38 PM   #7 (permalink)
I am glad to read your report Dave, I look forward to your review of the flight performance!
Do you have any way to video it?
snjbird is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 08:28 PM   #8 (permalink)
will see what I can do re-video, but as there isn't a prior one not sure the point, it will be a heli flying
Dave
Old 03-06-2012, 09:56 PM   #9 (permalink)
Deet, what type of frame is that in the photo.doesnt look like a 500esp
Kraken 580
Jose5x5 is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 10:31 PM   #10 (permalink)
read my signature
Dave
Old 03-06-2012, 11:02 PM   #11 (permalink)
Yep............ I asked Deet about that frame earlier. It's a one-off from a top secret supplier that no longer makes them in the Black Forest in Bolgemia!
But it is a cool and aerodynamic looking frame.
Trex 500-3226-1600, 14T, Koby 90LV, HS-5245MG, DS655, AR7200BX, DFC
Trex 450 Sport-2221-8, 15T, CC Edge 50 Lite, HS-5065MG, HSG-5084MG, AR7200BX, DFC
DX8
wanderer56 is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 11:24 PM   #12 (permalink)
actually there are 4 of them, and he now lives in the UK
http://www.archeli.com.au/forums/sho...d.php?t=142994
Dave
Old 03-07-2012, 06:32 AM   #13 (permalink)
So you can't get the frames any more? too bad it looks super cool!
Old 03-07-2012, 08:34 AM   #14 (permalink)
hmmm $120 , ok then that comes to the point I made in another thread as you get a complete Traxc head for $120 and use your original mainshaft
| Kraken 700 : Neo | Atom 6HV : Evo | Raw 580 : Neo | vbct |
ragge1 is offline        Reply With Quote Quick reply to this message
Old 03-07-2012, 03:58 PM   #15 (permalink)
the $120 includes the new mainshaft and the head ends up being about 30mm lower than the Traxc.
Also if you buy all those align parts you will have spare dampers and a spare featuring shaft.
If you weren't interested in building it as an entire head, and are prepared to "upgrade" an existing ESP head, you only need the kit, the grips and the spacers, which is under $100.
I did this as a exercise to see what exactly would be required if it was a complete build
I already had bearings, spacers and spindles in the spares box anyway, so it wasn't that big a deal for me to do it this way.
And now I have a complete spare FBL head.
Dave
Old 03-07-2012, 04:15 PM   #16 (permalink)
I'll definitely do the upgrade if I crash. Thanks for the info Deet.
Old 03-08-2012, 04:13 PM   #17 (permalink)
Love the lowered sleek look Deet. I am very much looking forward to seeing it fly.
JR-XG8
TREX-550E PRO DFC DS615's/DS655/G31/730MX/Talon 90
Radiomaster TX16S
OMPHobby M2 V2
AlphaCharlie is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 06:01 PM   #18 (permalink)
Just a note
I have just found out from the Aussie Distributor that the reason for the delayed shipping was that Align was sending the correct Jesus bolts to be added to the kits.
A careful inspection of the post pack found the correct Jesus bolt in the bottom of the pack, lucky I hadn't emptied the garbage bin yet
AC. helifest if not sooner..
Dave
Old 03-10-2012, 05:17 PM   #19 (permalink)
Finally got to give it a good fly yeaterda
All I need to say is this:
Complete 500/ESP FBL head for sale, includes FL main shaft, and a spare.
Dave
Old 03-12-2012, 06:31 PM   #20 (permalink)
+1, i upgraded from flybarred head, cost me about $95, cheaper and, imo, a significant improvement on the standard align fbl, and...
complete fb head for sale, along with a complete 450 pro fbl head when they come out with one for my little trex (already lowered the head of my mcpx, lol)
Blade MSR, Blade MCPX BL(hp05s, xp7a, sr120 tail, all MH head), EXI 450CF, TREX 450 pro(CC Ice 50, Scorpion -8, BeastX, KBDD TR, Trueblood greens), TREX 500 (BeastX, Align DFC head, KBDD TR)
Glass Monkey is offline        Reply With Quote Quick reply to this message
