Old 12-10-2012, 07:57 PM   #81 (permalink)
Originally Posted by DoctorJ View Post
I sure hope your head setup doesn't have similar setup issues, it will go bad so fast.
Head is all good.
Sladex is offline        Reply With Quote Quick reply to this message
Old 12-10-2012, 07:58 PM   #82 (permalink)
Bonkievan is offline        Reply With Quote Quick reply to this message
Old 12-10-2012, 07:59 PM   #83 (permalink)
Originally Posted by Bonkievan View Post
Giggity. Anyway what can I do?
Old 12-10-2012, 08:01 PM   #84 (permalink)
Originally Posted by Sladex View Post
Should I turn it off from hh mode
No, you want HH mode.
And did you did the gyro checks again with the swash and tail?
Old 12-10-2012, 08:01 PM   #85 (permalink)
Spinning it to the right and left I assume you mean? Yes I did and it worked
Old 12-10-2012, 08:03 PM   #86 (permalink)
Fancy words.... Lol. So what can I do. It passed your test . And I have a lot of right trim in there to center the rudder, is that ok. Each side gets almost exactly the same amount of throw
No, A little sub trim is ok after mechanical setup, i.e., 90 degree on servo and 90 on tail slider.
I would bet that finless has setup videos, you need to watch them. It's a lot of work to try and explain tail/gyro/servo setup in a thread at least for me. I don't even think about this stuff. I just follow a process because I understand fundamentally what's needed. Your missing very fundamental knowledge.
Its all about having fun
ShaneJourdan is offline        Reply With Quote Quick reply to this message
Old 12-10-2012, 08:05 PM   #87 (permalink)
Yes,
tilt heli forward=swash tilts back.
Tilt right=swash tilts left.
Spiin the boom away from you, CounterCW and the tail slider should move the opposite way. eg toward you in this instance CW.
Old 12-10-2012, 08:06 PM   #88 (permalink)
I bet you never even set end points to avoid end blocking.
Old 12-10-2012, 08:07 PM   #89 (permalink)
You have to go into your dx8 function list, scroll down to Gyro, then under Normal, set the number to a minus, for example, -45 for rate mode.
Stunt/ idle up 1 and/or 2, set the number to a plus, For example, +50 for Heading Hold mode.
You use the Flight Mode switch to switch gyro setting in Normal, stunt/idle up 1, stunt/idle up 2.....
Velos 880/Sab Urukay, KSE, Carbon Speed/Mikado Uvular/RCA Blackshark/Chaos 500 Evo, 550, 600, 700/Trex 500, 600, 600 Pro, 700/Roban 470 Cobra, 700 Apache, Cobra, 429, Jayhawk, 800 Airwolf/TFM 800 Blue Thunder, Seahawk, Jayhawk/ DX8 DX18QQ
treotraveler is offline        Reply With Quote Quick reply to this message
Old 12-10-2012, 08:08 PM   #90 (permalink)
I did set them up.
Old 12-10-2012, 08:18 PM   #91 (permalink)
BAH!! These yahoo's don't know what they talkin' bout! Just FLY IT!!!
Sorry.. can't help it!
TRex 700DFC CC 120HV/VBar
TRex 500 ESP/FBL CC Ice100, MiniVBar
TRex 600LE/ OS50/ Full Size VBar/ Arizona Regulator , FrankenBlade 400/Sonic head and tail/CF Frame, Blade MSR, Bunch o' planks.. DX7/Futaba 9C
Geardaddy is offline        Reply With Quote Quick reply to this message
Old 12-10-2012, 08:19 PM   #92 (permalink)
I when to the menu like you did and it said Gyro . Inh. I think this is the problem. Now i set the ch to aux 2 and sw to gov. All my rates are 0 be default. How do i figure that out?
Old 12-10-2012, 08:37 PM   #93 (permalink)
[ECHO]
THIS HELI NEEDS TO BE GONE THROUGH STEPWISE BY SOMEONE WITH PRIOR EXPERIENCE WITH 700E.
[/ECHO]
I think it's getting louder. Can anyone else hear that??
AMA 373608
K2Freak is offline        Reply With Quote Quick reply to this message
Old 12-10-2012, 08:40 PM   #94 (permalink)
You want the SW in the gyro menu to be SW:F Mode. You can have it set to Gov if you like, i just like having it on the assigned FM switch.
However, considering you're still coming to terms with this, I would recommend starting this way before changing switch assignments. You dont need to be thinking about this now for obvious reasons.
On my Dx8 i have the gyro on Ch:gear. also. It maybe different for the Bx as use 3gx?
Old 12-10-2012, 08:41 PM   #95 (permalink)
Seriously OP, one of the things that hf does is bring people together. Suggest you go to the member locator and see who is near you.
https://www.helifreak.com/faq.php?fa...faq_locatoruse
AMA 373608
Old 12-10-2012, 08:42 PM   #96 (permalink)
Originally Posted by K2Freak View Post
[ECHO]
[/ECHO]
I cant.............................................. .................................. I need you guys to help me. I though thats what this forum is about, Learning?
Old 12-10-2012, 08:45 PM   #97 (permalink)
The ar7200bx tail gyro is defaulted to the gear channel. You need to default the gyro to gear channel. Then select a switch. Most use the Flight Mode switch to change gyro setting.
Your gyro setting numbers will be at default zero setting untill you change them.
Is there anyway you can take your 700 and tx to one of the major rc shops in the Los Angeles basin, to go over this stuff with you?
Old 12-10-2012, 08:46 PM   #98 (permalink)
Yes. But so far you have been quite lucky. If it had been your head instead of tail you would now have a box of parts...
You are right by mission viejo, etc. Lots of folks around there that will hopefully be receptive to helping you in person.
No way can this forum do a comprehensive exam of your bird remotely.
AMA 373608
Old 12-10-2012, 08:52 PM   #99 (permalink)
I cant. My dad is going to have a 300,000 back surgery soon and i really dont want to bother him. He cant even walk right now. I dont drive.
Old 12-10-2012, 08:52 PM   #100 (permalink)
Have you changed this yet? Btw set your Gyro gain for +60 in Normal for a start.
I dont think you need to be worrying about Idle up modes just yet.
