Old 07-21-2013, 05:07 PM   #41 (permalink)
Originally Posted by heathy View Post
Guys. Myself and a few others here have noticed the bolts that are used to clamp the tail are not long enough to fully engage the nylon in the nuts, resulting in the tail loosening off causing problems.
Either flip the nuts or fit longer bolts if yours are the same.
mine are long enough
Sponsored by
Scorpion System motors
RC Take Off
Haiyin
tommeke is offline        Reply With Quote Quick reply to this message
Old 07-21-2013, 10:31 PM   #42 (permalink)
Do you have the plain cf tail or painted orange? My theory is the paint thickness on orange tails is causing the bolts to be short. Mine are on my 600sx too.
M52 POWER! is offline        Reply With Quote Quick reply to this message
Old 07-22-2013, 02:25 AM   #43 (permalink)
I have a 550SX and I upgraded to the SX tail on my 600. On the 600 they're flush or proud.
On the 550SX, they're flush or a little shy of flush. Seem to be in the nylon. Nothing loose.
Crank that boy down. You didn't slide a piece of tape in there for more purchase, did you?
In any case, I'll keep an eye on those getting loose; thanks for the heads up.
Jim
PRÔTOS 500 Plastic, Logo 550SX/600SX, PRÔTOS Max2 up and flying!
Team MSH USA, Team Cyclone, Team Xnova
trickybit is offline        Reply With Quote Quick reply to this message
Old 07-22-2013, 12:50 PM   #44 (permalink)
I have the orange tail
Sponsored by
RC Take Off
Haiyin
Old 07-23-2013, 11:05 PM   #45 (permalink)
Default 550sx tail belt problems?
Originally Posted by beans07 View Post
I haven't had an issue yet in 20 flights on mine and I am running quite loose tail belt. I will be keeping an eye on mine.
Yah, I was good for about 50 flights then it started. And it happened again today! The belt in my opinion was tight. Spedix tensioner on the way. Ugh.
Sent from my iPhone using Tapatalk 2
Protos Max 700, Logo 550SX, Goblin 570
MSH USA Flight Team, MSH Brain, Jeti Model, Cyclone
soniczen is offline        Reply With Quote Quick reply to this message
Old 07-24-2013, 02:02 AM   #46 (permalink)
I hope Mikado get this fixed soon. I did wonder if mine was an isolated event but clearly it's not.
Mike
Goblin 770, Goblin Nitro, Goblin 420 Many come and gone but all V-bar'ed!
hydev is offline        Reply With Quote Quick reply to this message
Old 07-24-2013, 05:16 AM   #47 (permalink)
fixed it!
well, I bought a gaui x5 and put all the electronics from my logo in it, does that count?
Sponsored by
RC Take Off
Haiyin
Old 07-24-2013, 05:32 AM   #48 (permalink)
Where can I buy this? Any resellers in Europe?
[SIZE="1"][B]Gaui X2 (MKS DS92 / DS95i / Brain / YGE 30A / TM-1100)
Mikado Logo 550SX (Futaba BLS 255 HV / BLS 256 HV / VBar / YGE 100A / TM-1000)
JacobsT is offline        Reply With Quote Quick reply to this message
Old 07-24-2013, 03:53 PM   #49 (permalink)
Hello ,
Should i put the spedix upgrade on my 600sx ? It works fine stock so i dont know !
totonor is offline        Reply With Quote Quick reply to this message
Old 07-24-2013, 04:24 PM   #50 (permalink)
Works fine stock on my 550sx too (25 flights) - but I'm still putting on the Speedix as soon as it arrives, for peace of mind.
Team MikadoUSA
hemp is offline        Reply With Quote Quick reply to this message
Old 07-24-2013, 04:37 PM   #51 (permalink)
+1, mine's on the way.
I have a fat pulley on my Logo 600 and it looks much safer...
Old 07-25-2013, 07:26 AM   #52 (permalink)
Where do you guys order? Don't care if it's backorder but I want one!
Old 07-25-2013, 08:30 AM   #53 (permalink)
buddyrc. Got it last night; went on easily as you'd expect.
Old 07-25-2013, 08:49 AM   #54 (permalink)
In your own country:
http://www.ercmarket.com/spedix-tail...-spx92010.html
But no stock :-(
Regards Arnaud
Mikado Logo 550SX | Mikado Logo 600SE V2
catzjes is offline        Reply With Quote Quick reply to this message
Old 07-25-2013, 10:43 AM   #55 (permalink)
Just looked at mine and it looks like they are barely catching. I think you are right the paint is quite thick, and it could be just enough to cause the nut not to catch.
Logo 550SX, Modified Logo 400SE, Forza 450 3S
Lompma is offline        Reply With Quote Quick reply to this message
Old 07-25-2013, 03:40 PM   #56 (permalink)
Flip your nylock nuts if worried.
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 07-25-2013, 05:36 PM   #57 (permalink)
Originally Posted by rando View Post
Seems to me it wanted to pop off during heavy tail loading moves (rapid change in direction of the rudder or something like a tail down, blades in, counterclockwise wall). Anyhow, with the dual bearings or Spedix tensioner, the issue hasn't come back.
How many of you guys having this tail belt/pulley issue (with stock part) are running maxed out deflection on the tail blades?
I ask as I'm brainstorming here for a possible cause as a result of discussions in this thread on arcHELI about reducing tail blade throw to improve tail performance.
I may be barking up the wrong tree but it's worth thinking about as it seems a few guys are having the tail belt slip using the stock belt tensioner.
trippergreenfeet is offline        Reply With Quote Quick reply to this message
Old 07-25-2013, 05:58 PM   #58 (permalink)
Default Re: 550sx tail belt problems?
I'm having maxed out tail deflection...for the record.
Sent from my GT-N7105 using Tapatalk 2
Henseleit TDR
Protos Max 700, Logo 690SX , Logo 480 XXtreme , Goblin 570,
Forza 450
dylanwee is offline        Reply With Quote Quick reply to this message
Old 07-25-2013, 07:37 PM   #59 (permalink)
I have maxed out deflection and have not had the belt slip off (31 flights). Pretty sure I've also never hit max deflection during a flight as I've never had a tail jitter or blow-out, even under the most stress I know how to give it (max collective sideways loops.)
Team MikadoUSA
Old 07-25-2013, 09:11 PM   #60 (permalink)
I set my 600sx up for max deflection minus a point or two on each side per Mr Mel's vbar setup guides. I had the belt slip twice but never since installing the spedix tensioner. I have a 550sx on the way along with another tensioner.
700L SXTS Neo | Goblin 700 KSE Neo | Goblin 380 KSE miniVBar | Nano QX
rando is offline        Reply With Quote Quick reply to this message
