Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 02-17-2012, 01:30 AM   #441 (permalink)
Originally Posted by briareos7777 View Post
Yup the TGY DP 3A (from hobby king also) is different from the XP 3A ESC from hobby king. The TGY DP 3A Rcp In is connected to pin P0.6, but on the XP 3A esc Rcp In is connected to P0.7. I think there are some other pins that are different also like the pFet pins (A, C seems to be reversed from the XP 3A). On my TGY DP 3A there's a "206B" label on the pcboard. In the comments for the TGY DP 3A, a person in the comments is saying the 206B version is bad. The comment was:
"The old ones had 1S3A written on them and were excellent. The new ones 206B. The new ones are rubbish. E.g. they have a CPU, which has a maximum recommended voltage of 3.6V directly connected to the Lipo which can give out 4.2V when fully charged. No wonder, that they often just burn away...Don't buy them, as long as they still ship this bad 206B version!!!
I didnt know they had different version of the f330 chips. The TGY DP 3A one that has the 206B label on it has the following numbers on the f330 cpu: B1041 1128. The HK XP 3A has: B1479 1039.
This is the same topic for all the small 3A ESCs. The F330 chip is spec'ed at 3.6V max. And all of the ESCs will run them at battery voltage. Not sure if this is really an issue, though. Yes, it will limit the lifetime of the ESC. But the 3.6V spec is normally set for continuous operation at 85deg C for 10 years! You will have many flights before the ESC even sees one year of continuous operation. And normally not at 85deg C!
Another issue with the DP 3A might be poor fets. From the pictures they are smaller, and they probably have higher resistance. I'll try to measure it when I get the ESCs.
sskaug is offline        Reply With Quote Quick reply to this message
Old 02-17-2012, 01:57 AM   #442 (permalink)
Originally Posted by Dylwad View Post
I Swapped out an old HP03T for a "NEW" HP03T and have bad blowouts, like 180 degrees on a full collective climb out. Going to try my other "new" HP03T and see if its different, but will probably go back to the old one.
Are you running the "new" or old HP03T? (New one has 6 magnets, old has 12)
You can spool the tail up and hear that its a lower RPM at full throttle than the old HP03T....
Dylan
I'm pretty sure I have the 6 magnet version.
Lynx Heli Innovations | HD Helicopters
ZyBeR is offline        Reply With Quote Quick reply to this message
Old 02-17-2012, 09:36 AM   #443 (permalink)
Originally Posted by sskaug View Post
I use both the new and the old HP03T, and see no blowouts. But... I run with a very long tail boom of 185mm. I know the new HP03T has less thrust than the old, and therefore a longer boom may be beneficial for it. Your setup looks good Brandt, but maybe you would start with a little longer boom? You can always cut it...
Excellent, Steffan, that's what I'll do. Really appreciate the guidance.
I'm planning on building two tails...
1. HP03t, 185mm, Plantraco
2. 120sr, 150mm, Plantraco, inline mount
Ideally, the 120sr tail will sit in a box awaiting my son's BL build, but it might come in handy if I can't get the BL tail sorted.
SuperBee364 is offline        Reply With Quote Quick reply to this message
Old 02-17-2012, 01:06 PM   #444 (permalink)
Hi,
Yes - but this was not my question.
Look at my picture with the ESCs - I have both, XP-3A and TGY DP 3A (and I know of those two versions of the TGY).
I wanted to know, if there are different versions of the XP-3A.
Mine works fine.
Walter
donaldsneffe is offline        Reply With Quote Quick reply to this message
Old 02-17-2012, 06:29 PM   #445 (permalink)
Thanks briareos7777.
I finally found it WAS the toolchain setup, but I simply had a "\" too much at the end of an include path. The resulting error messages weren't really logical
What I miss in the Silabs IDE, is the Grep search, context sensitive popup menus and so on...
But the little MCU seems to own some features, which I've missed in the AVRs.
Today I replaced my first XP-7A MCU, which died because of overvoltage stress (my conclusion).
Not an easy job, but with some patience a workable exercise.
Now I need a test Firmware and a Port map for the XP-7a.
Does actually someone has worked out a map ?
4712 is offline        Reply With Quote Quick reply to this message
Old 02-17-2012, 06:43 PM   #446 (permalink)
Originally Posted by donaldsneffe View Post
Hi,
A good question, Walter. Mine does have exactely the same layout and is not from HK (but from a chinese ebay Shop in Ger). And it works with a program card (manufactured of whom? ...no name). Hard to tell who sells the so called originals and what a copy is...
The ESCs here should be classified not by names but by fotos..
(btw: would be a nice Job to hack the program card to get the protocol build into the DIY ESC)
Old 02-17-2012, 08:00 PM   #447 (permalink)
I usually would just grep in a command line box anyways.
That's pretty amazing that you can replace the xp-7a mcu. One of my xp-7a the rcp in pin got messed up, i tried just touching the soldering rod to it only and it didnt fix it. At least i think it's messed up.
I've burned over 20+ fets now. I need a esc simulator, so I dont burn all these fets. Just like a mcp x simulator helped me not crash my mcp x so much...
Here is the XP-7A port map that I did. I don't know if it's correct. Wait until somebody else verifies it first, or you can verify it yourself.
XP 7a esc
Mux nFet pFet
A 0.5 1.2 1.5
B 0.3 1.1 1.4
C 0.1 1.0 1.3
Comp Com: 0.2
AdcIp: 0.6?
Rcp In: 0.7
GND / 1k / 10k / VCC
Hopefully I've been mapping my escs correctly.
briareos7777 is offline        Reply With Quote Quick reply to this message
Old 02-17-2012, 08:16 PM   #448 (permalink)
I have a question regarding the esc stuff. If you put a break point while the motor is running, since it's leaving a pfet on wouldn't it burn out the fet? Or pretty much if you turn a pfet on and have a break point, which means it wont get turned off, it'll burn it?
Old 02-17-2012, 08:50 PM   #449 (permalink)
Sure, the breakpoint stops (freezes!!!) all activity. Therefor be sure to use a current limiter!
Thanks for the map, I will check...
Old 02-17-2012, 09:44 PM   #450 (permalink)
sskaug,
Here's the mapping for the xp 3a I got:
XP 3a esc
Mux nFet pFet
A 0.5 1.0 1.3
B 0.3 1.1 1.4
C 0.1 1.2 1.5
Comp Com: 0.2
AdcIp: 0.6?
Rcp In: 0.7
Old 02-17-2012, 09:59 PM   #451 (permalink)
Anybody know if i solder wires to the esc where the fets are (3 wires per fet), then the fet to the wires. If the fet burns, it should only burn the fet and not the pcboard?
It would make replacing the fet a lot easier also. Could develop a bit easier then.
Old 02-18-2012, 01:21 AM   #452 (permalink)
sskaug,
For the xp3a.inc,
You have:
P1_INIT EQU (1 SHL ApFET)+(1 SHL BpFET)+(1 SHL CpFET) ; Setting pFET outputs turn them off
How do you find out for the pfet and nfet if you set the bit to 1 it'll turn them on or off. I've noticed in some other code that on the tgy 6a esc (silab), you have to set the nfets to 1 to turn them off.
Is there a way to determine this with a multimeter or something?
Old 02-18-2012, 03:19 AM   #453 (permalink)
sskaug,
XP 3a esc
Mux nFet pFet
A 0.5 1.0 1.5
B 0.3 1.1 1.4
C 0.1 1.2 1.3
Comp Com: 0.2
AdcIp: 0.6?
Rcp In: 0.7
In your .inc for for the xp 3a, you have the pFets different from what I mapped. Maybe double check the pFets.
...strange. Maybe there are different versions. Mine runs the motor just fine.
-S
Old 02-18-2012, 03:27 AM   #454 (permalink)
sskaug,
For the xp3a.inc,
You have:
pFETs always connect the motor output to V+, and when you put their gate to V+ they are off. And on when you put the gate to V-. And for nFETs it is the opposite.
Most ESCs have the MCU drive the pFETs via an inverter (transistor), so that when you set the output port high, the pFET gate is low (V-), and it is on. And most ESCs drive the nFET directly from the MCU. So, in most cases a high output port turns on pFET and nFET.
The small XP 3A devices do not have an inverter for the pFET gate, therefore a low output port will turn the pFET on.
And the Tgy 6A has inverters for both pFETs and nFETs...
Old 02-18-2012, 03:36 AM   #455 (permalink)
Yes, this is an important clue. Inverter must be properly taken into account.
Without the inverter would be no pFet >1S operation possible.
Old 02-18-2012, 09:28 AM   #456 (permalink)
XP 7a esc
Mux nFet pFet
A 0.5 1.2 1.5
B 0.3 1.1 1.4
C 0.1 1.0 1.3
Comp Com: 0.2
AdcIp: 0.6?
Rcp In: 0.7
OK double check!
But what do You mean with 1k/10k ???
@all: Could You share at least please the Header files, so we don't produce different types?
Name:	XP-7a  both sides.jpg
Old 02-18-2012, 12:21 PM   #457 (permalink)
OK double check!
The 1k resistor and 10k are resistors that are connected to ground to vcc.
Old 02-18-2012, 12:47 PM   #458 (permalink)
Just did some speed comparison of the SiLabs vs the Atmel:
The Atmel main "studders" around 150000 electrical rpm, which corresponds to a headspeed of 5500-6000 with an 8T pinion.
The SiLabs main runs well up to at least 240000 electrical rpm, which is about 10000rpm headspeed
The benefit of 24Mhz clock instead of 8MHz...
Old 02-18-2012, 01:04 PM   #459 (permalink)
Thanks Steffen,
I found out the pfet the source (i think) leg was connected to V+ then for the nFet one (source) leg is connected to GND. Then the Gate is connected to the MCU. Then the drain is connected to the motor.
When mapping the nfet/pfet to the ports, if it looks like this.
MCU-Pin->(A Nfet's Gate)-Nfet-(Nfet drain connected to A Pfet's Drain)-Pfet-(MCU connected to A Pfet's gate) (Drain)-Motor
MCU-Pin->(B Nfet's Gate)-Nfet-(Nfet drain connected to B Pfet's Drain)-Pfet-(MCU conected to B Pfet's gate) (Drain)-Motor
MCU-Pin->(C Nfet's Gate)-Nfet-(Nfet drain connected to C Pfet's Drain)-Pfet-(MCU Connected to C Pfet's Gate)-(Drain)-Motor
So, I'm calling the A nfet and Apfet the same if their drain are connected.
Is that how you map the pins Steffen? That's how I've been mapping the pins, I'm not sure if it's correct.
Old 02-18-2012, 01:14 PM   #460 (permalink)
That's how it's done
