Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba 14MZ - 12Z
Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum
Old 03-02-2008, 04:14 AM   #1 (permalink)
Default Futaba 12FG region changed successfully !
Hi.
I have good news for 12FG users. Please read this first !
I got my 35MHz 12FG from Hong Kong and since the frequency range was limited
I reprogrammed the TX module according to MZFANs instructions.
I also upgraded the radio software / firmware to version 1,3.
The main point is to use 82 as an area code for Europe. If you use 02, then the transmitters
area code, which still is HK will prevent the use of the TX module.
Now I have Europe on the LCD screen as an area and frequency range of
34,950 MHz – 35,910 channels 55 – 91.
I have ground tested all of the frequencies with PPM, PCM and G3 receivers
with absolutely no problems.
As we all know, do it on your own risk : )
Have fun with your great Futaba 12FG !
FinnRC is offline        Reply With Quote Quick reply to this message
Old 03-02-2008, 08:17 AM   #2 (permalink)
Originally Posted by FinnRC View Post
Hi.
I do not understand nothing
I also it be made , thanks to all those which have collaborated in this post:
https://www.helifreak.com/showthread...618#post573618
Bye
sinver is offline        Reply With Quote Quick reply to this message
Old 03-02-2008, 08:27 AM   #3 (permalink)
Bye
I don't understand also. But I am guessing he changed the region code in his module. I have not seen where anyone has accessed the service menu on a 12FG.
David
DavidH is offline        Reply With Quote Quick reply to this message
Old 03-02-2008, 02:26 PM   #4 (permalink)
David
Hello.
Sorry I didn't make me clear enough and sorry about my "not so good" English.
Let me try again.
The reason why I wrote to this forum was that I got my 12FG from Hong Kong
and I managed to change the region from Hong Kong to Europe.
Therefore I have now all the European 35Mhz frequecys in use. Thanks to MZFAN.
In Hong Kong they have only channels 75 - 82 ( 35.150 MHz - 35.220 MHz )
Now I have channels 55 - 80, 281 - 293, 182 - 191 ( 34.950 MHz - 35.910 MHz )
There is absolutely no need to get the access to the service menu of the 12FG radio to get the job done.
I was just simply happy and I wanted to share my joy.
Please read first the following thread.
https://www.helifreak.com/showthread.php?t=43590
Read the whole thing and hopefully you understand the region problem with the radio
and the TX module.
OK. what did I do.
First I updated my radio software / firmware to version 1.3. I think it doesn't
have any effect for the end result, but I did it anyway.
Then I followed MZFANs instructions and I reprogrammed the TX module.
I used the following settings to program the module.
https://www.helifreak.com/showthread.php?t=43590&page=7
I did some testing and I found out that when using region code 02 ( Europe )
in the module, there was mismatch with the radio because we don't have access to the
radios software to change the region code of the 12FG radio.
But when using region code 82 in the module the radio accepted the module
and the radio region code changed to EUROPE. So there is no need to
reprogram the radio software.
The point is that with the 12FG radio we don't have access to the radios
software and therefore we are not able to change the region code of the radio
but by reprogramming the module the right way the radio will accept the module
and the radio region will change and therefore there is no need to reprogram the radio
software which we can not even do.
This also means that if someone will figure out the code of the 2.4GHz TM-14 module
we will be able to buy it from where ever it is cheaper than in Europe
and then we just reprogram it and use it in our 12FG radio.
Hopefully you got it : )
Old 03-02-2008, 07:30 PM   #5 (permalink)
Yes I have read that thread. Like I said in the earlier post. You changed the region in the module and not in the transmitter. From what I understand for the 2.4 module to work. The region coding will have to be the same in the 2,4 module and the transmitter. At least from the reports I have seen so for that is the case. 2.4 modules for the 12 and 14 bought from the USA would not work in transmitters with a region code of Europe. They would only work after the region code was changed in the tranny to North America.
David
Old 03-03-2008, 12:14 AM   #6 (permalink)
You are right David.
The region code has to be the same in the module and tranny. Also in 12FG.
Specially if you are using non modified components.
I have now combination where the Hong Kong tranny was NOT reprogrammed in any way
but it is in Europe region mode now and all of the European frequencies are available.
Also in the LCD screen it says now "EUROPE".
This is because someone figured out that instead of using the original region code
of 02 in the module you should be using modified region code of 82.
My tranny changed the region to Europe all by itself after putting the
reprogrammed module in.
This is the reason why I think ( or hope ) that by figuring out the suitable code for
the 2.4 module it might be possible to use it in the tranny with any region code.
It is possible with "normal" module, hopefully in some day with 2.4 module also.
Old 03-03-2008, 01:56 AM   #7 (permalink)
Hi FinnRC,
Sounds interesting.
What happens if you remove your TX module and then turn ON your 12FG transmitter?
Does the 12FG still show Europe-mode or is it switching back to Hong Kong-mode again?
/Robert
Herob is offline        Reply With Quote Quick reply to this message
Old 03-03-2008, 01:59 PM   #8 (permalink)
Originally Posted by Herob View Post
Hi FinnRC,
Sounds interesting.
/Robert
Hi Robert.
I did some testing.
When I remove the modified module with code 82, the transmitter still shows EUROPE.
When I reprogram the moule back to original Hong Kong and put it back to the tranny, it shows
Hong Kong and the channels are limited to the leagal Hong Kong frequecys.
Then I programmed the module to "original" EUROPE code 02 and the
tranny did not accept the module. "Mismatch".
Finally I programmed the module back using code 82 and the tranny is now working
with all the European frequencys again.
Old 03-03-2008, 02:50 PM   #9 (permalink)
That´s amazing!!
Now I just have to build myself a serial programmer device, (hope it is not that difficult).
I also have a 12FG Hong Kong region 35MHz transmitter.
This will be interesting!
Thanks FinnRC for sharing your discoverys,
/Robert
Old 03-05-2008, 07:52 AM   #10 (permalink)
Thumbs up
Hi Robert.
I did some testing.
FinnRC,
I can just confirm your result.
My 12FG also automatically changed to Europe !!!!!!!
I now have all the 35MHz-frequencies 55-91, and a Europe-region 12FG !
MZFAN and FinnRC have made my day...and week...and year...
/Robert
Old 03-05-2008, 08:32 PM   #11 (permalink)
FinnRC,
/Robert
Hi,
Even if it looks like your radio area has changed, it has not. The radio keeps in memory the last area and frequency used when you make a new model or when there is no module in it.
But in fact the radio keeps its on original setting, in your case Hong Kong area. That means when you want to use a standard non modified module it will only accept Hong-Kong ones. You won't be able to use a 35 MHz european module for exemple, without modifying it.
Your radio will only accept Honkong modules or modified modules. With 2.4GHz modules it could be some trouble as I don't know of anybody who successfully modified one.
It is probably a matter of cconnector but I don't have one to try.
MZFAN is offline        Reply With Quote Quick reply to this message
Old 03-06-2008, 02:17 AM   #12 (permalink)
Originally Posted by MZFAN View Post
Hi,
Hi,
OK, I understand.
However, it is a great step forward having ALL the european frequencies to choose from!
I wonder if there will be any Hong Kong-region TM-14 2.4 GHz modules available in the future? Probably not.
/Robert
Old 03-06-2008, 11:21 AM   #13 (permalink)
GREAT NEWS Guys - NIIIIICE work!
Ha, - finally got the showel under Futaba - YYYiiipiii! I loooove it!!
/Henrik
Hookmaker
Kasama Srimok 90, Kasama Srimok 90E, JR Vibe 90 SG, JR Venture 90, JR Vibe 50 3D V-bar,
Bergen Intrepid Gasser, Vision-SX 90 (x 2)
MSH Protos "Monsterheli", HDX-450
hookmaker is offline        Reply With Quote Quick reply to this message
Old 03-07-2008, 02:00 AM   #14 (permalink)
Hi !
I will check the availibility of the Hong Kong TM-14 2.4GHz module
in couple of weeks.
I will keep you updated when I get back home.
FinnRC
Old 03-07-2008, 02:37 AM   #15 (permalink)
Hi !
in couple of weeks.
FinnRC
That´s great, thanks!
/Robert
Old 03-14-2008, 02:46 PM   #16 (permalink)
If anyone needs the Hong Kong region TM-14 module, ask Jason.
http://www.keimod.com/shop/
Old 11-19-2009, 05:35 AM   #17 (permalink)
Hello FinnRC,
could you contact me by PN. I am not able to send you one because i have not enough posts here :-)
i have a question concerning the regioncode..
thanks in advance
flysilent is offline        Reply With Quote Quick reply to this message
