NX4 Discussion and support of the Gaui NX4 Nitro Helicopter |
07-07-2013, 04:22 PM | #1 (permalink) |
Question regarding motor / muffler mounting
Do I need to use RTV between the two or just bolt them together?
I thought I was supposed to but the manual does not specify. Also, OMG! it was hard to put the fuel tank together!
Fusion 180 - M2 Evo - RAW 420 - Fusion 550 - Tron 5.5 - Kraken 580 - Kraken 580n - Kraken 700 - Kraken 700n - Vcontrol Evo |
07-08-2013, 10:53 AM | #2 (permalink) |
73 views, no one with an NX4 has installed their pipe and can comment?
07-08-2013, 11:03 AM | #3 (permalink) |
I would be very wary of using rtv sealant on the pipe. If any squishes in inside the exhaust in can make its way into the motor and cause glow plug failures and bearing issues.
Sent from my SCH-R830 using Tapatalk 4 Beta
700N YS.91 600N Pro OS 50 Hyper, GY611, 600E Pro All stock, Spartan Quark, NX4 OS 37, BeastX, HK250 DFC, Tarot ZYX-S, UMX Beast, X525 Quad with camera gimbal, HK control board, Spektrum DX7, Pheonix Sim v4.0 AMA# 97405 |
07-08-2013, 11:56 AM | #4 (permalink) |
I cut out a gasket out of a piece of auto gasket. It seems to work well and no leaks. I think I saw on ebay you can buy the gaskets all cut out for you, if you don't want to cut them out.
It took some patience with an very sharp exacto knife. I used gasket material for auto thermostat housing. |
07-08-2013, 12:50 PM | #5 (permalink) |
Thanks for the tips guys.
I was a little confused because in the smacktalk nitro 101 video bobby recommends using RTV on the pipe and the only other nitro I owned had it but in the manual, they just bolt on. I'll go to the auto store and find a suitable gasket to cut and fit.
07-08-2013, 04:31 PM | #6 (permalink) |
On the other forum, they say to use 5 min epoxy (Search for it in the NX4 section, its not that big over there). Just a thin coating. I never did, I bought the Gaui muffler that came with a gasket.
Minion Mini Quad 4S / Mini Talon V-tail Drone / Micro H Quad on Taranis FPV |
07-09-2013, 08:42 AM | #7 (permalink) |
Mine is just slapped on. I have tried the RTV and had a flame out down the line. Can't blame it on tr RTV but...????
I did not use it again and all good. A little dribble when it sits but I just wipe it down.
www.cuttingedgecnc.com |
07-10-2013, 09:39 AM | #8 (permalink) |
I use this stuff on all my nitros. It works well and has never leaked. You just need a little bit of it, not so much it goops out on all sides.
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR |
07-12-2013, 06:59 PM | #9 (permalink) |
after using the stuff Matt just posted, my heli is 80% cleaner and drier when i land.
before i had nothing, just bolted the exhaust to the motor
Empire Hobby/ Team Gaui USA -- Rcbearings.com -- Cyclone Blades -- Team KDE -- A-Main Hobbies -- OMG servos |
07-13-2013, 11:51 AM | #10 (permalink) |
Honda bond works real good.
07-15-2013, 07:43 AM | #11 (permalink) |
RTV works fine (make sure it's high temp, Red, Copper like Matt posted, Yamabond or Hondabond etc.) the trick is to use a toothpick and just very lightly cover the muffler surface, let it skin for 5 minutes then install it loosely so that the surfaces are touching but not snugged. Let it sit for an hour or so and then snug it tight, That lets it form into a gasket and keeps it from squishing into the motor, not that much would have anyway if the proper amount was used. The paper gaskets also work fine. I also usually resurface the muffler and exhaust port with some fine wet/dry sandpaper on a sheet of glass or granite. Usually not the first time but certainly after it's been put on and taken off several times. Never tried epoxy.
