Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > nano CP X Brushless Mods
nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help
Old 02-25-2013, 10:09 AM   #41 (permalink)
Originally Posted by SHYguy View Post
Looks promising guys!
I'm ready to "buy now" as soon as you guys have this thing wrapped up!
Tested today this:
-Microheli blades (more lift)
-Microheli 35C 200mAh batteries
>> very good & powerful, but the tail can't really keep up now... this brushless tail should do the trick!
So a larger prop is not needed, it's enough with a V2 or KBDD rotor?
The V2 rotor is the better option.
Team Newb pilot
All my helis and quads were lost in a tragic boating accident.
NCcraig is offline        Reply With Quote Quick reply to this message
Old 02-25-2013, 04:20 PM   #42 (permalink)
Has anyone used the HP03T 9000KV with a 6mm mount and how does it perform with mild / wild set up?
JonBee is offline        Reply With Quote Quick reply to this message
Old 02-28-2013, 04:53 PM   #43 (permalink)
Where is the best place to connect the esc signal wire for the bl tail esc???
Is there a spot that has a good 0 to 100% linear signal? Is that necessary?
tmacrc is offline        Reply With Quote Quick reply to this message
Old 03-02-2013, 03:38 PM   #44 (permalink)
Default Re: A new BL tail to try out........
Waiting for this is agonizing.
muddyml is offline        Reply With Quote Quick reply to this message
Old 03-02-2013, 08:48 PM   #45 (permalink)
I feel similar! was about to pull the trigger on a mild kit, but after having yet another tail motor go on me....
I wonder if there would be such a thing as an multi ESC unit that could handle both main motor and tail ? I am waiting to see how this develops.
left4deadcp is offline        Reply With Quote Quick reply to this message
Old 03-02-2013, 09:47 PM   #46 (permalink)
Default A new BL tail to try out........
Something that combined the two ESCs into a single unit would make installations much easier/cleaner.
Mate then I'd consider a BL tail.
nicholask1993 is offline        Reply With Quote Quick reply to this message
Old 03-03-2013, 06:41 AM   #47 (permalink)
There are some dual PnP solutions for the mCPx. But it's better to direct solder, and you may then as well have two separate ESCs. Easier to place.
Micro: OMP Hobby M1
Big: SAB Goblin 500
Radio: Spektrum DX8 Gen 1
Old 03-03-2013, 06:59 AM   #48 (permalink)
Easier to place.
And easier and cheaper to replace.
Team Newb pilot
Old 03-04-2013, 07:57 PM   #49 (permalink)
Would you be able to tell me what gauge of wire is being used and how many turns are on each tooth?
I may attempt a rewind if I can find the wire.
Old 03-08-2013, 03:26 PM   #50 (permalink)
Nice looking motor. How does it compare to the other 12000kv motor we have been using on the MCPX? Mine holds great on it. This looks much smaller and lighter though.
litehawkdown is offline        Reply With Quote Quick reply to this message
Old 03-08-2013, 05:23 PM   #51 (permalink)
Originally Posted by tmacrc View Post
I like experimenting. what motor are you using for the tail? do I have to rewind the HP02T for 12000KV or is there one out there somewhere? If so where?
Hobby King have a 12000kv motor listed for micro heli tail motor - this may be worth experimenting with.
Old 03-08-2013, 05:37 PM   #52 (permalink)
Hi,
I'm flying that HK12000kv on my wild set up at the moment and quite like it, holds the tail excellent for my type of flying (mild 3D). Although when Dylan has the HP02T back in stock I will buy it because it weighs less.
timox72 is offline        Reply With Quote Quick reply to this message
Old 03-08-2013, 05:51 PM   #53 (permalink)
Originally Posted by timox72 View Post
Hi,
Is that the 8000kv HP02T? alot of feedback suggests that this is not the way to go - I would be interested in any comments or suggestions as I am looking at a tail brushless option as well? I am indoor mild set up only - not after wild for outdoor use.
Old 03-08-2013, 07:21 PM   #54 (permalink)
I believe he is talking about the HK 12000kv Micro Heli Tail Motor.
At 14mm OD and 3.2g it is actually bigger than the HP02T at 13mm OD and 2g.
I am told with the right prop the 8000kv will work. That is where I am headed.
Dylan is working on a 12000kv HP02T.
http://www.hobbyking.com/hobbyking/s...Search=12000kv
Old 03-08-2013, 07:25 PM   #55 (permalink)
I think it is the 8000kv motor but am not a 100% sure, I also read the same as you about the lower kv is not the way to go. What I'm sure of is that the HK12000kv is working pretty good for the wild but might be to heavy for the mild.
Djeez......sorry Craig! Just read in your very first post that it is the HP02T 12000kv which weighs 2.36gram. Sorry for reading with my eyes closed
Old 03-13-2013, 04:14 PM   #56 (permalink)
Any further updates on the BL tail project yet? I rather fancy building my Wild kit with a Bl tail, but I'll build it with a brushed tail if the BL tail motor is still a while away from availability.
Nano CPX x 3, mCPX-BL x 3,130X, 180CFX, Lynx 450X-L, T-Rex 250 DFC, T-Rex 450L, T-Rex 500, KDS Chase 360, SAB G380, G500 Spt, BT650, BT700-T, BT700 Spt, XLP520
"More the Knowledge Lesser the Ego, Lesser the Knowledge More the Ego" Albert Einstein
Miracle Boy is offline        Reply With Quote Quick reply to this message
Old 03-14-2013, 11:36 AM   #57 (permalink)
I got impatient and ordered a hp02t 8000kv from Oversky and I ordered a 3.2g 12000kv motor from hobbyking.
I'm going to experiment with the hp02t and see if I can successfully rewind it to 12000kv before the public offering. (All my birds are grounded at the moment so....)
Old 03-14-2013, 11:49 AM   #58 (permalink)
Interesting! Let us know how it works out for you
Old 03-14-2013, 12:02 PM   #59 (permalink)
There is 10 winding's on the HK 12000kv of 30 awg wire.
Old 03-14-2013, 03:22 PM   #60 (permalink)
Thanks for this! I asked it a few days ago but never got a response. I have a spool of 30awg sitting on my work bench too!
