500 Class Electric Helicopters 500 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
10-21-2016, 11:23 AM | #1 (permalink) |
500 Rebuild to 500Pro, help a guy out!
Hi everyone, I crashed my 500and decided to rebuild it as a 500PRO. Everything is going perfect apart from one issue. My auto-rotation gear and tail drive gear ARE NOT meshing. Everything is sitting right, but I have a 1-2mm gap between them. I have been trying to see if I need a bigger auto-rotation gear (diameter) or a bigger tail drive gear (also, bigger diameter). The manuals for both heli's only show teeth count and the pics are..well.....you know, not always super helpful. Online options don't give out many specs that allow me to tell each unit apart from the other. I have a sweet pic of this issue too, but can't post it???? OH WELL let me know if you have any knowledge on this.
Thank you HeliFreaks! The Big Guy |
10-21-2016, 05:14 PM | #2 (permalink) |
There may be an answer here:
T-REX 500E Super Combo KX017014A Main drive/Tail drive: Drive Gear Ratio:1:12.46:4.68 T-REX 500E PRO Super Combo KX017015 Main drive/Tail drive: Drive Gear Ratio: 1:11.17:4.03 T-REX 500PRO DFC Super Combo RH50E01X Main drive/Tail drive: Drive Gear Ratio: 1:11.17:4.03
P 700 EVO, XLP Nimbus 550, P 380 EVO, Futaba ,YGE-T, neXt and Heli-X Loud, sudden noises in a helicopter, WILL get your undivided attention |
10-22-2016, 10:14 AM | #3 (permalink) |
Sounds like you have an old ( pre mod0.6 ) autorotation gear. The current spec is mod0.6 with 145 teeth on the auto gear. I've had this issue on my 550 and 600 when I order the wrong mod. I'd just order a new auto gear, and match it to the tail drive gear mod that you are installing.
Specter 700, Protos 700 Gasser, XLPower 550, Protos 380 - Jeti DS14 Citizen - #202 |
10-22-2016, 10:29 AM | #4 (permalink) |
sounds like you have the 31t tail drive gear, and you need the 36 tooth for the pro set up.
10-22-2016, 11:10 AM | #5 (permalink) |
Thank you so much guys!
10-22-2016, 12:58 PM | #6 (permalink) |
if you can use the 31t it would be better for tail authority. it speeds up the tail..so use the old 31t and auto gear and have better tail holding. for the pro they increased headspeed and decreased tailspeed.
a bunch of helis... now all vcontrol and neo..finally :lol |
10-22-2016, 02:04 PM | #7 (permalink) |
This /\, you bought the pro autorotation gear. Want 4.7 tail ratio get the original auto, want the 4.0 ratio get the 36 TT front gear. Pro - L and uses it. Less tail vibes but requires higher head speed for the tail to hold
Align 450Pro 3GX, 500ESP/DFC 3GX, 500L, 550 DFC MicroBeast , Velocity 50 Vbar OS55 HZ-R, D380 DFC D420, G500 Sport Microbeast, All HW V4, X5 stretch 220 Flame Emax Bullet Force V2 VTX |
