Walkera Helicopters Walkera Helicopter Support |
12-13-2010, 02:31 PM | #1 (permalink) |
Help noob with 2801 pro can't adjust settings
I have jusr received a 2s hot rod 4g6s with the 2801 pro tx.I am trying to gain access to all the setting so I will be able to set it up should I ever lose the settings. After selecting mdset then scrolling over to the right side of the menu (the side that says exp&dr,curves failsafe, monitor) the only submenu I can gain acccess to is the monitor.When I press enter on the other sub menus like expo &d/r nothing happens is this normal?Am I doing something wrong?Is the tx locked or maybe just malfunctioning.By the way the whole set up was done by wow hobbies.Thanks for any advice.Confused VT Heli
12-13-2010, 08:22 PM | #2 (permalink) |
I don't think there is anything wrong with the TX. Which RX does the heli have?
If it's the 2610S the heli is bound with the 2801 under 2601 mode in which case you would not have access to the functions you are looking at.
Some people have a problem for every solution... |
12-13-2010, 09:21 PM | #3 (permalink) |
more help please
Thanks John,
I will look into what rx I have.It looks like I have the 2610s-1.if those settings are locked out how did wow hobbies adjust those settings.pleASE ADVISE i AM MORE COnFUSED THAN EVER.I am sorry for the caps my grandfather just had a heart attack in front of me and passed so I feeeling a little down and out.but this is distracting me a little.could u please explain if those setings are locked out how did wow hobbies set up my heli with d/r and expo to make it suitable for a beginner. And how do I adjust those settings when I am ready.sorry for the ramble not feling myself right now |
12-14-2010, 03:58 AM | #4 (permalink) |
You need to go into the STICK section and set your RX mode to 2801. Setup your rates and save changes. Then revert the RX mode back to 2601mode and the changes will remain current. Even Walkera 4CH RX's accept things like EXPO and DR with the 2801pro TX, but you need to be in 2801 mode to edit. Just be carefull that you dont change your flight mode from Mode2 by accident when in the stick menu.
