Go Back   HeliFreak > R/C Helicopter Support > Electric Micro/Mini Helicopters > X400 and MX400
X400 and MX400 Ark X400 and HeliMax MX400 Helicopters Information
Old 09-11-2006, 07:32 PM   #1 (permalink)
Default LiPo batteries, what are you using?
I'd like to know what fellow MX400ers are using or prefer.
kenpsych is offline        Reply With Quote Quick reply to this message
Old 09-12-2006, 07:45 AM   #2 (permalink)
Im using the Align 2100 16c LiPo batteries...
mx400pro1 is offline        Reply With Quote Quick reply to this message
Old 09-12-2006, 02:22 PM   #3 (permalink)
Thunder Power 2100 15c LiPo. It seems to be able to handle things just fine. Especially if you are just using the default HeliMax 2580 motor with the default wood blades.
I am only into forward flight and not aerobatics yet but I have never seen the default HeliMax 2580 and default blades pull more than 21 Amps out of the battery during a max climb at +11 pitch and 100/80/100 throttle curve. 21 amp draw on a 2100mah battery equates to about a 10C discharge so 15C has some breathing room considering the 15C rating is for a continuous 15C draw. I am only into forward flight though and tested it with a simple vertical climb so if you throw the thing around a lot I am sure it could pull more than 21 amps but probably not much more.
StatiC is offline        Reply With Quote Quick reply to this message
Old 09-12-2006, 08:58 PM   #4 (permalink)
I am using Apex 2100 and regularly get 5 to 7 min flights, hover & FFF.
broncomech is offline        Reply With Quote Quick reply to this message
Old 09-13-2006, 08:46 AM   #5 (permalink)
electrifly 2100 20C- does not fit into stock canopy. 5.5 mins stock ESC and motor.
WB
The wind is my teacher.
windbender is offline        Reply With Quote Quick reply to this message
Old 09-13-2006, 09:20 AM   #6 (permalink)
Do these batteries have short circuit protection and low voltage protection? I have heard from some sources that any li-po battery or cell shipped to an end customer has to be protected but then again I have heard the opposite too. I couldn't find any information about it.
Old 09-14-2006, 06:55 AM   #7 (permalink)
There was nothing attached to the connectors that could be called "short circuit protection". just the usual cardboard back with see-thru plastic front.
WB
Old 09-14-2006, 09:11 AM   #8 (permalink)
I sent Thunder Power and email and they said that the batteries do not have any kind of protection on them. They expect the ESC to have that capability. I think that is the norm for these Heli batteries. Unfortunately if you have a short in your ESC or the battery shorts when not connected to the ESC your battery could burst into flames.
I am very surprised that battery companies can ship lipo batteries without protection. Be VERY careful with them. Don't ever put one in your pocket that is for sure.
Old 09-22-2006, 07:36 PM   #9 (permalink)
Default Re: LiPo batteries, what are you using?
I just ordered and received the Align 2100 16c packs. I'm quite impressed with the power of these batteries. I only got to hover around the front yard so I could not get a good feel for performance but the power was nice and she climbed out effortlessly. I've been using Common Sense 2100 batteries but I busted one up on a crash and it slowly got weak, plus I did not notice the small cut in the cell. The second battery has gotten considerably weak, so that's why I asked to see what you guys like...
Old 09-24-2006, 03:05 PM   #10 (permalink)
I'm useing epower 2200 12c on an align 430l 3550kv and 315 cfs. Geting about 8 to 10 min per flight with 2800rpm max hs. and about 15min on 315 woodies. they may not have the 400 cycle life but for the $38 price tag its a great bat.
Team Outrage
OPM - Fly it like it aint yours!
JR X9303 2.4 Baby. I have felt the difference and I like it!
Don"t make me list 'm all !
Raven_darkcloud is offline        Reply With Quote Quick reply to this message
Old 04-27-2007, 02:10 AM   #11 (permalink)
im running a maxamps 11.1 2100 mah and it seems to be a good pack ! i have crashed the heli with it in and no damage ! and im getting about 8 min per a pack mainly hover with just little ff . running the pack down to about 10. volts
Trex 600NP
Trex500esp
whattheheli is offline        Reply With Quote Quick reply to this message
Old 06-07-2007, 07:08 PM   #12 (permalink)
Apogee 3cell 11.1v 2200 mah. Tower stays sold out of them. I was impressed enough to order a second pack on back order of course.
Scottlclem is offline        Reply With Quote Quick reply to this message
Old 06-08-2007, 06:43 AM   #13 (permalink)
Switched to Evo25 1800 3P ( 145 gms vs 180 gms for the 2100) AON 3550 motor, jazz ESC 7 mins flight at H/S 2400rpm, 315mm wood blades. Also fixed a nose heavy issue. Runs very cool.
Wb
Old 06-08-2007, 11:00 AM   #14 (permalink)
I use the Bishop power products, Hyperion Lite-storm 1800Mah 20c 11.1. In the Mx 400 pro
I am geting 9 1/2 minutes out of it stock motor@ Esc and wood blades.
Maxx26 is offline        Reply With Quote Quick reply to this message
Old 06-16-2007, 07:41 AM   #15 (permalink)
Hi Guys, please confrim if using a Premium Power 11,1 v 20c+ 4800 Mah lipo with an Align 35 esc is ok or safe for powering the X400?
femi is offline        Reply With Quote Quick reply to this message
