Old 09-11-2011, 05:24 AM   #41 (permalink)
Here is a link to the V2 manual, You can see clearly it has the new tail with 2 radial & 1 thrust bearings !!!
http://video.align.com.tw/mpeg/manua...s/kx018e12.pdf
shahar_lz is offline        Reply With Quote Quick reply to this message
Old 09-11-2011, 10:51 AM   #42 (permalink)
Originally Posted by dvillijs View Post
Why not in_to_the_mystic? I want a lot of new upgrades and they have most of the new designs. I also check on net and lotsa guys indicated they got good and bad service so ima bit cautious.
The guy from ebay is also in taiwan and guess the only country he does not ship to.... Africa, lucky me , hench me asking for helipross
Has anyone bought from the Align online shop?
Do a search on Helipross. Plus they jacked the name from Heliproz, not someone i want to do business with.
Align Shop is Taiwan only.
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote Quick reply to this message
Old 09-11-2011, 02:19 PM   #43 (permalink)
Default tail
my new v2 did not come with this
vibe 50nex ys56
trex 700 le
avant aurora ys91sr
watso is offline        Reply With Quote Quick reply to this message
Old 09-11-2011, 03:28 PM   #44 (permalink)
Default 700E different V2's ?
Hi!
Just realized that ppl have different versions of 700E V2. Do we also have different kit no on our helis?
I have a KX018E12 ( marked V2 3GX on the box). Have most (all I know of) of the upgrades stock.
AAKEE is offline        Reply With Quote Quick reply to this message
Old 09-11-2011, 04:56 PM   #45 (permalink)
Default tail
mine has the same model as yours.
vibe 50nex ys56
trex 700 le
avant aurora ys91sr
Old 09-11-2011, 11:02 PM   #46 (permalink)
Originally Posted by cmar143 View Post
I believe KDE has an upgrade for the tail that does exactly that.
The KDE upgrade is a must have, I have it on my 550, 600, 700E and 700N, you can clearly notice the flight performance.
I ordered one of the new tail blade holders just for the color, it match my heli very nice
Roger P
Align T-Rex Family Owner - MicrobeastX - 7200BX
450 Dominator, 500 Dominator, 500(Airwolf) Four Blades, 550 DFC, 600N DFC OS55HZ, 700N DFC 105HZ-R, 700 DFC HK4525-520LE
Roger Palacio is offline        Reply With Quote Quick reply to this message
Old 09-12-2011, 04:51 AM   #47 (permalink)
I did the V2 upgrade.
The grips are a bit thicker than the previous one but the bolts, that holds the tail blades, are the same lenght as before. Hence the Hex lock nuts will not work properly since the bolts are too short.
w12martin is offline        Reply With Quote Quick reply to this message
Old 09-12-2011, 09:01 AM   #48 (permalink)
w12martin, Can you clarify what you mean? You have the newer grips that a few of us just ordered. I got that. The Hex lock nuts not working is what I am confused about. Are you saying that the newly released Align V2 grips (HN6103A) come with bolts for the tail blades that are too short? The upgraded tail comes with bolts for the tail blades as pictured below.
StatiC is offline        Reply With Quote Quick reply to this message
Old 09-12-2011, 09:26 AM   #49 (permalink)
Yes, the bolts are too short. Simple to fix btw, but...that's not the point.
ID:	253156   Click image for larger version
ID:	253157   Click image for larger version
Old 09-12-2011, 09:35 AM   #50 (permalink)
Well that sucks because I am expecting to get the tail by the weekend to start flying again. I assume you ordered longer bolts or did you do something else. Where did you order longer bolts from if that is what you did?
Old 09-12-2011, 09:47 AM   #51 (permalink)
Well, since I'm still waiting for my ICE2 120HV, I didn't order the proper bolts yet. I think 3 or 4mm longer should be enough
Old 09-12-2011, 10:53 AM   #52 (permalink)
Did you get the V2 tail from the ebay seller, somewhere else, or did it come with your heli kit?
UPDATE:
I found some that are 18mm that don't have threading all the way through that look like they will work fine. Can you measure to see if 18mm would work? Please?
Old 09-13-2011, 04:46 AM   #53 (permalink)
I bought the V2 upgrade from a local shop in Japan.
I think you need at least 20mm bolts
Old 09-13-2011, 08:48 AM   #54 (permalink)
Just wondering why Align haven't chosen to use a design with 'Chinese Weights' built into it? It's a pretty well proven theory so why wouldn't they use it? I know they did it on the TRex 250 (and perhaps others) so is there any reason not to have done it on a 90 size heli?
J-S-Q is offline        Reply With Quote Quick reply to this message
Old 09-13-2011, 02:29 PM   #55 (permalink)
Good Question, Not sure why they would not.
Old 09-13-2011, 02:30 PM   #56 (permalink)
w12martin, Thanks for that.
I think i found a winner below. On sale too . I just ordered a pair. Hopefully the lock nuts are a standard size that match the Align lock nuts.
http://www.amainhobbies.com/product_...hanked-Bolts-2
UPDATE: Actually after I look at your picture I realize that 18mm would have probably been fine. The 20mm measurement is from the top of the bolt head to the bottom of the bolt. The 20mm bolt I ordered I am sure is the shank size (bottom of bolt head to bottom of bolt). That extra 2mm will just give me .01% of the chinese weight mod .
UPDATE2: Hmmm... Now I hope there is enough threading with 2mm of the threading sticking out past the locknut.
UPDATE3: I just added a small package of 3x18mm to my order so I should be set either way now. Thanks for letting us know the bolts are too short.
http://www.amainhobbies.com/product_...p-Head-Screw-4
I thought I remembered reading 2 years ago that chinese weights don't make as much of a difference with bigger tail grips (compared to 450 sized heli)... I am probably mistaken though.
Old 09-13-2011, 04:59 PM   #57 (permalink)
I have the new tail as stock on my 700E v2.
The tailbolts reach thorugh almost all of the nyloc part of the nut. Not all way through, but I'd say 70%.
It locks so good that I cant turn the bolt with fingers only. Guess it wount come loos in flight.
I think, if you loosen the bolt a lot of times the nyloc would become worn and perhaps loose locking-force.
Old 09-13-2011, 08:47 PM   #58 (permalink)
xStatiCa, sorry!! my mistake. I measured the bolts form the top of its head.
18mm should do the job
Old 09-13-2011, 11:54 PM   #59 (permalink)
What tail blades can used with it? I guess 120 mm would touch the ground or long main blades, like 713mm
T-Rex 700N: JR DS8717HV; Vortex VX1+Outrage BL9188HV; Outrage BL9080HV/Throttle; Gryphon regulator; SG Pro; OS MAX 91HZ-R
T-Rex 700E: JR DS8717HV; Spartan Quark+Outrage BL9188HV; CC ICE HV 160A; RCM-BL750MX (450KV); WR Super BEC
T-Rex 250SE 350Watts
QYT001 is offline        Reply With Quote Quick reply to this message
Old 09-14-2011, 04:18 PM   #60 (permalink)
The weights only improve small helis.
NO FLYBARS
504Rone is offline        Reply With Quote Quick reply to this message
