Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > Genius CP
Genius CP Walkera Genius CP Helicopter Support
Old 01-26-2014, 05:47 AM   #1 (permalink)
Default devo transmitter flashed with deviation software
Hi all.
Is there a video showing how to do the above.
Roy
RoyM is offline        Reply With Quote Quick reply to this message
Old 01-27-2014, 12:27 AM   #2 (permalink)
How to upgrade Devo Tx Firmware to Deviation Firmware V2.1 and V3 (9 min 9 sec)
mnem
*******com occasionally sends me free stuff; I review it. You have been warned.
mnementh is offline        Reply With Quote Quick reply to this message
Old 01-27-2014, 09:10 AM   #3 (permalink)
mnem
Thankyou for the video,as a member of the old farts club I prefer to watch something rather than try and do it from the web site.
Thanks again, Roy
Old 01-28-2014, 08:58 PM   #4 (permalink)
Glad to help...
I'm a bona fide Old Fart myself; the longer I stay in this hobby, the bigger and yellower my airplanes get...
mnem
Old 01-29-2014, 05:23 AM   #5 (permalink)
Hi.
Can you suggest where I can get a cable to connect my computer to devo tranny ,or perhaps an item code/number. I want to try and use the deviation software.
Roy
Old 01-29-2014, 12:45 PM   #6 (permalink)
Which TX?
IIRC, all the newer Devention Family of TX use a standard Mini-USB cable that you probably have lying around. Then it's just a matter of downloading & installing the Walkera dFusE firmware update tool, and downloading the Deviation firmware and libraries from Deviation.
mnem
More cow.
Old 01-30-2014, 10:17 AM   #7 (permalink)
Yes, my Devo 8s uses the standard mini USB plug.
TexanPilot is offline        Reply With Quote Quick reply to this message
Old 01-31-2014, 03:42 AM   #8 (permalink)
Devo 7e, I only purchased the TX so it came without any bits and pieces.
Roy
Old 02-01-2014, 10:58 AM   #9 (permalink)
As shown on the Walkera site here:
http://www.walkera.com/en/showgoods.php?id=451
the Devo 7E does in fact use a common Mini-USB cord available pretty much anywhere.
One word of warning; there's a reason the 7E is much cheaper than its brethren. It is designed with a 1/10th power TX module which is intended ONLY for indoor use. Even as a ParkFly TX its range is questionable.
There IS a hack to increase the power to almost full-range output; but it's DEFINITELY a Dilbert-level hack (as in, not recommended unless you're a Dilbert) and your questions so far indicate that probably isn't you.
mnem
May the Schwartz be with you.
Old 02-10-2014, 07:54 PM   #10 (permalink)
Don't flown larger plane/heli with your Devo7E its only 10mhz instead of 100mhz but it consume battery like 100mhz controller. I experiment 2 or 3 lost of control with it only my throttle hold switch was working by chance.
Still a good transmitter much better than dx4 or lspm4 blade shit
8S and 12S are good
dalid is offline        Reply With Quote Quick reply to this message
Old 02-12-2014, 08:06 PM   #11 (permalink)
Dalid means 10mW vs 100mW power output, which is what I was talking about.
Don't... just DON'T.
mnem
*Low-Power*
Old 02-17-2014, 08:01 PM   #12 (permalink)
But don't worry if you already have this transmitter it does exist a very simple mod for the 7E, by removing something inside of it gonna became 100mW full range transmitter.
Old 02-23-2014, 12:03 AM   #13 (permalink)
mnem
Umm, yeah; I think I covered that aspect too.
Old 02-23-2014, 12:45 AM   #14 (permalink)
If the Devo 8s is not to your liking or budget the Devo 10 is full size and full range and deviation compatible too. I love mine.
V120d02S, 450 Pro, 480 Pro 6S
Raptor E550
jml79 is offline        Reply With Quote Quick reply to this message
Old 02-23-2014, 04:24 AM   #15 (permalink)
How is it done? I need to do that to my 7e.
-Heli Yea! Master of: the living room, mechanical setup and, the obvious!
Belt'ish CP FBL, HDX 500 DFC, New V120D02S FBL, Mini CP FBL, Hirobo Shuttle ZX, 450L w/VX1e, QR-X350PRO FPV, 450L w/APM FPV(in progress) DEVO 10 white w/2km range!
Heli Yea! is offline        Reply With Quote Quick reply to this message
Old 02-23-2014, 04:45 PM   #16 (permalink)
WALKERA DEVO 7E TRANSMITTER INCREASE RANGE MOD
http://www.hacksmods.com/2013/04/wal...ase-range-mod/
Blade 300X all control by Devo8S with Deviation 3.0 firmware
Eflite ask-21 powered
Eflite Sbach 342
Walkera Super CP, Ladybird
Old 02-23-2014, 05:23 PM   #17 (permalink)
Alright! thank you so much!
Old 02-24-2014, 08:57 PM   #18 (permalink)
Very comfortable radio the Devo7e, I also try Devo6s same shape but nicer
Eflite Sbach 342
Old 02-24-2014, 09:27 PM   #19 (permalink)
Ummm... yeah.
Like I said, not a project for the uninitiated. Be VERY careful; there have been a number of readers who've turned their 7Es into a doorstop using Daryoon's hack. Not because he documented it poorly; quite the opposite. He has documented it very well, and it LOOKS easy. It is NOT.
I do this stuff for a living; it's second nature to me. MOST people don't have 30 years of micro-soldering experience. You are messing about in the RF amplifier's power section; any accidental solder blob can short out the radio and release the magic smoke.
This is NOT a project for folks who don't already know their way around a printed circuit board and have a fair bit of soldering skillz.
mnem
Old 02-24-2014, 10:51 PM   #20 (permalink)
I'll probly skip it. I have looked inside and know all the wonders of magic smoke. Way to tiny for me. I can fly far enough till I get the devo 10.
