Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 09-16-2012, 11:30 AM   #81 (permalink)
Default here is mine
having hard time with pictures upload
Name:	heli photos 020.jpg
ID:	349930   Click image for larger version
Name:	heli photos 027.jpg
ID:	349931   Click image for larger version
Name:	heli photos 021.jpg
ID:	349932   Click image for larger version
Name:	heli photos 018.jpg
gimballina jolie is offline        Reply With Quote Quick reply to this message
Old 09-17-2012, 04:28 PM   #82 (permalink)
flybarless and all !! good stuff gimballina jolie
stark is offline        Reply With Quote Quick reply to this message
Old 09-18-2012, 06:37 PM   #83 (permalink)
Default mine
this is mine and its for sale....
plus a few other stuff i have
ncrkceo13@gmail.com is offline        Reply With Quote Quick reply to this message
Old 12-01-2012, 01:10 PM   #84 (permalink)
My new (to me) Gaui 425 with the quick paint job I threw on it. I plan on trying some fancy stuff this winter with an air brush, but I just wanted to get something on the stock canopy to get in the air. The stock canopy is actually pretty easy to put together, I found the Testors orange plastic model cement worked perfect.
The theme is "Visibility":
Ya, the monocote trim sheet I used on the tail is not a perfect match, but I think it will work. Next time I am in St Louis I will head by Mark Twain Hobby and see if I can find a better match in person.
I was able to do a test flight this afternoon, it flew great. A couple of twist of a link to get the blade tracking in and a bit of trim and it would hover without my thumb on the cyclic. Wow 500 class rocks!
EDIT:
Here it is with the boom and tail blades painted. It looks much better I think.
Gaui Hurricane w/ 530mm blades & Robird G31
Walkera Super CP
Walkera Devo 10 w/ Deviation
SQRT(-2) is offline        Reply With Quote Quick reply to this message
Old 01-09-2013, 10:17 AM   #85 (permalink)
I just wanted to share the Gaui FBL and with new wiring.
I made a bottom plate in the body with plywood, I drilled a hole in it and put a thin plywood bottom that slid between the skids and the frame. I hid all the coils of wire between these two bottoms.
Walkera Super CP
Old 02-04-2013, 06:26 PM   #86 (permalink)
Thank you PTcaflyer! Got it put together this afternoon... Now to learn what I need to look over and check out before the first flight.
fiveflat is offline        Reply With Quote Quick reply to this message
Old 02-04-2013, 08:12 PM   #87 (permalink)
HF MR Support
You are Welcome!
You will have fun and soon you too will have the"Gaui Grin"!!!
PT
Gaui 550(Need GOT ONE!) / KK2.1.5 steveis pro/ZMR250 / Alien 450 camera ship / HJ 450 all W/KK2.1.5 Steveis pro Estes Nano/ Hubsan X4 / Syma X1
AMA 953414 CONTRIBUTOR, TEAM LAVAQUAD
PTcaflyer is offline        Reply With Quote Quick reply to this message
Old 02-05-2013, 08:10 AM   #88 (permalink)
Awesome job with the wiring. I also see that you have made your own flybarless head out of the original 425 head. How is it working out for you? Would love to know how you made it .
cheers,
Old 02-05-2013, 08:19 AM   #89 (permalink)
Works just fine for me.
I ran the Jesus bolt through the flybar seesaw bolt hole to lower the head. The links I made out of threaded rod. I bet you could find a rod that is the correct length, but I could get the threaded rod local.
The extensions are these:
http://rcdumbthumbs.com/G-204706.aspx
For the swash follower you can mod the FB ones our use this:
http://rcdumbthumbs.com/G-204707.aspx
I imagine a Trex 500 FBL head would also work, Tarot has one for $45
http://tarot-rc-heli.com/Tarot_RC_He...less_Rotorhead
EDIT: Sorry, man did not see you were in Finland there. I don't know where to get those in Europe, but I bet you can figure it out. I'll keep the links to where I know to find them so you can see exactly what I am talking about.
Walkera Super CP
Old 02-05-2013, 02:44 PM   #90 (permalink)
I di dthe same mod for my 550 - I used some rods that I had for the swash to grips - they are either the cyclic servo to swivel links from the Gaui 550 / 435 or from a Raptor
Mikej is offline        Reply With Quote Quick reply to this message
Old 02-05-2013, 06:54 PM   #91 (permalink)
Default Gaui 425
I like this... are parts hard to get?
volvochef is offline        Reply With Quote Quick reply to this message
Old 02-06-2013, 03:33 AM   #92 (permalink)
Thanks for the info. As long as I know the part numbers I can do the finding
cheers,
Old 02-12-2013, 02:03 PM   #93 (permalink)
Slighty off topic here, but I came back to this thread just to see SQRT's FBL setup. I have also read that the Trex 500 FBL head is a direct fit to the stock main shaft, anyone see any reason why the Trex 500 DFC head wouldn't work either?
Old 02-12-2013, 08:57 PM   #94 (permalink)
DFC uses a shorter main shaft. (I think.)
Walkera Super CP
Old 04-06-2013, 11:28 AM   #95 (permalink)
My gaui 425 before my first take off (boom is medium boom but blades are 425mm)
Hacker A40-12S 1350kv
CC ICE 75
Futaba S3152 on cyclic and BMS 661DMG on tail
2 lipos turnigy 3S 3000mAh 30C
I bought it on ebay (no motor and no esc) nearly 18 monhs ago
And I did not put the canopy for the flights
milliotseb is offline        Reply With Quote Quick reply to this message
Old 04-06-2013, 01:40 PM   #96 (permalink)
Looks great...love that canopy!!
Blade QX, Align Trex 500, Gaui 550 Hurricane, HK600GT, 450 Quadcopter
I have a perfect record in helicopter flight......I've never left one up there!!!!!
Davy Crockett is offline        Reply With Quote Quick reply to this message
Old 04-06-2013, 01:47 PM   #97 (permalink)
HF MR Support
Looks Great! Those canopies are collector items!!
Try bumping that gyro gain up at least 10% and go to 500mm blades...!PT
