Like Tree325Likes
Old 05-09-2016, 10:38 AM   #2341 (permalink)
Originally Posted by btheli View Post
Here's what I came up with for a charge case. Thanks to everyone who posted here for many great ideas. Very special thanks to pctomlin for answering tons of questions, and to Ian Contessa, developer of the IceMeter, which safe guards my 4010 Duo against damage if one of the server PSU's were to fail (lots of other "cool" features too). Still need to finish the lid with some flat panels to make it look nice and perhaps my old Android pad.
Hey Buddy.
You're very welcome and thank you for your custom.
Your case has turned out really nice and very neatly laid out to.
Ian Contessa
Ian Contessa
Coolice Charge Cases & Power Supplies
Facebook Page
Coolice is offline        Reply With Quote Quick reply to this message
Old 05-09-2016, 12:02 PM   #2342 (permalink)
Nice job on the case Ben. Looked forward to checking it out in person at the next FF I see you at.
Paul
Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD
Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD
pctomlin is offline        Reply With Quote Quick reply to this message
Old 05-09-2016, 12:41 PM   #2343 (permalink)
Thanks. This has not been a good year for me making FF's!
Sent from my phone using Tapatalk
MSH Prôtos Max V2 770 ● Gaui X7 & X3 ● Synergy N5C ● SAB Goblin 570 ● Spirit FBL ● Horus/Taranis
btheli is offline        Reply With Quote Quick reply to this message
Old 05-13-2016, 08:12 PM   #2344 (permalink)
Here's mine, will probably be a few mods coming soon but very happy with it so far
Sab 770, Sab 700, Sab Raw 420
jockey is offline        Reply With Quote Quick reply to this message
Old 05-29-2016, 05:45 PM   #2345 (permalink)
Some great looking cases everyone! I'm curious about fan direction. If I have 2 fans mounted on the top. They only blow one direction unless you flip one around. Should they both blow out and not worry about fresh air going in?
T-Rex 700 Dominator vx1e, Goblin 570 vx1e, T-Rex 600N DFC vx1e, Jeti Ds-14
NSFlyer12 is offline        Reply With Quote Quick reply to this message
Old 05-29-2016, 09:11 PM   #2346 (permalink)
It all depends on how you set up the air flow through your case. You do need to have fresh air coming in to supply a fresh exchange of cooler air. You can have fans just pulling air in, sucking air out or a combination of both.
Paul
Old 05-29-2016, 09:23 PM   #2347 (permalink)
The way I set mine up is I have side mounted fans, and they blow directly across the supplies.
One blows in and the one on the opposite side sucks air out.
It seems to work pretty good at keeping the supplies cooler. I haven't had the fans on the supplies kick into high speed in a while.
Gaui X7 w/Vbar, Miniature Aircraft Tempest w/ YS 91, Gaui X5 w/ Vbar, JR Vigor w/ YS 61, Gaui X3 w/ Vbar, Blade 180 CFX, Spektrum DX9
19trax95 is offline        Reply With Quote Quick reply to this message
Old 05-29-2016, 10:03 PM   #2348 (permalink)
I also have one fan blowing in and one blowing out. Just make sure that they move air the same direction as your power supply fan or they're going to be fighting with eachother and not doing any good.
Specter v2, Tron Dnamic, Nimbus 550, P380, Edge-TX
JWeber is offline        Reply With Quote Quick reply to this message
Old 05-30-2016, 12:44 AM   #2349 (permalink)
Lostwages is offline        Reply With Quote Quick reply to this message
Old 05-30-2016, 02:07 PM   #2350 (permalink)
Default Post your charger case
Here's mine!
Attachment 654837
WHIPLASH GASSER w/ Hanson 290RC 3D Max
3xTrex 700X Dominator , Trex 450L Dominator 6s
SPEKTRUM IX20 , SPEKTRUM DX9 BLK EDITION
mark196622 is offline        Reply With Quote Quick reply to this message
Old 06-01-2016, 09:44 PM   #2351 (permalink)
Mine is still a work in progress.
I have the Home Depot Rigid case, Chargery 1500w power supply and iCharger 406 duo charger.
So far I have the power input routed to the back of the case, v2 deck is work in progress and made of 1/4 inch MDF (final version will be 1/4 inch ABS) and I found some heavy duty 90° hinges. I got some binding posts for routing the charge outputs to the deck and I will just drill a couple holes for the balance leads. I'm waiting on hanging mounts from ProgressiveRC to mount the charger.
I plan to add cooling fans & vents, a usb output for my phone & field tablet and if I can figure out a way to mount servo leads into the deck, I can still make use of the built in servo tester.
Edit: Anybody know why the pics upload upside down? And how to fix it?
Team Lynx Heli Field Rep
XL Protos 380
Jomaba4308 is offline        Reply With Quote Quick reply to this message
Old 06-03-2016, 07:46 PM   #2352 (permalink)
Default Charging case
Nice case so far Jomaba, I've got the same charger and was looking for some ideas. I sent you a pm yesterday, where in Connecticut do you live, I'm in Putnam wasn't sure how close you were to me.
Trex 700l Dominator. Microbeast
Futaba 10j Tx
Icharger 406Duo
chambers is offline        Reply With Quote Quick reply to this message
Old 06-03-2016, 10:59 PM   #2353 (permalink)
Pm sent
XL Protos 380
Old 06-11-2016, 01:19 PM   #2354 (permalink)
here is mine , a ridged case ,, I rushed the plexy top because we got warm weather here in pa earily so I had to put it together to fly,, in winter I will redo it the way I want it ,,, its got an icharger 308b and a meanwell 1200watt 24v ps to charge 2x 6s packs fast
ID:	656734   Click image for larger version
ID:	656735   Click image for larger version
ID:	656736   Click image for larger version
ID:	656737   Click image for larger version
going pro, one crash at a time
https://www.youtube.com/channel/UCZ6...VLThEA-j7cbvkQ
dnj1985 is offline        Reply With Quote Quick reply to this message
Old 06-17-2016, 09:55 PM   #2355 (permalink)
Originally Posted by nem3 View Post
Hey nem3 that's a great looking case. Well done dude.
Could you tell me where you sourced those balance boards from? I cannot seem to string the right search criteria together to find them on the net.
Matt
MadBird is offline        Reply With Quote Quick reply to this message
Old 06-17-2016, 10:52 PM   #2356 (permalink)
Thx MadBird. Was a pain to track them down, wanted to do a fused balance board, but they're all so huge/didn't have room for them. I got them from Pulse actually. http://www.pulsebattery.com/junsi-el...or-308duo.html
Logo 700 | Logo 550SX | Avant Mostro | Mikado VControl | CiQ
nem3 is offline        Reply With Quote Quick reply to this message
Old 06-18-2016, 05:06 AM   #2357 (permalink)
Thank you very much for the info nem3.
They will suit my purpose with less effort than the cheaper ones that have a different type of connector on them.
Old 06-26-2016, 02:33 AM   #2358 (permalink)
Nice Cases!
tf-zuid is offline        Reply With Quote Quick reply to this message
Old 06-26-2016, 04:12 PM   #2359 (permalink)
Default Here is miNE I just finish this one. For the bump set up
Bump case
Chris ryan is offline        Reply With Quote Quick reply to this message
Old 07-01-2016, 05:51 PM   #2360 (permalink)
While not exactly a 'case'.... check out Pawel's charger setup! Wow! Thought that one shouldn't hide on the charger forum.
https://www.helifreak.com/showpost.p...&postcount=310
