700 Class Electric Helicopters 700 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
08-17-2012, 02:26 PM | #1 (permalink) |
700 DFC tail issue
Not sure if anyone else has experienced this but I was doing the maiden hover and the tail shaft snapped where the tail rotor attaches. I was only a few feet off the ground when it happened so there is no other damage than what you see. It is a bummer because I am leaving on vacation tomorrow and as planning on taking this one with me.
08-17-2012, 05:44 PM | #2 (permalink) |
I think you have the same issue with the other member who posted here:
https://www.helifreak.com/showthread...423238&page=22 See post no. 215 by brwilkins. |
08-17-2012, 05:55 PM | #3 (permalink) |
Same exact problem I've had. I had 2 of them break on me. The first time the entire heli had to be rebuilt minus the electronics. The second time I was able to auto it down. So, I'm on my 3rd tail rotor shaft now. I hope this isn't a bad batch of steel or something.
I noticed on the two that snapped on me, the little plastic arms that connect the grips to the slider broke. I wasn't sure whether that was a result of the tail shaft breaking or the other way around, but to isolate them as being the potential problem, I ordered the tail upgrade kit from KDE that replaces those arms with metal ones. On my first to shafts, it took about 6 flights before the shaft broke, so we'll see how this one does with those new arms. You might want to contact somebody at Align or Assurance RC. I sent my first broken shaft to Assurance but haven't heard anything back from them yet. Please keep us posted on your progress with this. I'll do the same on the thread linked above.
TREX 800 DFC Pro, TREX 700 DFC v3, Goblin 700 3GX, TREX 550E v2 3GX, MCPX, MCPX-BL |
08-17-2012, 08:00 PM | #4 (permalink) |
Has anyone tried a 600 tail box on the 700? I think the last few mm milled from the shaft has weakened it to the point where it snaps, where the 600 is one continuous piece.
08-17-2012, 09:20 PM | #5 (permalink) |
I called Assurance today but they asked me to call back Monday and ask for Tim. I ordered a replacement rotor shaft today from HD. If you look you can see I am using the KDE upgrade. The problem now is that when the shaft broke it blew 2 of the bearings in those KDE arms. Not sure how easy it will be to find those. I will keep you posted how this turns out.
08-18-2012, 01:55 PM | #6 (permalink) | |
I put 3 flights on mine this morning since swapping out the linkage to the KDE. So far, so good. I'm nervous flying it though, just waiting for that shaft to snap off again. Hopefully third time's a charm.
08-19-2012, 05:29 AM | #7 (permalink) |
The tail ratio should be identical, there's no reduction in the rear TT gears so it's 1:1 .
If the load on the tail is purely from the tail grips transferring to the shaft it would make a lot of sense to use the 600 box without the weak shoulder. The gears are slightly smaller OD however the 600 tail spins faster. Both 600/700 use the same TT fitting and the 600 tail is lighter so CG should be better. I'll try to get photos of the 600 and 700 tail boxes later. |
08-19-2012, 07:48 PM | #8 (permalink) |
Tail
Uh ohh. I noticed the tail assembly is kinda loose like..so i better be careful..wilwl i be. Ok to sport fly or hover. ..just maidened hovered today went ok..but now iam worried?
Always thanks for the help much appreciated makes the hobby alot easier and enjoyablesince i began flying in dec.2011 |
08-19-2012, 08:01 PM | #9 (permalink) |
Tail
08-20-2012, 11:57 AM | #10 (permalink) |
tim was out at ircha all week and i think will be in the office on tues
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba |
08-20-2012, 09:22 PM | #11 (permalink) |
Maiden today ,,suddenly auto at 20 foot,,lol
So lovin the power and sport flyin,,all i iwant to do so far first flight,,and about three minutes in. Power cuts off nothing at about 20 ft. So glad i been practicing my auto rotations. Just baby ones at 5 feet. But now it paid off big time. So i iforgot to turn into wind. Cause panic set in slightly,,lol and landed it fine but grass Ground was uneven and tipped over ,, no damage ,, but we hovered it few minutes later to check it it was fine. Tail was fine etc ..maybe esc got hot. It was very hot sunny south florida 90 plus degrees..?? Hmm.
08-21-2012, 03:43 AM | #12 (permalink) |
Do you have the ESC logs to see what the temp was?
08-21-2012, 07:48 AM | #13 (permalink) |
did you set the motor timing a stock 5 and you should be at 12kpm
what is your head speed and what kind of packs are you running need more info
08-21-2012, 08:26 AM | #14 (permalink) |
Harvey. No i dont. How can i do that ? Thankyou
Don
08-21-2012, 08:28 AM | #15 (permalink) |
Dino. My my local guys at store set up program. I will ask him if he did thank you. Don
08-21-2012, 08:53 AM | #16 (permalink) |
If this is the CC ESC then you require the USB interface to download the logs and make changes to the advanced settings (governor etc...). I would suggest purchasing one as they are rather inexpensive compared to the ESC (like <$30, I got mine for $20).
IF the timing is not set appropriately this could increase the ESC temp and cause the shut down, this can be viewed in the log output as mentioned.
Carl Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544 |
08-21-2012, 09:57 AM | #17 (permalink) |
Dino. I know initially i set my pitch to 14 degrees and first hover did not like it then set to 13 ,, now i see book says 12 on the castle specs ,, so i will change that when i get home in two weeks.. And also purchase a log setup. I have specktrum telemetry but not installed.. I have the temp sensor and brushless rpm sensor. Should i use that ?
08-22-2012, 02:58 AM | #18 (permalink) |
I think you need to get the adapter and look at the logs to see what happened and then check (or do) the setup to see exactly what's happening. In my opinion you can hardly hope to use the CC on a demanding application (700 size heli) without a setup through the adapter (there are many little parameters which are important, and you can't access them through the beeping setup routine).
08-22-2012, 09:39 AM | #19 (permalink) |
for now keep things simple i will post a vid of the setup of my CC so you can see it
08-22-2012, 01:39 PM | #20 (permalink) |
Ok thanks much.. Appreciate it.. I plan to get a new charger also for mainly 6s batts etc.. But would love to charge and see what the batteries are doing ea cell etc. on the screen ..opposed to just charging on a paraboard unless you see everything on a screen from the ea battery etc. looking into it slowly.. Thanks.
