Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
10-11-2009, 06:40 PM | #41 (permalink) |
how long did you have to wait to get a confirmation for your order? I emailed stefan last thursday and havent even gotten something that he has received it. Is that normal?
10-12-2009, 07:05 AM | #42 (permalink) |
They made holidays for a week so it may take a little bit longer to get a confirmation...
-Klaus
SuziLAOS-DNHP-CenturioMax-Protos500-Logo400-500-600SE |
10-12-2009, 07:35 AM | #43 (permalink) |
Just got my confirmation, took less than 24hours. But I'm on the May list, pity ! Was hoping for next Jan.
10-12-2009, 09:05 AM | #44 (permalink) |
WOW. So cool, I never thought I'd get to see something like this!
10-12-2009, 02:32 PM | #45 (permalink) |
I probably have to cancel my order, so at least someone will get his kit earlier.
Are you sure on the motor John? From what I read the Scorpion is less efficient, but just as powerfull. I suspect that the power that it pulls more then the Pyro is transferred to heat instead of usable power. 2 of the Dutch pilots that where sponsored by Scorpion replaced their motors and controllers by Kontronik stuff.
Logo 800/Jeti DS16 |
10-12-2009, 04:57 PM | #46 (permalink) |
I'll vid showing fitting of both motors but inititially I'll use the Kontronik - lot of pinion grinding needed to fit the Scorpion
John |
10-12-2009, 09:59 PM | #47 (permalink) |
YES! I am on the list!
Hello Phil, I have put you onto my list. No deposite is necessary. Best regards Jan |
10-15-2009, 03:17 AM | #48 (permalink) |
John |
10-15-2009, 07:59 AM | #49 (permalink) |
John,
I recall seeing a post in another forum that you were hoping to go to Ihobby next weekend. Will you be attending? I am 1 1/2 hr drive from Chicago, but not sure which day I'm going yet. |
10-15-2009, 08:26 AM | #50 (permalink) | |
10-15-2009, 09:19 AM | #51 (permalink) |
Got one also :D
I got my Rigid on Monday.
I managed to finish it but given that it rained here the last 4 days I didn`t get to fly it I have the normal pyro and it`s shaft lenght is perfect for the counterbearging. So the normal shaft is perfect. The long shaft would be way to long for the Rigid. The pinion is EXTREMLY close to the motor. Can`t wait to fly it
Henseleit TD Rigid - Pyro 30-12, Jive 120HV, BLS 253, BLS 251, 710 TDR Blades, SLS 12S 4000 Logo 700 V-Bar - Scorpion 4035/500, Jive80HV, JR DS8717, S 9256, Radix 690, SLS 12S 4000 T-rex 600 ESP - Align 600M, CC ICE 100A ESC, DS610, GP780+DS650, Align 6S 5200 40C T-rex 450 PRO - 100% Stock and loving it |
10-15-2009, 09:25 AM | #52 (permalink) | |
10-15-2009, 04:25 PM | #53 (permalink) |
I ordered my Pyro from Readyheli and there was no option as to shaft length - the one supplied has ~20mm shaft with flat ground and fits the counter bearing perfectly.
THe build has got ahead of the build vids (each one takes ~ 4hrs to render at full frame size) so got to maiden her on Tuesday (in a TS!) and got a couple of flights in yesterday in much nicer weather !! http://www.youtube.com/watch?v=NWZwqLGtLdc
John |
10-15-2009, 05:28 PM | #54 (permalink) |
Congratulations on the maiden and more. And thank you for the taking the time to do the videos. Awesome heli.
10-15-2009, 09:19 PM | #55 (permalink) |
WOW!!! That seams just solid!!!....Rigid you might say!
But how does it compare to a "normal" heli??? I mean, is it really like going from a GM to a Ferrari? Can you really feel that much of a difference??? Tks for all the effort!!! WE ARE LOVING THIS!!!!
T-Rex 250 super combo T-Rex 450 PRO - I love this little guy! T-Rex 450 SE V2 - Sk360 in Airwolf fuselage T-Rex 500 Blinged to the extreme - Sk360 - Gy401/S9257 - 5045MGs T-Rex 600 LE - KDE everything, waiting on RL53 Raptor 50 eCCPM 140- QuickUk everything - G7703D/S9254 - S9252s - RedLine53 |
10-15-2009, 10:10 PM | #56 (permalink) |
WOW!! That was a nice set of flips at the end! Very clean design although I am curious to see how well the unconventional landing gear struts hold up. Doesn't look like you're lacking in power for Pitch!! Great build videos!
10-17-2009, 08:35 AM | #57 (permalink) |
Very very nice, seems to fly great.
10-19-2009, 08:14 PM | #58 (permalink) |
are the other build videos still coming?
10-20-2009, 04:26 PM | #59 (permalink) |
Sure are !! I'll post tail tonight and get on with final setup this week
John |
10-20-2009, 08:54 PM | #60 (permalink) |
Here we go - tail assembly - pretty straightforward - elegant, simple, tough design. The TT is a steel rod - pretty heavy - supported by three bearings ready mounted in an 920mm x 25mm ali boom.
The tail is a bit unusual in that the rotor blades go contrary to most common practice ie clockwise rather than anticlockwise viewed end-on. Got my tail gearbox upside down in some of the video so just make sure your tail spindle shaft pokes out the opposite side to the mounting holes for the vertical fin - I do mention this but couldn't be to breakdown the whole assembly and re-film In flight the tail quite sensitive to gyro gain - too little and it wags to much and it hunts - the sweet spot is very much HS sensitive and critical to within ~4% - I'll detail my flight settings later TDR6 - Tail assembly - wmv 82mb
John |
