Like Tree9Likes
Old 12-07-2011, 07:04 AM   #281 (permalink)
Originally Posted by gixxernoob View Post
Thanx for the replies! One more inquiry does anyone know the size of the heat shrink tube I need for the Trex500 main blades?
It depends on the chord of the blade. You can figure it out using a tailor's tape measure: measure all the way around the blade and divide that number by 2 to get the minimum flat width of the heat shrink. You'll want to go maybe a centimeter wider to allow for proper shrinkage.
HeliFreak Support
Graupner MZ-32
Old 12-08-2011, 06:41 AM   #282 (permalink)
Thanx! I will measure it then
I LIVE FOR THIS!
gixxernoob is offline        Reply With Quote Quick reply to this message
Old 12-08-2011, 07:05 AM   #283 (permalink)
Oops, that should have been "divide by 2", not multiply.
HeliFreak Support
Graupner MZ-32
Old 12-08-2011, 04:04 PM   #284 (permalink)
Even easier is to just measure the chord of the blade and add 1/4 inch, this will be the minimum flat dimension shrink tube that you need.
If the shrink tube you are looking at list its diameter then take the chord plus 1/4 and divide that by 1.571 and you will have the minimum diameter shrink tube you need.
(Blade chord + .25) ÷ 1.571 = min shrink tube diameter
Not quite as accurate as the Bums way with the tailors tape measure, but then not everyone has, or even knows what a tailors tape measure is.
Jeff Borowski
flyinfool is offline        Reply With Quote Quick reply to this message
Old 12-08-2011, 05:45 PM   #285 (permalink)
Among my wife's many hobbies is sewing, so I always have one around the house.
HeliFreak Support
Graupner MZ-32
Old 12-25-2011, 03:36 PM   #286 (permalink)
I Want to do a night heli and just ordered these,will they work ? the resistor calc gave me 68ohms so i got some of them in the cart to! (good prices)
http://www.westfloridacomponents.com...R1C-KHA-C.html
superinstaller is offline        Reply With Quote Quick reply to this message
Old 12-26-2011, 02:34 AM   #287 (permalink)
really ? for a 1S Lipo Cell ?
I'd say 100-120 ohms for a red LED.
red 2,1V 25mA 100-120 Ohm*
yellow 2,1V 25mA 100-120 Ohm*
green 3,2V 20mA 56 Ohm*
blue 3,3V 20mA 47 Ohm*
white 3,3V 20mA 47 Ohm*
*for 1S Lipo cell (3,6 – 4,2V)
pommesschranke is offline        Reply With Quote Quick reply to this message
Old 12-26-2011, 10:19 AM   #288 (permalink)
I went w/ 3.7v and 2.4v/20mah per the led specs and it gave me 68, Ill have to do a before test setup first, thats why i bought extra leds. I did my first night driveway hover lastnight w/ some white tail and fuse leds! way cooler than I thought!
Old 01-03-2012, 10:44 AM   #289 (permalink)
Do not do your calcs at 3.7V, you need to do the calcs at 4.2V.
4.2V is the voltage of a fully charged cell.
For the LED, do not use the max rated voltage, use the nominal voltage listed.
Jeff Borowski
Old 01-07-2012, 10:13 PM   #290 (permalink)
I don't know if this has been covered, but will these work with a fbl bird (given that you start out with fbl blades)?
Sowa is offline        Reply With Quote Quick reply to this message
Old 01-08-2012, 05:48 PM   #291 (permalink)
Yup
ChrisH is offline        Reply With Quote Quick reply to this message
Old 03-26-2012, 01:26 PM   #293 (permalink)
Hello all,
They say that the first step to getting help is admitting you have a problem. Well I have a problem! I have been bitten by the Night Flying bug pretty hard!! And now I have one of my Blade SR's equipped with a set of 245mm Carbon Night blades that were given to me and orange and blue glow wire to light the tail boom and canopy. I also ordered the LED's and glow wire from glowire.com to convert my Blade 450. I will post pics of my SR with lights on tonight. I am just waiting for calm weather here in Maryland so I can make my first night flight.
Shawn
B450 BNF Basic & Futaba 8UAS 2.4
2 Bld SR's 1 w/ MH Upgrades, 1 Nite Fly, MCPx V2 Walkera V100D08 rtf Composite-Arf 2.3m Extra 330l w/ DA85 H9 Tango w/ O.S. 55AX, Top Flite Flite Streak and Nobler Control Line, Fly Zone DR1 RTF. new owner of a DX8
R_C Addict is offline        Reply With Quote Quick reply to this message
Old 04-10-2012, 11:46 PM   #294 (permalink)
Just wired LiPo cells to OEM reject night blades. The LEDs work, but the internal LiPos are dead. Throw in some glow wire and UV-reactive tail blades, and this is what it looked like last night:
Hovered a full battery before this shot was taken. LiPo cells were attached with super glue rather than adhesive tape. They were further secured with heat shrink.
agenthex is offline        Reply With Quote Quick reply to this message
Old 04-22-2012, 12:59 PM   #295 (permalink)
is there a way hk led lights be use on 1 cell ????? i can use them on min 2 cell
mastmalang70 is offline        Reply With Quote Quick reply to this message
Old 04-22-2012, 03:13 PM   #296 (permalink)
You need at least 2 cells. At night, 2 cells are plenty, but if you want lights visible in daylight overcast, you'll need to go to 3 cells.
The only way you could run them off 1 cell would be to desolder the chip LEDs from the strip and solder them up with proper current limiting resistors (blue LEDs may not need a resistor).
HeliFreak Support
Graupner MZ-32
Old 05-13-2012, 01:54 PM   #297 (permalink)
Hey Guys,
I found this video on YouTube:
[ame]http://www.youtube.com/watch?v=5G5GmY97VaA[/ame]
I'd like to do this, but I don't know how. I've even asked the video poster and I haven't heard back from him. I've seen something similar on helicopter and quad blades, so I thought I'd post here to see what you guys can tell me.
Blackhawk Crew is offline        Reply With Quote Quick reply to this message
Old 05-13-2012, 03:00 PM   #298 (permalink)
http://www.rapidonline.com/Electroni...MD-LED-72-9776
can these type be used without resistors on 3.7 volts????????
Old 05-13-2012, 03:12 PM   #299 (permalink)
No. The Vf value is the voltage drop across the LED and it's only 2.0V typically, 2.5V max for the orange ones. All of the LEDs shown on that page will require a resistor.
HeliFreak Support
Graupner MZ-32
Old 05-14-2012, 09:53 AM   #300 (permalink)
ohh thanks, so ,vf is a forward voltage
i need one with 3.7 volts any link
thanks again
