500 Class Electric Helicopters 500 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
10-05-2009, 09:26 AM | #1 (permalink) |
500 and hitec 225mgs
Does anyone know if the hitec 225 mg servo will fit without any modification on the
t-rex 500? |
10-05-2009, 12:56 PM | #2 (permalink) |
They fit, but you have to use the spacers. So depending on your definition of modification... Yes or No . They are the same as the 5245MGs, just not digital. They work great, but there have been issues with the case top cracking on a crash, but there was a modification to the case that is supposed to help with that (any new ones you buy will be the new design). I didn't break the top case, but I ended up breaking all of the tabs on the cases which required a case replacement. I think this is due to the need of the spacers because they don't fit "just right". Luckily the cases are able to be bought and pretty cheap.
10-05-2009, 01:04 PM | #3 (permalink) |
so, where do I get these spacers that are needed for installation?
10-05-2009, 02:57 PM | #4 (permalink) |
They come in the kit with the 500. If you look in the manual that comes with the 500, there is a section that shows installing the 5245MGs, which shows the spacers in use. Use that section as the 225MGs are the same case as the 5245MGs.
10-05-2009, 03:50 PM | #5 (permalink) |
Thanks. I just purchased a 500 esp as a complete set minus the servos since I have
the 225 mgs already. This is my second heli. My first is the 450 sport which I absolutely love. I hope the 500 is just as good if not better than the 450. |
10-05-2009, 08:19 PM | #6 (permalink) |
I've had three crashes, 2 major and one minor ,Im using 225mg with the plastic arms supplied from align totally stock head, no probs with cracked servos.
From what i gather if you are using metal head, metal servo arms, something has to give in a crash and the servo case is the next weakest link this is not from experience, just my thoughts from reading other posts. |
10-05-2009, 08:46 PM | #7 (permalink) |
I use the HB version of this servo and they work great!
T-Rex 550E V2 / DS-610 / GY401 / 620 / CC ICE 100 T-Rex 600 ESP / DS-610 / GY401 / 9254 / CC ICE 100 T-Rex 700E F3C / DS-610 / GY520 / 650 /CC ICE 2 HV 120 |
