Go Back   HeliFreak > R/C Electronics Support > Thunder Tiger GT5 FBL System
Thunder Tiger GT5 FBL System Thunder Tiger GT5 Flybarless Electronics
Old 05-02-2013, 06:54 AM   #1 (permalink)
Default ACE GT5 Error Messages
Just wondering if someone has a list with error numbers and the meanings. My GT5 keeps coming up every once a while with those numbers - I believe not always the same - and it requires to power the unit off for an extended time before it boots up correctly again.
I've got three of those GT5s and this one is the only one with those weird errors during boot-up. Luckily it doesn't do that during flight - at least not yet
HeliDet is offline        Reply With Quote Quick reply to this message
Old 05-07-2013, 04:13 PM   #2 (permalink)
I haven't seen this one myself, but have you tried emailing or calling TT America?
Logo 800/Jeti DS16
Laurens is offline        Reply With Quote Quick reply to this message
Old 05-07-2013, 08:20 PM   #3 (permalink)
Haven't looked at that yet - since this GT5 is the old version and out of warranty I didn't want to send it in for repair anyway. Thought I get lucky posting here finding someone who could point me into the right direction...
Old 05-08-2013, 02:32 AM   #4 (permalink)
When i put GT5 on 450 heli and power it by Castle CCBEC 10amp. I dont know why but its usually get errors when power on (not exact your error) so i get CC BEC off and use ESC's BEC only, Since then it hasnt got any more error.
Trex 500ESP; Trex 450 pro; HDX v5
dophuc is offline        Reply With Quote Quick reply to this message
Old 05-08-2013, 05:47 AM   #5 (permalink)
That might be an idea, I have the CC 10A BEC on that heli (Trex 500) too. The other two GT5s that I got run with a CC BEC Pro with 20A on two FBL Gasser helis with no problem.
This one cycles through all inits during power-up and when it is supposed to come up with the status screen with bar graph it shows error numbers. Annoying is that a simple power recycle does not get rid of the failure, it has to sit for 5 minutes minimum (sometimes longer) without power.
Old 05-12-2013, 02:06 PM   #6 (permalink)
Today again, now with a new number 3158 - before was 3154. This happens after 7 flights with no issue. Battery #8 was obviously too much
Besides, just out of curiosity I emailed TT USA and their tech hasn't seen or can explain those errors. TT Germany so far doesn't answer emails. On their facebook page someone commented that they forwarded my question to someone - I assume some technical person. Will see next week I guess.
Old 05-14-2013, 05:44 AM   #7 (permalink)
Just to make this thread complete:
I got an answer from TT Germany. Don't know if he is one of the GT5 programmers but he said that failure was put in for quality control purposes and indicates that one sensor at a certain temperature is drifting more than wanted. He also said it would not fail the gyro during flight only cause some little drifting that the pilot might not even notice. With proof of purchase they offered to exchange it in Germany (I guess he didn't realize that I am in the US).
So that means that this failure is only caused by internal components and not the fault of a ESC/BEC or connected servos.
Old 05-16-2013, 02:14 AM   #8 (permalink)
Hi,
what you see is the gyro value coming from AD conversion. This must be between 1300 and 2500, otherwise you'll get this error message and the unit will not initialize, as it is assumed the gyro is defective.
As stated this can temporarily happen due to temperature drift or also maybe due to power supply issues.
Also the sensors vary a little bit in quality so maybe you did get one with a rather large offset which makes it somehow sensible to temperature. If you don't see any gyro drifting when the unit is operating correctly and if it is initializing correctly most of the time, I'd also say this is no issue.
regards from Germany
Stefan
Frenchdress is offline        Reply With Quote Quick reply to this message
Old 05-16-2013, 05:13 AM   #9 (permalink)
Originally Posted by Frenchdress View Post
Hi,
Stefan
Hi Stefan,
I was messaging with Joerg Henneke on Facebook concerning this. After he explained it to me I assumed that those are no failure numbers and rather sensor readings. Anyway TT US offered me to exchange it since it is still under warranty - so its on its way now. Their tech had never seen those errors but was kind enough to take my explanation that I got from Joerg as reason for exchange. Lets see what they say after they looked at it...
I could actually care less as I do not notice any extreme drifting but if it happens that error normally stays and doesn't clear easily which leaves my heli then most times disabled for that day.
Gruss
Detlef
Old 06-04-2013, 08:23 PM   #10 (permalink)
End of story, I've got for my 12 month old GT5 a brand new GT5.1 as warranty replacement from Thunder Tiger USA. Can't beat that service:
Old 06-06-2013, 08:41 PM   #11 (permalink)
I have one of the first gt5
And mine have frecuently the same messages that you said...
When that happens I turn the unit off for about one minute and then start working again..
This one goes better than the other one that you send back...
or is not noticiable in flight?
Lucasg is offline        Reply With Quote Quick reply to this message
Old 06-06-2013, 09:07 PM   #12 (permalink)
Hi Lucas, I never noticed any strong drifting during flight that I would have blamed the gyro for. Maybe with the new one I get to see how it really should have worked.
Mine was sometimes able to reset if you let it sit for a few minutes and sometimes it was not booting correct all day. Joerg from TT Germany said it is temperature related as well, so that might have been the key.
Since I got a free GT5.1 now I couldn't be more happy. Since I don't use a RX on my 500 I like that the new one got the failsafe setting. The only other difference I know is that it supports DSMX satellites (don't need that). Last weekend I got only 2 1/2 batteries through it till my swashplate started to come apart - so hopefully I get a chance this weekend. But honestly the first 2 fights I didn't notice any difference - flew the same way as the old version with identical settings.
Old 06-06-2013, 09:38 PM   #13 (permalink)
thaks a lot for the reply..
Keep enjoy this great unit
