Old 02-18-2014, 06:17 PM   #1 (permalink)
Default Motor Temp telemetry
Hey guys, I have telemetry with my Futaba Tx, and have just bought a temp sensor. Where is it best to place the sensor wire, and what temps should I be looking for?
I was thinking at the back of the cylinder just before the head, in a fin with Arctic Silver glue to hold it there.
Cheers, Rob.
TDRx2, Synergy N7/E7se/N5cTT, Align 450L/550/700e/700n, Gaui NX7/NX4, , Goblin 700/Black Nitro, Futaba 18MZ/ V-Control All on V-Bar's and S-Bus. #0095
rctintin is offline        Reply With Quote Quick reply to this message
Old 02-21-2014, 02:50 AM   #2 (permalink)
The best place for the sensor are at the bottom of the engine on the crankcase, away from the muffler. It must be positioned between the first and second silver fin on the crankcase form the heatsink (head). Temps are between 100-120 degrees celsuis and are only a guideline. Remember, ambient temps play a important roll. If you are used to fly at 110 degrees celcuis on a hot day, don't try to get that on a cold day.
A commen mistake people do, are to go leaner when it's cold and richer when it's hot. That happens when you only fly by temperature and that's wrong. Colder are richer and warmer ambient temps are leaner. The sound, performance and smoke of the engine are the keyfactors here. Temperature are only a rough guideline. Good luck.
Align T-Rex 600&700 Nitro Pro DFC
SAB Goblin 630 Competition
SAB Trioblin 500
Futaba 8FG Super
cmouton is offline        Reply With Quote Quick reply to this message
Old 02-21-2014, 03:02 AM   #3 (permalink)
Just to give you a idea, I had telemetry on my nitro birds in the beginning and were constantly checking the temps and tuned to stay between 100-120 degrees celcuis. Most of the time, the performance were not there.
After a few weeks I got fedup, and ignored the temp readings and tuned it according to sound and performance and a new world opened before me. The performance were excellent and my temps were running above 120 dergrees celcuis. Then I bought a ir tempgun and checked the temp on the ground and compared it to the telemetry temps. The telemetry were between 10-20 degrees hotter. On the ground the telemetry showed for example 110 degrees and the ir gun on the same spot(and time) showed 90 degrees.
I removed the telemetry tempsensors and never looked back. It's two years later and I have never cooked a engine.
Just for the record, It were Spektrum telemetry.
SAB Trioblin 500
Futaba 8FG Super
Old 02-21-2014, 05:29 AM   #4 (permalink)
I must say that I am finding it very useful for now, understand that it is only a reference to keep out of big trouble. For instance, I knew when my mixture is getting to a good point when the temperature rises and head speed also on telemetry is holding the highest speed well. I did go a bit far once ie found lean but that was useful as confirmation too.
Yes its a bit of comfort but understand its not 100% for tuning and important not to get distracted, nearly got me on that, take care not to look at the TX figures too often!!
I have my sensor on the OS105 blue head part, opposite side to the exhaust with some Arctic epoxy and RTV (Bathroom silicone) over the top of that.
LOGO 500SE & 600SE & 600SX
Synergy E7 -
N7 - N5C
zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzTDR + II
Alun
CyprusFlyer is offline        Reply With Quote Quick reply to this message
Old 02-21-2014, 02:25 PM   #5 (permalink)
Hey thanks guys.
For sure, its just for a guide, more so as an over temp alarm to protect the motor.
Having only flown electric 90's for the last 2+ years, I want to get the feel back on my awesome Synergy N7. Just don't want to cook the motor while getting it on song!!
Old 02-21-2014, 03:01 PM   #6 (permalink)
Know the feeling in the same boat, fighting my 105 still but a few irons in the fire!
Fantastic few flights so far when it goes well and hopefully get to the bottom of my carb problems soon. Alarms are a good last resort money saver I think.
Synergy E7 -
N7 - N5C
Alun
Old 02-23-2014, 05:39 PM   #7 (permalink)
12 flights in now and the 105 is purring, so I may not even bother to fit the temp sensor, but it would be an interesting thing to do seeing as I have it here now.
Old 07-29-2015, 11:02 PM   #8 (permalink)
Somebody can share pictures of the temp sensor installed in the motor?
Thanks!
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is online now        Reply With Quote Quick reply to this message
Old 08-23-2015, 06:44 PM   #9 (permalink)
I used to wrap the TM1000 probe around the cylinder fins above the exhaust header and below the head.
And I was getting different readings from the IR thermometer and the TM1000 - the TM1000 was always reading higher.
I recently installed a CSM CarbSmart and their recommended placement for the CarbSmart's thermo probe is on top of the and as close to the glowplug as possible.
Their documentations says this is the most reliable location to pick up the true temperature of the combustion chamber.
So, I am going to try that location for my TM1000 probe also.
I am also going to add a dab of Arctic Silver Thermal Adhesive to the probe (http://www.arcticsilver.com/ta.htm).
I have used for a while for for a couple of things on my nitro helis.
It says it is permanent, but you can detach your part if you need to.
Name:	2015-08-23 16.16.05.jpg
ID:	604449   Click image for larger version
Name:	2015-08-23 16.15.32.jpg
ID:	604450   Click image for larger version
Name:	2015-08-23 16.14.42.jpg
