Go Back   HeliFreak > R/C Helicopter Support > Minicopter Joker/Diabolo Helicopters
Minicopter Joker/Diabolo Helicopters Minicopter Joker/Diabolo Helicopters Discussions
Old 02-23-2014, 05:04 PM   #21 (permalink)
This is where Kosmik is your best friend. On 14S the 750 -56 with 20t is at the sweet spot of 2600HS at Kosmik preferred 80% throttle.
For speed you do not want to run governed, and as close to wide open as possible. The 750-50 with a 20t pinion puts you here:
Throttle 60%: 1754
Throttle 65%: 1901
Throttle 70%: 2047
Throttle 75%: 2193
Throttle 80%: 2339
Throttle 85%: 2485
Throttle 90%: 2632
Same calculator,
http://heli.dacsa.net/calcv3/Default.aspx
My point is why run goverened when you are just working the ESC harder.
WHAT main gear tooth count are you using for the Diabolo S?
Santiago.
Team Minicopter www.PeakAircraft.com
Team Kontronik
Scorpion Power Systems - Bavarian Demon
plankdriver is offline        Reply With Quote Quick reply to this message
Old 02-23-2014, 05:33 PM   #22 (permalink)
HF MR Support
Default Diabolo S setups
Santiago
If you want to go full throttle, by all means and the 17t will be perfect for the 2600HS.
On 12S I am using 20t which will give me 2600 at 100% throttle.
When switching to 14S, I just need to run on 80% to get the targeted HS of 2600 as well without having to change pinion.
Lynh
TommyBear is offline        Reply With Quote Quick reply to this message
Old 02-23-2014, 05:34 PM   #23 (permalink)
HF MR Support
Originally Posted by crash at 42 View Post
This is what I intend to do if I can get my hands on some 7S 4400. They are as rare as hen's teeth ATM.
Revolectric has 7s 4400mah
70c also available[/QUOTE]
Thanks buddy, have seen way too many cells dropped on Revo packs after 2-3 months of use, hence I am staying away from them.
Lynh
Old 02-23-2014, 05:41 PM   #24 (permalink)
Just soldered up my new Revo 60C packs yesterday - have been in the box for about a year but even so disappointed one cell dead and another at 2.7V so out of 4 7S packs only 2 usable !
John
Old 02-23-2014, 07:04 PM   #25 (permalink)
Guess i will have to watch mine, 2x's new 12s 4400 packs for my diablo. One of the 4 had a weak cell but after several charge discharges alls good. Thanks for the heads up
Diabolo S #6
Diabolo
TDR
N7
crash at 42 is offline        Reply With Quote Quick reply to this message
Old 02-23-2014, 08:05 PM   #26 (permalink)
What's the gear ratio for the S?
_____________________
JRAY is online now        Reply With Quote Quick reply to this message
Old 02-23-2014, 08:17 PM   #27 (permalink)
HF MR Support
Should be the same as the Diabolo I presumed as it uses the same gears.
Lynh
Old 02-23-2014, 09:06 PM   #28 (permalink)
The 1s stage is the same, but I AM NOT SURE if the metal gear is the same as the Diabolo.
Gerd,
Is the tooth count the same as the Diabolo?
thanks
Santiago
Team Kontronik
Old 02-25-2014, 12:36 AM   #29 (permalink)
Anyone knows for sure the tooth count on the S?
I have a Scorpion 4540-550 that I though was too high kv for 14S, but according to you guys it should be ok for about 80% governed speed with the Kosmik.
Is that correct?
Santiago
Team Kontronik
Old 02-25-2014, 02:55 AM   #30 (permalink)
The wheels are the same size as Diabolo.
Gerd is offline        Reply With Quote Quick reply to this message
Old 02-25-2014, 05:10 AM   #31 (permalink)
Is that correct?
Santiago
I have put in the 4535LE 550 kV Santiago and clocked 2300 yesterday at 80% throttle with a 19t pinion so certainly seems in the ball park!
John
Old 02-25-2014, 05:20 AM   #32 (permalink)
awaiting the video.....
William Blake Team Kontronik
TDR1, Banshee 850 # 22
Diabolo 700
wblombard is offline        Reply With Quote Quick reply to this message
Old 02-25-2014, 10:52 AM   #33 (permalink)
THANKS Gerd!
John, is that with 12 or 14S?
Santiago
Team Kontronik
Old 02-25-2014, 02:11 PM   #34 (permalink)
Running 14S. Mr Mel calc gives 2450, Log says 2300 FWIW
John
Old 02-25-2014, 02:31 PM   #35 (permalink)
THANKS Gerd!
X2!
Old 02-25-2014, 02:47 PM   #36 (permalink)
I have noticed with Mr Mel's that scorpion motors are always slower than predicted and pyro motors are always faster than predicted. Not sure how this works out.
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 02-25-2014, 04:23 PM   #37 (permalink)
Thats a good thing for pyro owners, not a scorp oil your bearings every 3 flights fan and then theres the Heat.
Diabolo S #6
Diabolo
TDR
N7
Old 02-25-2014, 04:41 PM   #38 (permalink)
HF MR Support
Pyro comp runs just as hot.
Just thought I let you know as it is a deviation from the cool running pyro reputation we are all used too.
Lynh
Old 02-25-2014, 06:24 PM   #39 (permalink)
Good to know what to expect my pyro 750 50 runs very cool.
Diabolo S #6
Diabolo
TDR
N7
Old 02-25-2014, 07:25 PM   #40 (permalink)
HF MR Support
Maybe it is just the black colour of the comp series that makes them run HOT.
Lynh
