Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 07-19-2016, 01:57 PM   #101 (permalink)
I do not want 550, it flies well on 520 and is easier to fly smack 3D (it is more agile). 550 also is more power requiring and I don't want to destroy my batteries it's only 2.9kg so it is light enough to keep it on 520. 520 are also cheaper
Keith - FrSky | OMP | KST | KC3D
Protos 800X Evo | OMP: M7, M4 MAX | M4*2 | M2 EVO*2 | M1 EVO | So Many Airplanes
KC3D LLC - Charge Cases, Starter Adapters, Heli Upgrades, and More
Number is online now        Reply With Quote Quick reply to this message
Old 07-19-2016, 04:05 PM   #102 (permalink)
Originally Posted by Mahmood View Post
Ahan thanks bro. I have exact same setup. Motor gets v hot too and esc gets warm only with fan. Weather is little hot too it could be the reason that motor becomes over heated. Btw i am using life 2s 6.6v to run fbl/servos. As my esc is without bec . This gives better CoG too as before with talon 90 built in bec and no life heli used to be little tail heavy.
If tou havent tried 550 blades , you will love it. More stable then 520's.
very hot doesn't mean overheated. Motors can take quite a bit of heat without ANY issues. Certainly they can get hot enough to cause lasting burns on your hands without taking any damage.
Old 07-19-2016, 08:54 PM   #103 (permalink)
ESC came down barely warm (-:
16KHz PWM, 15 Timing. Going from 32KHz to 16KHz seems to have made a huge difference.
T-REX 550 DFC | Schoolyard Fun! (2 min 48 sec)
Old 07-20-2016, 03:22 AM   #104 (permalink)
hmm well.. no complains if you are happy. yes on midland heli teh price difference is not much on 520's vs 550.
https://www.modelhelicopters.co.uk/h...0-dfc.html?p=3.
i am rebuilding my kit . will test again on 520's and see how it goes. but my HS is not anywhere near your HS at 80% flat. would be 90-95% on my tx.
Mahmood is offline        Reply With Quote Quick reply to this message
Old 07-20-2016, 03:24 AM   #105 (permalink)
thanks for the info. yes my motor do come extremely hot most of the time and esc warm. so may be bogging reason could be worn bearings causing more friction...who knows....!
Old 07-20-2016, 10:43 AM   #106 (permalink)
You may already have, but tell me your entire setup again. Gearing, electronics, FBL, etc.
Old 07-20-2016, 03:11 PM   #107 (permalink)
I have the opposite issue. My 730mx and 100a v3 esc come down barely warm on my 550, even on hot summer days. It just doesn't have as much power as I want. I'll have to check my pwm and timing..
My batteries though, they hate the 550. They come down quite warm
Trex 700L spirit pro / Trex 700n spirit pro/ Trex 550x spirit pro / Goblin Black Nitro 700
Thestructured is offline        Reply With Quote Quick reply to this message
Old 07-20-2016, 03:15 PM   #108 (permalink)
Set 16KHz and 15 Timing. No power problems on 550L and HW gov
Old 07-20-2016, 04:12 PM   #109 (permalink)
Well my align trex 550dfc is all stock except for the following:
hw esc 100a v3 HV (withot bec)
Seperate life 2s ...6.6v battery to power fbl/servos
K-bar fbl unit(using it with sat reciever)
Radio is JR 11x zero, DSMJ protocol
600mx 1220kv motor is stock
550mm bladesCF(also have 520)
Gearings not sure exact teeth but they are all stock
Motor is pinion is not stock. Its 12t.
Tail blades 90mm CF
Oh yes tail boom size is of 600size.
Thats it (y)!
Main battery 6s 5000mah (40c to 60c ...3 diff lipos).
Old 07-20-2016, 04:13 PM   #110 (permalink)
I just bought a new HW100a v3 for my 550. Can't wait to shed 100g when I swap out my CC120hv and WR Mini bec g2.
Protos Max Leggero 700, Logo 600SE, Blade 230s
DX9
flint723 is offline        Reply With Quote Quick reply to this message
Old 07-20-2016, 04:22 PM   #111 (permalink)
Tail blades 90mm CF
Thats it (y)!
Not sure why you got the HV version? The 6s version is way cheaper and has a built in BEC..
Old 07-20-2016, 04:25 PM   #112 (permalink)
Default Hobbywing platinum 100a v3 for trex 550. Anyone using it.
I'm watching this trade for couple days and I have a question I have HW 100 HV and Scorpio 4035 630 KV I want to ask what is the best timing and PWM according to my mother I need to set up the timing to 5° and Pwm to 8 kHz what you think?
shay3k3 is offline        Reply With Quote Quick reply to this message
Old 07-20-2016, 04:37 PM   #113 (permalink)
Most motors work great at 8KHz, and that's what Scorpion are said to do best at. Some motors work better at slightly higher, others lower. Usually PWM has the biggest effect on ESC temp, usually the motor isn't affected all that much (although theoretically, motors will run *slightly* more efficiently at higher PWM rates, whether or not it's true in practice who knows). Timing in my experience is where you'll see the biggest changes in motor temps.
Old 07-21-2016, 12:26 AM   #114 (permalink)
ESC came down barely warm... I was actually really surprised. Battery was quite toasty lol. Gonna puff these things before I even get to use them in my Protos.
T-REX 550 DFC | Football Field Fun (2 min 48 sec)
Align 600MX 1220Kv 112/13T
HobbyWing 100A V3
--PWM 16KHz
--Timing 15
--BEC 7.4v
--85% with HW internal gov (actual RPM unknown)
Flights 2:30 up to 3:00
Old 07-21-2016, 12:38 AM   #115 (permalink)
So I go with the Scorpion settings or to increase the pwm and timing for better esc Temps ?
Old 07-21-2016, 12:40 AM   #116 (permalink)
Go with recommended settings and see where they take you. If the ESC is hot, try running lower PWM. The motor is a scorch-pion so it'll probably get hot anyway (-:
Old 07-21-2016, 03:17 AM   #117 (permalink)
yes actually
i ordered hw 100a v3 esc with buil in bec. but i got a deal for havign this esc for the same price. so i can also use this esc for 12s setup. when i foudn out that it was without bec, i added a 2s 2200mah life battery to it.
Old 07-21-2016, 03:24 AM   #118 (permalink)
Trex 550 DFC | Football Field Fun - YouTube
HobbyWing 100A V3
--PWM 16KHz
--Timing 15
--BEC 7.4v
Liked!!
i think main difference in my setup now is life 2s battery(weight). i tthink the throttle % on tx varies from tx to tx because my tx 85% flat throttle gives 30% less rpms then your 85%.
by the way dont use heli option gimbal swash. one of teh balls came out of mine during flight causing $130+ crash. and heli option wont reply a single word about it lol on their fb page.
Old 08-08-2016, 03:40 PM   #119 (permalink)
Hey bro can tou pls share you 550dfc flying weight as i think mine could be possibly heavy with a life battery , so as to cause severe motor bogging during rainbows....will check mine and revert tomm .
Old 08-08-2016, 06:24 PM   #120 (permalink)
I'm not Keith, but I run a 2000mah life pack on my 550v2. I don't see any bogging on tictocs with 550mm blades.
George - Goblin700(iKon2), Trex550e(iKon), Oxy3(microiKon), Taranis
gstoneberg is offline        Reply With Quote Quick reply to this message
