Old 08-27-2014, 09:51 AM   #1 (permalink)
Default 690 SX - Extra Parts Tail Rotor Build
Ok helping my son build his 690 SX, and we built the tail rotor last night. When finished there were two round washer like shims (10mm diameter) and two black round plastic sleeves left over. I looked over the manual again and again, and cannot find where these parts go. Anybody else have these left over? Totally frustrated!
Avant Mostro 700E
Mikado Logo 690SX
T-Rex 700N LE DFC Conversion
T-Rex 600N
DaleT is offline        Reply With Quote Quick reply to this message
Old 08-27-2014, 10:18 AM   #2 (permalink)
The washer-like pieces sound like the shims for the tail rotor shaft. You might not need them. With the tail assembly all mounted up and tightened, does your tail shaft slide back and forth left to right at all? If not, throw those shims in your spare parts box. If it does, tear the tail down and put a shim between the flange bearing and shaft spacer on the side which has the bigger gap between the belt and the lip on the tail pulley. Still slop? Add another shim... Etc...
A pic would help, but if they're super thin and approx 10mm outside diameter, I'd bet the inside diameter is the same as the tail shaft diameter, and those are your shims. They might have been excluded from the manual as they're a "only use if needed" item. My 480 came with them but didn't need them. My 600 uses one on the left side.
As for the black round plastic sleeves, are they spacers for between the tail pulley and flange bearing? I think those would be metal, the plastic ones are usually for centering the tensioner (anti-static) pulley/bearing. Again, pics would help
Hope that helps
corrosionate is offline        Reply With Quote Quick reply to this message
Old 08-27-2014, 10:57 AM   #3 (permalink)
Hope that helps
Thought maybe that what the shims were for but wasn't sure. Here is a pic of the parts leftover.
https://www.helifreak.com/attachment...1&d=1409154888
Avant Mostro 700E
Mikado Logo 690SX
T-Rex 600N
Old 08-27-2014, 11:19 AM   #4 (permalink)
Hhmmmmm.... Those other ones look like they would fit on the tail shaft as spacers... Between the flange bearings you shouldn't be able to see any of the tail shaft... If you can see the shaft, the spacers should fill in the space. If you've already filled in all that space then maybe these are extras or something...
I'm afraid that's all I can help, they may be a part that is exclusive to the 690sx, and I haven't built one of those. My 600 has similar spacers but they're aluminum.
Old 08-27-2014, 11:59 AM   #5 (permalink)
The shims (metal) are for taking the play out of the tail shaft (side to side).
The black spacers (if they are the 5x8x3.7) are for the tail output shaft assembly. One goes on the side of the pulley that is flat. I appears they may have put extras in your kit?
Ryan
Mikado USA, Kontronik, Opti-Power, MKS Servos, VTX
RyanW is offline        Reply With Quote Quick reply to this message
Old 08-27-2014, 12:10 PM   #6 (permalink)
The pulley doesn't look to be a two part item. On other models the shims would go inside the pulley. Therefore I think the metal shims/washers go between the two belt idler bearings.
See page four of the manual.
I agree the plastic spacer does go on the short end of the output shaft between the pulley and bearing.
Andy from Sandy is offline        Reply With Quote Quick reply to this message
Old 08-27-2014, 01:54 PM   #7 (permalink)
Both the shims and plastic spacers inner diameters match the output shaft diameter. If the shims are for taking out play in the output tail shaft, then they are not needed because there is no play between the two flange bearings. As for the plastic spacers, there is no room for them on the shaft. Between the flange bearings there is the pulley and one metal spacer, with no room for anything else.
https://www.helifreak.com/attachment...1&d=1409165621
Avant Mostro 700E
Mikado Logo 690SX
T-Rex 600N
Old 08-27-2014, 03:38 PM   #8 (permalink)
I see the 690 tail assembly is definitely different than from other models. I guess I don't know about the plastic ones...
Old 08-27-2014, 03:51 PM   #9 (permalink)
Dale it looks like you got the tail correct, I had those pieces left also, as long as you do not have any play side to side you should be fine. Chris
chc35 is offline        Reply With Quote Quick reply to this message
Old 08-27-2014, 06:59 PM   #10 (permalink)
Thanks Chris! I was fixing to call you on this one.
Avant Mostro 700E
Mikado Logo 690SX
T-Rex 600N
Old 08-27-2014, 07:08 PM   #11 (permalink)
I too am in the process of building this bird and had the same pieces left over, mine also came with three 3x5x0.5 washers that go between the belt guide bearings, thing is the manual calls for only 2.
tjmarti is offline        Reply With Quote Quick reply to this message
Old 08-28-2014, 06:03 AM   #12 (permalink)
I also had those parts left over after the build. I actually had several other parts left as well. I figure because Mikado uses their parts on several models some extra hardware is included for when they are used on other models than the 690. It is confusing however.
Chanq is offline        Reply With Quote Quick reply to this message
Old 08-28-2014, 12:33 PM   #13 (permalink)
I think you hit the nail right on the head with this. Just my opinion though! :-)
Team Mikado USA!!!
Team Scorpion!
Logo 600SX - Scorpion 4035-560, 10s 4400 packs
Logo 690SX - Stock Scorpion motor, 12s 4500 packs
sgrim80 is offline        Reply With Quote Quick reply to this message
Old 12-14-2014, 04:08 PM   #14 (permalink)
So I just got finished with the tail build as well. Also had these extra parts. My issues has to do with the tail slider lever, the one tha the tail rod connects too. It is really tight on the metal piece it screws too even with the tiny washer. Any of you guys also experience this ?
ToddM is offline        Reply With Quote Quick reply to this message
Old 12-14-2014, 06:44 PM   #15 (permalink)
I didn't
Logo 480 XXtreme, Logo 550SX, Logo 690SX, Logo 800 XXtreme, TDR, Minicopter Diabolo 550, Minicopter Triabolo, Goblin 500, Goblin 700, Goblin 770, KDS Agile 5.5, Voodoo 600, Voodoo 400, HD Cell 500, Thunder Tiger E700
taosgraveyard is offline        Reply With Quote Quick reply to this message
Old 12-14-2014, 06:58 PM   #16 (permalink)
Hello Todd,
Make sure the bearings are fully seated in the bell crank. Next step is to barely tighten the bolt going through the assembly. If you crank down, you can crush the bearings and they will never be smooth again. Tighten just to the point there is no rocking action on the bellcrank and it still rotates smoothly. Then let the loctite do its thing.
Ryan
Old 12-14-2014, 10:18 PM   #17 (permalink)
Thanks Ryan. I reattached the bellcrank, making sure the bearings were seated properly and the washer was inserted . Barely cranked down to fully tighten and all is like butter now.
