Old 01-21-2015, 03:26 AM   #1 (permalink)
Smile Scorpion HK3026-1400kv rewind
Picked up this motor in a trade, Perfect condition.
once the heat shrink came off I saw that a few wires were broken and the heatshrink did
fail between 2 leads. there was some fiberglass tubing but way up outside the motor.
bad job scorpion
Factory specs:
No. of Stator Arms ................................................ 12
No. of Magnet Poles .............................................. 10
Motor Wind ............................................ 6 Turn Delta
Motor Wire ..................... 24-Strand 0.25mm (30 AWG)
Motor Kv ........................................... 1400 RPM / Volt
No-Load Current (Io) ................... 3.86 Amps @ 6 volts
Motor Resistance (Rm) ............................. 0.010 Ohms
Max Continuous Current ............................... 80 Amps
the stator came off really easy with the freeze method, I counted 3+4
so really in scorpions terms it was 7 turn delta.
Im shooting for d-lrk y 1000ish kv, but I will test wind first. also the coating is perfect, but if it gets in the way of wire size vs turns I will opt to remove it.
fusionsx00 is offline        Reply With Quote Quick reply to this message
Old 01-21-2015, 06:20 AM   #2 (permalink)
Very nice! Is it just me or do those magnets look crazy thin. Are then recessed into the can?
SAB Goblin 600, Logo 480Xxtreme, Gaui X3, Compass 6HVU, Atom 500
Jmann841 is offline        Reply With Quote Quick reply to this message
Old 01-21-2015, 06:21 AM   #3 (permalink)
A turn is a turn! How does Scorpion count turns? I ran into the same thing on my 4020-1350. Its supposed to be 5 turns but turns out it was six.
If its fixed don't break it!
Bladecpnitro is offline        Reply With Quote Quick reply to this message
Old 01-21-2015, 09:36 AM   #4 (permalink)
Originally Posted by Bladecpnitro View Post
A turn is a turn! How does Scorpion count turns? I ran into the same think on my 4020-1350. Its supposed to be 5 turns but turns out it was six.
Scorpion counts winds for 2 teeth, so if you see 12 turn on scorpion specs
It could mean 6t on one tooth and 6t on the other. Or 5+7 or 4+8.
I count per single tooth,
Yeah scorpion is special
Old 01-22-2015, 05:12 AM   #5 (permalink)
This is a 500 motor correct? What size wire do you plan to test wind with?
Do you plan on run this in one of your birds?
Old 01-22-2015, 04:47 PM   #6 (permalink)
Yeah 500 size(425mm blades), i will fit max wire size
I have 20awg to 14awg to try, my guess is 17awg
It may go in a goblin 380, not 100% sure.
Old 01-25-2015, 03:39 AM   #7 (permalink)
first test wind 6t 2P-DLRK Y = 956kv
going to try 6+7 to get to 880kv
Old 01-25-2015, 06:38 AM   #8 (permalink)
Do you do the 1000V meg test on your winds man?
Old 01-25-2015, 11:25 AM   #9 (permalink)
Yeah, but only on final winds, just before i reassemble. With test winds I do a quick check with my fluke for shorts.
Ebay has the insulation testers for 50$ now
Old 01-25-2015, 12:28 PM   #10 (permalink)
There is a thin positioning ring for the magnets (if you look closely) that is obscuring the magnet thickness.
ahahn is offline        Reply With Quote Quick reply to this message
Old 01-25-2015, 03:12 PM   #11 (permalink)
I did my quantum rewind while out of home and didn't have the megger. I managed to get a fluke so i tested with it, only to find out i have a short when it met the megger back home...
2 X X7 | Scorpion 4525 Ultimate 4+6T YY / Xnove 4530 525 | scorpion Tribunus 200II ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | SK540 / Brain2 | Mks
omerco is offline        Reply With Quote Quick reply to this message
Old 01-25-2015, 04:43 PM   #12 (permalink)
Were you able to repair the short or did you have to pull the wire out of that phase?
Old 01-26-2015, 01:35 PM   #13 (permalink)
the short was on the corner between the wire and the stator - no repairing could be done there. pulled it out, added paper and re-coiled it. motor is kicking hard...
Old 01-30-2015, 04:49 PM   #14 (permalink)
Stator powedcoat removed, i also chamfer the edges. The plates edges are razor sharp so doing the chamfer is a lot of help to prevent any damage when winding. I will use 20mil nomex for top plates and 15mil for slots.
Next i will make the top plates and figure out the best (thickest) wire size
Old 02-05-2015, 07:44 PM   #15 (permalink)
Just finished the wind, passed inital 1000v test.
Nomex plates
First 2 teeth wound with 17awg, it will be 6t(5+1) 6t(4+2)
Old 02-05-2015, 08:55 PM   #16 (permalink)
How did you strip the stator?
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is offline        Reply With Quote Quick reply to this message
Old 02-05-2015, 10:44 PM   #17 (permalink)
This one i had my freind do a light sandblast, then 200 degree denatured alcohol in a cleaning tank for 20 minutes at his shop. He did 6 stators for me for a 12 pack
Old 02-06-2015, 12:39 AM   #18 (permalink)
motor turned out great, 988kv on yge lv90 at 12khz 6s
i am going to finish sealing up the stator , and permanatly attaching the hub. Really tempted to trying this on my x5 with 425mm blades. its the same motor I ran on my x4 a long time ago.
Old 02-06-2015, 05:14 PM   #19 (permalink)
The motor is ready for flight test. The windings came out to 58 grams with 17awg almost twice the weight of the stock wind. 18 awg would of looked a lot nicer but i really wanted to go with the largest wire possible.
Old 02-07-2015, 05:09 AM   #20 (permalink)
Looks great man~! Do you test it without fiberglass insulating the wires and adding bullet connectors?
