Reflex Flight Sim Reflex Simulator Talk |
05-12-2004, 01:36 PM | #1 (permalink) |
Registered User
Any XTR and 9Z Users?
Hi Everyone,
How do you go about setting up your 9Z with Reflex. I hve tried it from a reset model, I have tried it from a program from my Raptors, etc. I have set the ATV's at 100%. I can't get this ting to do more than jump around like mad. What do you have in your channel assignment screet? Thanks in advance,
William James Crazy wife still trying to kill me. |
05-13-2004, 05:58 AM | #2 (permalink) |
Jump around like mad, sounds like pcm modulation.
Press F8 (hope I remember right) for the channel window, it should show whether the channels are right. On my 9CHP I just set one memory to the plank mode and ppm, works fine. You don't need any mixes with Reflex... Andi |
06-07-2004, 10:34 PM | #3 (permalink) |
Will, did you get this working with 9Z yet? I have reflex XTR on order but MRC still hasn't got the two futaba connectors (square and round) in stock... I'll eventually want to use my 9Z and 9C. I'm curious to know how you made out.
06-07-2004, 11:43 PM | #4 (permalink) |
Registered User
No I have not.
It will fly now, but still cannot get the correct hold switch to work, or the idle-up switch to work right. Reflex ignores all but one condition on the idleups.
06-08-2004, 07:14 AM | #5 (permalink) |
Would you say it's still worth it even though it has this shortcoming?
06-08-2004, 07:26 AM | #6 (permalink) |
Registered User
I would say that it can probably be done. I have devoted a few hours to the project and so far have been unsuccessful. I also have G2 which is plug and play which is all I seem to have time for.
I have actually owned Reflex before, sold it, now bought it again to try XTR. Would I buy it again, most likely not. The physics and graphics are great, but getting it to work with my radios has been discouraging. I tried to get it the first version to work with my 9z as well, and could not get it right either. I offered to trade it to Shannon and let him try it before I sold it and I guess he could not get it right either because he said after testing he was not interested. If they would make it easier to setup with a 9Z, or provide a good tutorial, it would be a lot easier to use with 9Z. I have not given up yet, but I don't have that many more hours to devote to getting it to work. Look for Reflex and the XTR upgrade for sale here soon.
06-08-2004, 07:55 AM | #7 (permalink) |
I had seen Shannon's post about trying to get it working and because of that I asked MRC specifically if it worked fully with the 9Z. Tim @ MRC said yes. I should be receiving it soon. When I do and if I'm successful, I'll do what I can to help get yours working too. I have to wait until I can get my hands on the right connector though. Right now they only have JR connectors and my JR radio is toast
06-08-2004, 09:33 AM | #8 (permalink) |
Registered User
Thanks Dan. It could very well be I'm stupid or something like that, but I can setup a heli on this radio without a problem, and seems like I should be able to do the sim as well.
06-08-2004, 12:22 PM | #9 (permalink) |
You're not the first person to complain about reflex setup. I've researched several forums and found several instances of ppl struggling with it... For what I paid, I hope MRC and/or Wolfgang can hold my hand through the process. I hope my expectations are set right.
06-13-2004, 10:10 PM | #10 (permalink) |
Registered User
ANybody know Wolfgangs email address?
06-14-2004, 08:55 PM | #11 (permalink) |
I emailed him about a week ago at support@reflex-sim.de and haven't received a reply as of yet. Will, I've been using reflex for a couple days now with a JR radio. By Wednesday I'll have the connectors for my 9C and 9Z. The JR setup went extremely smooth. I went from having a cd in my hand to flying in about 25 minutes. The key was viewing the channel setup at the same time as setting the channels. I'll post back when I get my 9Z adapter and have a chance to attempt the setup.
06-14-2004, 08:59 PM | #12 (permalink) |
Registered User
Sweet!! Thank you Dan!!
06-18-2004, 07:01 AM | #13 (permalink) |
Share your results Dan. Inquiring minds woud like to know. I have 9CHP but hav enot ever tried reflex. I emailed but got no reply to the support at the reflex website month ago.
06-19-2004, 10:27 AM | #14 (permalink) |
I recieved my square futaba connector and set up Reflex with my 9C yesterday. It works great. It took me about 20 mins to figure out that I had to calibrate the zero positions first, which is stated clearly in the help - if I had read it beforehand. Anyway, rest assured, the 9C works fine. Once I corrected my mistake, I had it going in less than 5 mins.
I scribbled down my method of setup to eventually adapt for use w/the 9Z when my cable comes in. MRC Altech has my round futaba cable on backorder. Here is the process that I used for the 9C. I imagine it would work with any 8 channel radio: 9C radio setup:
Reflex setup:
The Channel display should read slightly fluctuating values, at or near 0 (see attached picture). Follow the instructions on the Assign Channels window at the bottom. Once it's complete and has auto-detected the channel assignments from your input, you'll have an opportunity to make any manual changes (e.g. if one of your radio swiches wasn't set to your liking). Reassign the switch in the radio, then make the changes in the reflex Assign Channels window. Here's my scenario to illustrate: My newly created Reflex model in my 9C had channel 7 tied to the wrong switch, so I set switch G in the AUX-CH Select menu of my 9C for throttle hold on channel 7. Then, in Reflex, I set channel 7 to the 'Autorotation' reflex function of the Assign Channels window, making sure that it wasn't reversed. - Reverse is indicated by the plus/minus ( ' - ' / ' + ' ) toggle button to the right of the channel buttons for each function. - Adjust the end points in your radio to get full servo travel and thus a linear setup. Otherwise, your heli will be either too responsive or not enough. You view full servo travel by looking at the Channel Display and simultaneously adjust your end points, just like real setup. Some posts I've seen appear to suggest compensating for this by putting in expo... set the end points correctly first, then use expo if needed. Remember, Reflex is much more of a "simulator" than other sims. Therefore, you have much more power to tweak your setup than you may be accustomed to. This can be good and bad: It's only bad if you want quick setup and your main goal is not realism (e.g. just want to learn basic orientation); it's very good if you want to simulate the real thing. That's it. I hope this helps someone. For quick start guide, use this local help file. |
06-21-2004, 04:45 AM | #15 (permalink) |
Registered User
Awesome, Thank you!!
08-11-2004, 05:16 PM | #16 (permalink) |
9z works well with realflex
guys im using my 9z with xtr and it works great i downloaded a fury from davehour on rr all switches to include cut and hold work as they should dont forget to go into turn on soft key while turning on radio set to ppm once thats done turn off radio go into program once the screen come up plug in radio hit f4 your on your way
08-12-2004, 07:54 AM | #17 (permalink) |
I'm still waiting for my 9Z adapter cable. I doubt it will ever come - it's been two months.
08-22-2004, 03:42 PM | #18 (permalink) |
9Z
I purchased the Reflex at IRCHA Jamboree. We camped there this year and I could not wait to get back to the camper and install it on my laptop.
At first I got a little frustrated, and it took me about 30 minutes or so to figure out how to get it working. Now it works GREAT! I also have G2, but I have to say I like Reflex better. The help file includes a TON of information. The main problem I had was that you have to switch the radio from PPM to PCM...it will not recognize the radio in PPM mode. Then I had to go in and assign the channels properly. Once that was done it works great. The only drawback is I have to change to PCM before I plug it in and to take effect you must turn the radio off, then back on. I guess the other drawback is it does draw your tx battery down some, but I prefer flying with my real tx instead of the false tx that comes with G2. If I can help feel free to email: terryrowell@charter.net |
09-03-2004, 09:59 PM | #19 (permalink) |
Ok im confused terry says pcm and dan says ppm inquiring minds want to know. My best guess is ppm Tom
