Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 12-26-2007, 05:35 PM   #1 (permalink)
Default Help me, too much confused...1st post..
Hi guys, good job for this forum about hurricane that help me for some troubles
This is my first post! i want to ask a thing maybe wrote yet but i would be more...(cant remember the right word , lol) :
I just got hurricane550 CF with gaui 1100 and 75amp ESC and 13 pinion .
which is the right lipo to go with 13pinion for hovering and a bit more?
Have to change to 14 or 15 or 16 ?
i have to pack 3s2200mah 25C and im planning to buy some others size, im confused about this. thank you and sorry if this post is like some others.
PS : happy new year from Italy!!! too early to say? :wink:
aro75 is offline        Reply With Quote Quick reply to this message
Old 12-26-2007, 06:06 PM   #2 (permalink)
Stay with the 13 tooth pinion.
Get the highest capacity lipos you can find that weigh no more then 300 grams for each of the 3S packs. Model get a bit heavy once you have more 600 grams of batteries up front.
3200 mah to 42500 mah should fit into this weight range.
Kepler is offline        Reply With Quote Quick reply to this message
Old 12-26-2007, 06:27 PM   #3 (permalink)
thank you!
But can i take a 5s 4000 for example or 2 x 3s with 13 pinion? 14 pinion not good ?
Old 12-27-2007, 07:12 AM   #4 (permalink)
Read this.
https://www.helifreak.com/showthread.php?t=54540
Use 13T pinion for longer flight time. More T on the pinion brings you more HS RPM, thus less fligth time.
Phoinix is offline        Reply With Quote Quick reply to this message
Old 12-27-2007, 09:29 AM   #5 (permalink)
http://www.ezfly.se/hscalc.htm
here is a good HS calculator just for the 550....you can figure out headspeeds with diferent pinions.
It only goes down to 14T...
mjdee14 is offline        Reply With Quote Quick reply to this message
Old 12-27-2007, 05:14 PM   #6 (permalink)
thank you.
for example : 5s 4000mah 15C with 13T is good for long time flying but which flying??
i need hovering and just first figure.im noob!!
Old 12-27-2007, 09:15 PM   #7 (permalink)
13 tooth on 5S might be a bit low on the head speed. I think 14 tooth would be low as you would want to go.
Old 12-28-2007, 03:18 AM   #8 (permalink)
I'm running 13T, 5S, Z30 and i can get 2100 rpm on 100%. I run it at 1630 RPM for longer flight time. Oh, yeah, and i'm running 550 mm blades. For orientation, hurricane will hover at as low as 1000 RPM, if you wanna talk about low rpm. I can do backflips, loops, rolls and i have no problem with manouvering. That is much more than a noob can handle.
I had problems reaching the same manouverability with my 450SE at 100% RPM
