Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
06-15-2007, 01:43 AM | #101 (permalink) |
Hey Bob great vids and thanks for the manual scan
unfortunately the second part's link doesn't seem to be working this is the link thats not working http://video.helifreak.com/?subpath=...manual_low.zip cheers bob let us know if you have chance to fix it thanks ben |
06-15-2007, 02:04 AM | #102 (permalink) |
Team Taco VP
Well I dont know what happend to the file but I cant find it anymore nor does it seem I have it locally to upload again.
Sorry but I removed the link so others would not have trouble too. Thanks for pointing out the broken link. Bob
"Don't Taco My Pack Dude!" NEW Video Link -> Safety Video #1 Video Link -> CAUTION using powerful tools! Video Link -> How to CRASH TWICE in one flight! Video Link -> Don't Taco! |
07-01-2007, 02:14 PM | #103 (permalink) |
12 or 13
bob
which cog works better the 12 teeth or the 13 teeth for all round flying and battery fly time... i am just building a v2 as we are speedmailing |
07-06-2007, 01:16 PM | #104 (permalink) | |
///and hoping for a bit of help and clarity. Has anyone replaced the V2 feathering shaft yet? The Feathering Shaft HS1251 part has aluminum collars that are Φ5xΦ3x1.5mm. But on the stock V2, and on the main rotor blade grips, the aluminum collars are as per the stock V2 which are Φ4xΦ5.6x1.5mm. So is the part "Feathering Shaft HS1251" compatible with the V2 head? was there a design change on the feathering shaft on the V2? do i need to change any other parts or it will work with the New V2 head as advertised? Thanks in advance and regards Rob |
07-07-2007, 11:06 AM | #105 (permalink) |
Team Taco VP
Just checking tyhe Align web site the spacers with the replacemnt feathering shaft says OD 5mm, ID 3mm, and thckness 1.5mm
http://www.align.com.tw/shop/product...oducts_id=1579 This HAS to be a missprint!!! WHY because the OD of the feathuring shaft is 4mm. the old V1 was 3mm. I think they are quoting the V1 spacers in the web page and parts bag!!! 3mm ID WONT WORK on a 4mm OD spindle! So I bet if you took the part out of the bag an measured the spacer it would be more like ID 4mm, OD 5.6mm and 1.5 thickness. Bob
07-10-2007, 04:18 PM | #106 (permalink) |
Help me Mr. Wizard.......
I'm been screwed so many times by my local hobby shop that I just don't trust anything they say anymore. CAN SOMEONE TELL ME WHAT FUTABA SERVO SETUP TO USE FOR A T-REX 450SE V2???????????? IT'S USING A BL35X (6VOLT) ESC. I will greatly appreciate any help... Thanks Rik |
07-11-2007, 08:02 AM | #107 (permalink) | |
Thanks Bob... Really appreciate the help. Regards |
08-08-2007, 08:46 AM | #108 (permalink) |
CooL! that looks awesome!
Bob ... when are the build vids coming? |
08-25-2007, 01:04 PM | #109 (permalink) |
I just received my 450S CF in the mail today,... Do you believe i can use these same video's to assist in the build of the 450S CF?
I'm not totally sure of all the differences between the two helicopters so i thought i would ask and hopefully someone is kind enough to answer for me please. Thank you. CNH |
08-26-2007, 02:00 AM | #110 (permalink) |
hi all
just wondering, what is the main difference (other than color) between the 450 SE V2 black and the 450 SE V2 siler? Thanks alot! |
08-26-2007, 07:25 AM | #111 (permalink) |
There isn't. It's just the color of frames and fins.
08-26-2007, 04:34 PM | #112 (permalink) |
Awsome thanks alot, can't wait till tuesday!!!
12-16-2007, 11:16 AM | #113 (permalink) |
Hi, I see you use the fs61bb servos in combination with the esc bec BL35x.
The servos use 4.8volts, the esc gives 6volts. Doesnt this give any problem? Geerten Roos Holland |
12-16-2007, 12:31 PM | #114 (permalink) |
Team Taco VP
fs61bb servos? NO I DONT! I use Hitec 65MG servos and they are rated for 6V.....
I have NO CLUE what fs61bb servos are? Bob
12-17-2007, 03:09 AM | #115 (permalink) |
this message was ment for Ave_eme, see message #111
On the photo you can see the servo's. |
12-17-2007, 08:58 AM | #116 (permalink) |
Hey Finless,
How does the align se v2 compare to the copterx se v2? Barry |
12-17-2007, 07:31 PM | #117 (permalink) |
Team Taco VP
No clue.... I have never even seen a CopterX.......
Bob
12-20-2007, 01:03 PM | #119 (permalink) |
I would agree that the CopterX vs. the TRex....in that they do APPEAR to be identical except for the main gear (not the new style) and the tail hub, silver not black, but could be designed the same as the new align black hub..hard to say. But my guess is that there would be many more differences that do not meet the eye that would make the CopterX even less exactly the same.
