Old 12-08-2013, 01:56 PM   #1 (permalink)
Default My 700 Pro DFC build questions
So far I only have one question but I'm sure I'll have more as I finish the build.
Are the bullets that come with the Castle 120HV esc supposed to fit the bullets on the 800MX motor? I haven't soldered them on the esc yet because first I wanted to make sure they fit and from what it looks like to me they are too small.
I tried the female bullets from an EC5 connector and they seem like the right size
Which is it?
Trex 700 Pro DFC - Compass 6HV - Vcontrol - Neo
#nodroneshere - 104
Larry227 is offline        Reply With Quote Quick reply to this message
Old 12-08-2013, 03:37 PM   #2 (permalink)
Most people find that there is no way they can solder the ESC wires (#10) into the size of connector that comes on the motor. I would unsolder (don't cut) the ones off of the motor and then use a quality connector of your choice. I use EC5 without the plastic and then heatshrink them, but CC makes nice ones in 5.5 and 6.5mm too...
AMA 373608
K2Freak is offline        Reply With Quote Quick reply to this message
Old 12-08-2013, 06:31 PM   #3 (permalink)
i had the same problem and ordered the castle 4mm bullets and they are the perfect size. helidirect.com has them for 6 $
BL NANO CPX
550E DFC
700E DFC PRO HV
700N DFC OS105HZ R
woodstock450 is offline        Reply With Quote Quick reply to this message
Old 12-08-2013, 07:37 PM   #4 (permalink)
Thanks for the replies. I had some spare new EC5's so I used the bullets from those, both on the motor and esc.
So far I have it all built and electronics installed but left the boom and head off until I get the wiring done. I put the CC 120 up front (we'll see how warm it gets next summer) and a full size Vbar on the rx tray in the rear with the sensor up front. I plan to put one sat on the front on the vertical face of the gryo tray and one on the boom right behind the tail block.
Luckily I didn't forget to solder in the HW phase sensor to the motor wires and a single ground wire from the flight pack connections. I assume with running a separate Life pack I'll need that common ground for the Vbar gov.
Already shut down for tonight, I just wasn't into it, been a long couple weeks at work and I just wanted to be lazy today. Plus the high was only 14* F so I'm not in any rush to get it complete, I would rather take my time, make it last and make sure it's right.
#nodroneshere - 104
Old 12-08-2013, 07:52 PM   #5 (permalink)
I left my main and auto gear out of the Heli until I was done with set up. It's perfectly safe that way. Good luck with your build I love mine
TS3D#1
NanoCPX, TREX500DFC,
TREX700DFC HV, DX8
TREX 700 Pro, TREX 700LTop, GauiX3, Futaba 14SGH
Excalibur3 is offline        Reply With Quote Quick reply to this message
Old 12-08-2013, 09:53 PM   #6 (permalink)
I will just leave the main gear with the shaft through it for now while I do my wiring so I know I clear everything. Then I'll take it back out to set up the ESC and check the failsafes.
Then re-install it and the head and do the rest of the Vbar setup.
#nodroneshere - 104
Old 12-08-2013, 11:28 PM   #7 (permalink)
Hey Larry I just finished my new 700E Pro tonight. I'm pretty sure everything is done including governor setup and iKon setup. I just used the included bullets, I also thought they were very small but I made it work.
Are you routing the wires inside the frame or outside?
Helis, Planes, Drones, FPV Racing.
Tesla is offline        Reply With Quote Quick reply to this message
Old 12-09-2013, 12:11 AM   #8 (permalink)
Cool Tesla. I think I'll probably run my wires on the outside of the frame just for the convenience factor. I tried hiding them all years ago on my 500 and it was a pain when I had to remove a servo or do much of anything else so I'm not going to get too OCD about it on this one.
This is your first 700? Let us know how the maiden goes. It's my first one too but it's going to have to warm up a bit before I get the maiden in.
#nodroneshere - 104
Old 12-09-2013, 03:32 AM   #9 (permalink)
Yep the size of those bullets are joke... I ended up using 6mm scorpion bullets..
With the castle edge no need fir a phase sensor set the aux wire to be an rpm sensor and connect that... msh sell a cable for it into the Ikon...
Manyc is offline        Reply With Quote Quick reply to this message
Old 12-09-2013, 09:00 PM   #10 (permalink)
Yeah this is my first 700 and I am so excited, I just sit and stair at it while it sits on my bench. It will be sad to see the 550 go but this 700 will get all my attention.
I won't be able to maiden it for a while it just got insanely cold here in Chicago and I don't want anything to interfere with my maiden. I hate my self if it wasn't a perfect maiden.
I hope to hear about your maiden soon.
Old 12-10-2013, 12:28 AM   #11 (permalink)
Default Re: My 700 Pro DFC build questions
I don't think mine will be anytime soon either. Maybe when it gets a couple degrees above freezing but that might be awhile.
Sent from my GT-P7510 using Tapatalk 2
#nodroneshere - 104
Old 12-10-2013, 04:59 PM   #12 (permalink)
I'm building my first 700 now too. (something to do in winter right?)
I hope this helps people who have been in the hobby for less than three years and don't have everything memorized (like me!)
https://www.helifreak.com/showthread.php?t=584617
DX8, Trex 700 dfc, Trex 550 dfc, Oxy3, Rifle 1M (plank!) PL8, PL6
atkin is offline        Reply With Quote Quick reply to this message
Old 12-10-2013, 06:26 PM   #13 (permalink)
Be careful with the EC5 bullets, make sure they fit tightly.
If they're loose at all going into the mating side, you're going to have issues in flight.
I use the Castle 6.5mm's on the ESC side. Nice and big, easy to solder, and tight fit.
dchekas is offline        Reply With Quote Quick reply to this message
Old 12-10-2013, 07:48 PM   #14 (permalink)
Poor northerners...lovely flying weather here in florida...todays high was 81 degrees
AMA #1039539
ddj74 is offline        Reply With Quote Quick reply to this message
Old 12-10-2013, 08:12 PM   #15 (permalink)
Oh I wish I could fly, why do I live here, I hate cold weather and its so limiting in every way including flying.
Old 12-11-2013, 07:56 AM   #16 (permalink)
Isn't that the truth. I hate a
" white Christmas" bah humbug!!!
TS3D#1
TREX700DFC HV, DX8
Old 12-14-2013, 05:51 PM   #17 (permalink)
Ok I have it all done and ready to maiden. If it's above freezing tomorrow I'll probably go out and put one flight on it.
I have a question. Do these links on the head look ok or are they backed off too much? I did the swash links as per the manual and when setting up 0* pitch with the Vbar I had to back the links on the DFC arms out this much to get 0* pitch.
Crap. The picture turned 90* on me. Let me try and fix it.
Well the thumbnail wants to stay 90* off. If you click on the picture to view it in another tab it shows up like it should.
#nodroneshere - 104
Old 12-14-2013, 07:39 PM   #18 (permalink)
Threads look too exposed. I would lengthen the servo to swash arms about 1 1/2mm to 2mm then set zero pitch.
AMA #1039539
Old 12-14-2013, 07:47 PM   #19 (permalink)
Agree.
Larry,
You can raise the swash a bit. The allows few more turns in on the DFC links.
HD750, TDR II, TDR, Logo 700, Logo 700 XXtreme, Logo 550SX V2
taoY is offline        Reply With Quote Quick reply to this message
Old 12-14-2013, 07:52 PM   #20 (permalink)
I just cranked my neck 90 degrees left
I agree with DD, lengthen the servo to swash a couple turns and take in the same on the swash to grips. I took a close look at Jamie Robertson's 700 and it only had a couple threads showing, so I did the same and raised the swash to get more rod into the links.
Crap, I thought it was cold here in Granbury. Been to Toronto in the middle of the winter and it wasn't any fun at all. Guess that's why I live here in Texas.
Specter 700, Logo 700, Logo 690SX, Goblin 700, Trex 700DFC, Gaui X7, Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550
Amain Hobbies Team Rep
rcflyerheli is offline        Reply With Quote Quick reply to this message
