Old 05-06-2014, 08:55 AM   #1 (permalink)
Default tail pitch slider with ball links very tight fit
Hi Guys,
I just changed my tail pitch slider and the ball links which snap onto the ball screws on each tail blade holder are very tight fit and causing binding in the tail.
what is the best solution to eliminate or reduce the binding.
dl5973 is offline        Reply With Quote Quick reply to this message
Old 05-06-2014, 10:16 AM   #2 (permalink)
Are your tail grips/bearings seated all the way? Pull hard outwards on the grips (as if centrifugal force would be applied) to make sure. If that checks out ok and it´s actually the plastic links being to firm, there is a ball link sizer available. I just use an old ball and snap it on the links a few times too loosen the plastic a bit. If still too tight and no sizer available you can scratch an old ball with an exacto knife and "ream" the links with it. Be careful not to end with sloppy links.
2x MCPX I Gaui »X1« I 2x Mini Protos I Protos I DX8
dr dremel is offline        Reply With Quote Quick reply to this message
Old 05-08-2014, 03:03 AM   #3 (permalink)
tail grips/bearings are seated all the way
the plastic links are the problem. One seems to fit pretty nicely but when I go to put on the second one it has to be forced to go into position. When you pop the links onto the ball you end up getting resistance when you move the grips left and right.
Old 05-08-2014, 11:01 AM   #4 (permalink)
I´ve bent misaligned plastic parts into position with the help of a hairdryer/hot air gun before. Sometimes parts get out of shape during shipping.
Old 05-09-2014, 08:30 AM   #5 (permalink)
One other thing to check for-- once I had a hub that would bind only when rotated at a certain orientation on the tail shaft. I used some 600grit paper to smooth/even out the inside of the hub (which is brass), and that fixed it.
Chief
RC Chief Hobbies
MSH Protos 500 Flybar, Gaui 200 V2 Flybar,V120D01, V120D02S,MCPx (retired)
Boating Fleet: Toysport Syncron and Triton Monos, 1/10 scale 1967 Miss Bardahl Shovelnose Hydro, Executone semiscale Hydro, OPC Tunnel, Miss Geico Cat
BHChieftain is offline        Reply With Quote Quick reply to this message
Old 05-11-2014, 06:39 AM   #6 (permalink)
Chief
yes sanded the hub as I had a similar problem.
Old 05-11-2014, 06:42 AM   #7 (permalink)
I ended up getting the shits and changed to a new set of tail rotor grips with thrusted bearing
everything is running smooth again.
I love the way the MSH Protos fly's but the quality of some of their parts its absolutey shit house.
I use to own Align Trex 500 and never had run into any issues like this.
Old 05-11-2014, 07:27 AM   #8 (permalink)
I have to agree. I have at least 300+ flights on my T-rex 500 DFC PRO with zero issues except for a slipping main gear on the one way bearing which was my assembly fault, accidentally left out a spacer
My mate at the field has has a few tail reliability on his Protos 500 as well.
Goblin 380, 420, 500, 570, 700. Soon RAW 420 & RAW 6s Piuma
HeliAxe is offline        Reply With Quote Quick reply to this message
