Old 02-21-2010, 01:31 AM   #21 (permalink)
Default Trex 450 Pro 3G Flybarless!
Thought I'd share this and see what you guys think! Finished the install on Friday. Was pretty easy except wiring the thing!
Sorry if the images aren't the best. I'll take some better ones on a nice sunny day out flying!
Jake Mackey is offline        Reply With Quote Quick reply to this message
Old 02-21-2010, 03:33 AM   #22 (permalink)
Looks clean man
Old 02-21-2010, 08:39 PM   #23 (permalink)
Originally Posted by OICU812 View Post
No one to my knowledge, Great Hobbies, Hobby Wholesale both in Edmonton, Alberta both do. They have websites and you can call in your orders, one day by bus is all it takes as well, cheers.
Hobby Alley in Edmonton carries a vast selection of Align parts as well...
Wizzard is offline        Reply With Quote Quick reply to this message
Old 02-23-2010, 10:56 PM   #24 (permalink)
Thumbs up yes - you can fly with 4 blade rotor head without flybarless stabi system
Wanna flybarless without the elec stabi system? - YEP - you can buy the multi-blade 4 blade rotor head and no need electronic stabi system - again if you don't want to spend money on the elec stabi system while no 3d in flybarless - then buy the 4 blade rotor head
Originally Posted by sharks View Post
But is it optional to install a stabilization system, is this required? And what are the benefits?
rcjpth is offline        Reply With Quote Quick reply to this message
Old 02-25-2010, 10:42 AM   #25 (permalink)
Anyone have a vid?? I like to see this heli with FBL...
Trex 700E 12s Pro DFC
Trex 600E 10s with Vbar
Trex 450 Pro with Vbar
Trex 250 with scorpion 3600Kv
VDFS is offline        Reply With Quote Quick reply to this message
Old 03-03-2010, 06:35 PM   #26 (permalink)
I'm still waiting for someone to tell me how great the Align flybarless setup is.
Anyone? Anyone?
T-Rex 550E, T-Rex 450 Pro, T-Rex 250 SE, Blade MCP X, Funjet Ultra, 3DHS 41 Edge, DX7, BC6
JBuck is offline        Reply With Quote Quick reply to this message
Old 03-04-2010, 12:16 AM   #27 (permalink)
Anyone? Anyone?
I'm loving it! No problems so far.
It's a totally different feel while flying if your new to FBL. Which I am. But I'm getting used to it. And if flies freakin awesome! I'm loving it. It's so stable for just cruising it around. Tried a few 3D maneuvers with it (nothing too exciting) and was ok. Just need to tone the gain down slightly.
Check out Utah Extreme 3D on Facebook where we keep up with the local RC scene in Northern Utah!
Old 03-05-2010, 11:26 PM   #28 (permalink)
Default 450 FBL
Jake that heli flies like a champ, and it is quite a bit quieter if i might add compared to the stock flybar setup.
Surfrjeff is offline        Reply With Quote Quick reply to this message
Old 03-08-2010, 01:01 PM   #29 (permalink)
RCJPTH,
So you are saying that the 4 rotor head is as stable as a stock machine in flybarless design?
Can you use standard servos like on a flybarred machine?
What are the negatives then?
ghillie is offline        Reply With Quote Quick reply to this message
Old 03-15-2010, 12:02 PM   #30 (permalink)
Default When will 450 Pro kits ship with FBL in the box?
Any thoughts on this? I note that the various heli shops are already selling the 600 Nitro and 700's with the FBL in the box. I gotta think that the rest of the lineup will certainly be shipping this way soon enough.
I'm wondering if the first all electric heli kit to get the FBL will be the 600 or the 450?
Anyone have any thoughts on this? Any "inside info" from Align and/or Assurance as to when we might be seeing a 450 Pro kit with the FBL in the box?
Joe
T-Rex 250 SE w/Walkera 2801 radio. alloy boom block, CF boom, alloy servo mounts, CF pushrod, alloy t/r bell crank, JR DS290G, Kevlar t/r belt, 40mm KBDD t/r blades, Titanium turnbuckles.
HeloJoe is offline        Reply With Quote Quick reply to this message
Old 03-15-2010, 06:47 PM   #31 (permalink)
What kind of collective and cyclic pitch range do you guys setup with miniVBAR ?
Does it need to be more or less than when using the traditional flybar ?
Thanks !
demosa is offline        Reply With Quote Quick reply to this message
Old 03-15-2010, 07:11 PM   #32 (permalink)
Thanks !
Collective same as you would say on a flybar, cyclic you tend to run 9-11 degrees, it is entirely different so you need that resolution to work with.
Old 03-17-2010, 03:21 AM   #33 (permalink)
Default Trex 450 Pro FBL 3G System
Here's a little video of my 450 Pro with the new 3G on it. Just getting a feel for it. I've never had any experience with flybarless helis. But I'm loving it so far!
Old 03-19-2010, 04:53 PM   #34 (permalink)
Can someone that is using the mini VBAR on a 450 Pro comment on the servo horn length and the resulting "cyclic gain" calculation (via the "geometry tool" on the vstabi site).
With the "usual" servo horn length recommended by the 450 pro manual (i.e. 15mm or so, so that the links are straight up to the swashplate balls) the cyclic gain calculation gives me a pretty low value, 81 or something like that. This most likely means that the servo horn length on the Pro is pretty big which results in too much pitch range...
But if I reduce the servo horn length then my swash links will be "crooked".
Any comments please ? Never mind, I figured it out !
Tahnks !
Old 03-20-2010, 09:59 PM   #35 (permalink)
Skookum SK-720
Better then Align?
Says it replaces reviever. DX7?
Anyone?
Im thinking of going flybarless but not sure which to go with.
Old 03-25-2010, 06:36 AM   #36 (permalink)
If i buy these parts i transform my 450 with FBL head??
http://www.align.com.tw/shop/product...oducts_id=3172
http://www.align.com.tw/shop/product...oducts_id=3180
http://www.align.com.tw/shop/product...oducts_id=3188
Is necessary buy other parts?
Old 03-25-2010, 06:45 AM   #37 (permalink)
I modded my stock Pro head for FBL use, did not like it!
Was very nervous and twitchy.
Recommend the RJX head, Im very happy with it.
http://www.helidirect.com/trex-450-p...ad-p-16799.hdx
Trex 450 Pro Stretch Neu Scorp 1630, 8s, CC30HV. Mini V
Trex 700 DFC V-bar
Helipsyko is offline        Reply With Quote Quick reply to this message
Old 03-25-2010, 07:41 AM   #38 (permalink)
Why you do not like the head ALIGN (modded by you)?? The parts that i list is correct or i forget somethink?
Old 03-25-2010, 11:58 AM   #39 (permalink)
As mentioned, it was very nervous and twitchy.
Here is where I found the way to do it http://rc.runryder.com/helicopter/t5...hlight=450+fbl
But when I tried the RJX head it was like getting a totally new bird.
Trex 700 DFC V-bar
Old 03-27-2010, 07:38 AM   #40 (permalink)
Great thread !
I have just made a Pre Order for the SK 720, hopefully I have it in the end of April.
I have also bought the Mikado head and swash plate driver, and a pair of EDGE FBL main blades for mine, it should be here next week .
Where to put the controller, hm …. I have not made up my mind yet, I think that KDE – thing look so huge on the PRO, I hope there would be room enough to put my controller under the bottom plate.
I already have the SK 360 installed in another –not-at-the-moment-flying -bird, it could very well be that I start playing with that in my PRO
/Bjørn
Moving air in severals ways in Denmark :glasses2:
bjosko is offline        Reply With Quote Quick reply to this message
