Old 03-06-2014, 01:30 AM   #1 (permalink)
Default Kosmik new firmware 4.4
http://www.kontronik.com/index.php?o...id=193&lang=en
Lots of changes for alarms.
VControl
Old hand at Planks
Peter
Old 03-06-2014, 08:56 AM   #2 (permalink)
So is purely a TelMe update?
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 03-06-2014, 10:32 AM   #3 (permalink)
Yes its in preparation for the Telme modules
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 03-07-2014, 07:48 AM   #4 (permalink)
When will the K-Prog App be upgraded?
Dave
f2000ez is offline        Reply With Quote Quick reply to this message
Old 03-07-2014, 10:04 AM   #5 (permalink)
Dave
upgraded for what?
Richard Zappe
Old 03-07-2014, 01:32 PM   #6 (permalink)
Richard...probably asking because this was listed on the KON website:
Update KOSMIK 160 (Version 4.4)
Update KOSMIK 200 (Version 4.4)
With version 4.4 the alarm activated by the TelME modules are the following:
battery voltage: 10% more than KOSMIK slow down limit
used capacity: 10% before reaching KOSMIK capacity limit
RPM: no alarm
motor current: 125% of allowed current
temperature power unit: 90% of allowed max. temperature
temperature BEC: 90% of allowed max. temperature
BEC Strom Default: 125% des zulässigen Dauerstroms
PWM %: Inaktiv/nicht benötigt
In future these parameters will be programmable by K-Prog App.
Greg Alderman
Warehouse/ Facilities Manager
greg@helidirect.com
Greg Alderman is offline        Reply With Quote Quick reply to this message
Old 03-07-2014, 01:34 PM   #7 (permalink)
RPM: no alarm
Oh OK whoops missed the last line. Yea probably some time after the telme modules come out.
Richard Zappe
Old 03-07-2014, 02:52 PM   #8 (permalink)
The Bluetooth provide telemetry already.
Mikado Logo 800XXtreme, Vbar 5.3, 813mm Edge Blades, 14S Kontronik Cool Kosmik 200HV.
ALIGN T-REX 550E DFC with 600 Boom, 603mm Edge Blades, Kontronik Heli Jive 120HV, Pyro 600-12, Mini Vbar 5.3 Pro, V3 Tail, Black Gears, Many KDE Upgrades.
Nelvick is offline        Reply With Quote Quick reply to this message
Old 03-07-2014, 06:21 PM   #9 (permalink)
Its an update to change perameters associated with the telme module not additional telemetry.
Richard Zappe
Old 03-08-2014, 07:58 AM   #10 (permalink)
Thank You Gregg and Richard
Dave
Old 03-09-2014, 04:17 PM   #11 (permalink)
Sounds li,e cool stuff coming
Kontronik, Switch Blades, Bavarian Demon, TDR, TDF, Diabolo, HeliBaby, Takumi and Banshee
im4711 is offline        Reply With Quote Quick reply to this message
Old 03-20-2014, 01:06 PM   #12 (permalink)
I have a kosmik 160, and I am finally getting that helicopter ready to maiden,
The kosmik is running version 3.1 of the firmware ( I just pulled a log and checked)
Can I go straight from 3.1 to 4.4?
Besides updating the progdisc to latest version before doing the update, , is there anything else I need to know?
Any "gotchas"
Thanks in advance, my first kosmik upgrade and just being careful. I do not want to brick this thing...
Logo 480 XXtreme, Logo 550SX, Logo 690SX, Logo 800 XXtreme, TDR, Minicopter Diabolo 550, Minicopter Triabolo, Goblin 500, Goblin 700, Goblin 770, KDS Agile 5.5, Voodoo 600, Voodoo 400, HD Cell 500, Thunder Tiger E700
taosgraveyard is offline        Reply With Quote Quick reply to this message
Old 03-20-2014, 01:11 PM   #13 (permalink)
I followed the guide in sticky. Went from 4.3 to 4.4. Only thing that was scary was windows reported program not responding during update with no progress indicator. The prog disc flashed green and red and it did work out though.
Khalil N.
Seaview Rotary Wings, Brooklyn NY.
nuroo is offline        Reply With Quote Quick reply to this message
Old 03-20-2014, 01:32 PM   #14 (permalink)
Thanks for that info, think I remember reading, just leave it alone and it comes back when done..
Let it do it's thing, right?
Old 03-20-2014, 02:53 PM   #15 (permalink)
Is recommended reset to mode 1 and them upgrade the firmware. If your is the very first generation will require a hardware upgrade by Kontronik in order to be upgradable by my understanding.
Sent from my iPhone IOS 7 using Tapatalk 2
Old 03-20-2014, 04:48 PM   #16 (permalink)
Yes I already looked inTo that issue. First generation is not supposed to be 3.1. I pulled a log, I am on 3.1
Other threads indicate that serial numbers lower than mine have been able to successfully update, as low as somewhere around #300. Mine is #439.
Thanks will do a mode 1 reset before the upgrade
Old 03-20-2014, 05:52 PM   #17 (permalink)
Si nesesitas ayuda avisame que te puedo explicar mejor en espańol por telefono de ser nesesario.
Old 03-21-2014, 09:40 AM   #18 (permalink)
gracias, pero yo soy un extranjero aqui en Argentina, Inglés es mi idioma preferido
Old 03-21-2014, 09:45 AM   #19 (permalink)
Freaky
Did the upgrade ok, never got the not responding message, and never got a progress indicator. One the lights on the progdisc stopped flashing, I disconnected the battery and the USB cable and reconnected and got a invalid update error on the progdisc.
Did a reset using the progdisc and now everything is good
Why is this upgrade process so flakey? What's wrong with kontroniks software and firmware developers... This has to be causing them support emails and calls that they could totally avoid if the process was not so unnerving
Anyway, my jlog2.5 is getting data now, and the ESC allowed me to to mode programming and set the BEC voltage, and it arms, so I guess all is ok
Old 03-21-2014, 10:14 AM   #20 (permalink)
Cool. I glad is working for you now.
