Thunder Tiger GT5 FBL System Thunder Tiger GT5 Flybarless Electronics |
01-24-2012, 02:58 AM | #21 (permalink) |
The instructions recommend lower ID-Stick for smaller heli's to avoid cyclic bounce on elevator so I would be inclined to follow Swalco's guidance to get it as good as you can and then start working on ID-Stick!
CustomHeliParts/KDE TRex 700N ThunderTiger X50 FBL Ely.Q Vision 90 Ely.Q Vision 50 |
01-24-2012, 02:59 AM | #22 (permalink) |
Yes I did try raising it to 120% but it still didn't cure the problem.
01-24-2012, 03:04 AM | #23 (permalink) |
Yes, you are right. I just had a look at the manual and it says lowering ID-Stick to 60-80% can help eliminate cyclic bounce on smaller helis. I have not experimented at all with this parameter yet so next time I'm out, I will try lowering it and see what happens.
01-24-2012, 03:06 AM | #24 (permalink) |
Then i recommend you to play with I-D Stick. I do not have currently own experience with I-D Stick, but Tail Stick Dynamic was for me the only one way to eliminate tail overshooting on stops (similar to cyclic bounce).
