Old 01-15-2012, 12:28 AM   #41 (permalink)
Any new news on this?
Avant RC
Scorpion Power Systems
ThunderPower RC
Kontronik Drives
Justin Stuart is offline        Reply With Quote Quick reply to this message
Old 01-20-2012, 01:13 PM   #42 (permalink)
Originally Posted by MrMel View Post
Easiest explanation is:
Jive in "non-KSA" mode auto-adjust settings depending on several factors.
In KSA mode the auto-adjusting part is less, its more static i.e. same as other ESCs.
(Timing and drive-rate)
What would be the flight differences between both modes. Would you loose performance in KSA?
"Sort your head out and fly with your heart"
Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc,
Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251
markleyland is offline        Reply With Quote Quick reply to this message
Old 01-20-2012, 09:49 PM   #43 (permalink)
I don't know for sure but, I would venture to guess that in non-KSA, where the Jive is not dynamically adjusting to the motor, you're going to be much closer to 100% efficiency. Then again, I'd gladly accept a 5-10% performance degradation that was always there over a 100% performance degradation that showed up at the most inopportune times!
John
Compass Knight 600E, Blade 450, Blade 400, Blade SR, Blade mCPx, Blade 120, Blade mSR, Blade mCX, Blade CX2
johnopsec is offline        Reply With Quote Quick reply to this message
Old 01-20-2012, 11:03 PM   #44 (permalink)
Yes, you will loose some performance.
But it's kind of arbitrary as the reason for using KSA in some cases is that the motor produce more power and EMF spikes so the controller cannot handle it.
Meaning, if you REALLY need that last x% power, your setup from start is not optional, you should have chosen differently.
http://heli.dacsa.net
Old 01-21-2012, 03:25 AM   #45 (permalink)
The reason I ask is my motor has low resistance issues with my Jive 100+LV. I would have chosen differently but KDE told me the two were compatible when I asked so I bought their KDE/NEU when they first came out (now discontinued). I have problems arming the esc at times and have never tried the KSA mode. I remember someone else having the same issues with this motor who tried KSA but didn't solve the problem. Worth a try I guess as long as there are no adverse effects or damage to the motor/ESC?
Old 01-21-2012, 04:02 AM   #46 (permalink)
More about ksa
https://www.helifreak.com/showthread...29#post3187229
Hyaloid is offline        Reply With Quote Quick reply to this message
Old 02-05-2012, 10:54 AM   #47 (permalink)
I have a telephone meeting with Kontronik coming tuesday, but I can tell you what you should NOT do, do not "abort" throttle hold, that seems to be the biggest risk factor as far as I have found out so far.
If you do throttle hold, allow the motor to stop, completely.
else you can get into commuting error, with it, risk of big EMF spike, with it, risk of damaging ESC or motor.
I'm not talking about Vbar + Auto-rotation bailout, since that use an idle mode, but I mean if you do a "full throttle hold" and then flip out of hold before motor physically has stopped.
Hi again MrMel,
i was asking few weeks ago about v-bar gov + helijive + 4525-520 that i have for my goblin and i want to use... that was what you said...
so...
How was that telephone call? any details about the problem?
and is this problem related to helijive or is it the same with all ESCs?
Thanks for your time again
Toni
Tohtori R is offline        Reply With Quote Quick reply to this message
Old 02-05-2012, 11:10 AM   #48 (permalink)
They really did not have any info on the topic, sorry.
what I talk about above is Mode 8 on HeliJive and should not occur on other Jives.
Old 02-06-2012, 03:11 AM   #49 (permalink)
i mean other brands... is this a problem of kontronik when used with that motor or?
if i get some other brand esc (scorpion comander etc..) is there the same problem waiting for me?
i have also read about align 700MX motors that has burned with that setup so is it related to motor choice at all?
sorry for bombing you with questions but i have a very expensive setup waiting and i dont want to kill it for not knowing something...
v-bar gov still seem very intresting if it works...
-Toni
Old 02-06-2012, 03:38 AM   #50 (permalink)
-Toni
It's only Kontronik ESC that has this particular problem.
Old 02-06-2012, 04:10 AM   #51 (permalink)
thanks for making this clear.
-Toni
Old 02-08-2012, 06:31 PM   #52 (permalink)
Hi Mr. Mel
Thanks for the warning. This is the first time iVe heard of this. I have only 1 Kontronik ESC so far and I dont frequent this site. What happens if you have damaged your ESC by doing so and not knowing about it? Will Kontronik still honour their warranty? I will read my intructions manual again regarding whether this warning is included in the intructions manual. If its not then it should be included in the front page i reckon.
LOGO 600se, Scorp 5020-450,HeliJive 120, V-Bar Blue FS
LOGO 500se, Scorp 4025-1100 6s on 550 Blades
PROTOS 500 Stretched , Scorp, YGE, Beast-X
(Retired) Trex 600 Npro FBL 3GX ,Trex 550 FBL 3GX ,Trex 450 FBL 3GX-X2,Trex 250 FBL 3G
dennisvm75 is offline        Reply With Quote Quick reply to this message
Old 02-08-2012, 10:09 PM   #53 (permalink)
Originally Posted by dennisvm75 View Post
Hi Mr. Mel
Kontronik will always look at each case for warranty claims, as long as you provide information enough they are very fair, and no, it's not an official warning, but rather a friendly pointer, i.e. only common thing I've seen so far that has potential to have problems
Old 02-08-2012, 10:22 PM   #54 (permalink)
Does that mean that this "A cheat for autorotation bailout on Jive?" is a bad idea? Technically, it's not HOLD but simply slows drops throttle to a point where the motor is being driven but, not fast enough to hover.
John
Old 02-08-2012, 10:24 PM   #55 (permalink)
No, as long as motor is driven it's even more safe than anything else.
(that's why when using VBar you should run "Idle at AR")
The problem have potential when
a) ESC has stopped driving the motor (turn off)
b) Motor still spinning but nothing drives it.
c) ESC tries to restart the motor.
It's a very short timeframe, drag from main gear and pinion usually makes this short, and with lighter motors even more so, but if you have a very big motor like a Scorpion 50xx series etc, it takes a little while before motor stops.
Old 02-08-2012, 10:27 PM   #56 (permalink)
Gotcha. Just wanted to make sure. I didn't want people cooking their ESCs following advice that I had given. Good way to get a BAD reputation!
John
Old 02-08-2012, 11:06 PM   #57 (permalink)
Thanks so much Mr. Mel
