Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 11-08-2012, 09:48 PM   #41 (permalink)
let us know how it went TAUSCNC
laoch33 is offline        Reply With Quote Quick reply to this message
Old 11-09-2012, 09:34 PM   #42 (permalink)
I flew it!
https://www.helifreak.com/showthread...92#post4436492
Post is here
www.cuttingedgecnc.com
tauscnc is offline        Reply With Quote Quick reply to this message
Old 11-10-2012, 02:41 AM   #43 (permalink)
Here there my setup
Os37sz
Gaui pipe 30
Ds510m on cyclique
Ds520 on tail
Ds510 on motor
Beastx
Rs 617 fs ( he's a little bit big for the heli size )
Mini gryphon auto booster
2 life 1450 mah hyperion with dean
Revmax pro
Edge blade 425 and 72mm kbdd on tail
Also i change the dumper for the black
Philippe from france
philou3110 is offline        Reply With Quote Quick reply to this message
Old 11-16-2012, 09:57 AM   #44 (permalink)
Yahoo picking up my kit and stuff today after work.
Teambob00
Chris Lalonde is offline        Reply With Quote Quick reply to this message
Old 11-16-2012, 01:03 PM   #45 (permalink)
Awesome.. Watch the fuel line , header tank, rubbing on the canopy. I heated up the nipple and bent it down, let cool. You can put the fuel tubing under the tail pushrods and shorten it quit a bit.
Old 11-16-2012, 03:28 PM   #46 (permalink)
Sweet thanks for the tips.
Teambob00
Old 11-29-2012, 03:26 PM   #47 (permalink)
Default .50 engine on NX4
hi guys
will a .50 os heli engine fit on the Gaui NX4??
ruidos99 is offline        Reply With Quote Quick reply to this message
Old 11-29-2012, 04:17 PM   #48 (permalink)
Originally Posted by ruidos99 View Post
hi guys
Pretty sure it will not work. The os 37 should be more than enough power!
joallen001 is offline        Reply With Quote Quick reply to this message
Old 11-29-2012, 05:25 PM   #49 (permalink)
I am 90% all set except the MKS DS8910a tail servo which I am still waiting for the arrival from AMain. Here is my setup:
NX4 Basic Kit
Radix 430 main FB/ Radix 72mm tail
OS37 Engine/Hatori SAB pipe
DS510M cyclic
Futaba s9257 throttle
MKS DS8910a
BeastX
AR7100R with rev sensor
2100mah LiFe 6.6v Rx pack
ID:	369872   Click image for larger version
ID:	369873   Click image for larger version
ID:	369874   Click image for larger version
ID:	369875   Click image for larger version
ID:	369877   Click image for larger version
rudyy is offline        Reply With Quote Quick reply to this message
Old 11-29-2012, 08:24 PM   #50 (permalink)
NX4 Basic Kit
DS510M cyclic
MKS DS8910a
BeastX
How much room do you have with the 2100mah battery? I just ordered the 1450mah, but would of liked to use the 2100 if it fits. Also did you just attach your header tank to the main tank?
Old 11-29-2012, 08:51 PM   #51 (permalink)
I ditch the mount and use 3M double side adhesive tape reinforced by the clear silicon along the four edges of the tank.
Yes, I can fit in the 2100mah on the top mount.
The receiver mounted sideway does not work as it is too big and I cannot fit in the canopy. I am caught by surprise after finishing all the nice wiring. I relocate the receiver to the bottom mount and now everything is ok.
Old 11-29-2012, 08:59 PM   #52 (permalink)
I personally do not like using the mount as it may cause frame damage upon crashing (knock on wood), and it makes the heli look a lot cleaner.
Old 11-29-2012, 10:04 PM   #53 (permalink)
Your canopy clip is on top, and it should be in the bottom. The canopy gives you no room!!! It's one of my gripes with this heli, but once you fly it, you quickly forgive this.
Rush 700 * Trex 700N x 2 * Trex 600Pro * Goblin 570 * 450L Dominator - V-Bar on all
AMA #934662
caralmar is offline        Reply With Quote Quick reply to this message
Old 11-29-2012, 10:16 PM   #54 (permalink)
Thanks for pointing it out. I do not notice that.
But now I cannot fit in the canopy because the LiFe is too big. I think I may have to mount the canopy clip on top as a workaround.
Old 11-29-2012, 10:36 PM   #55 (permalink)
I wouldn't... Inverted hurricane may pop it off that way!
AMA #934662
Old 11-29-2012, 10:44 PM   #56 (permalink)
I need to relocate the AR7100R rx back to where it is but with the stock esc plastic mount removed. The 2100mah rx pack is bottom mounted, leaving the top mount empty. Now, I can fit in the canopy with the clip at the bottom. I think that is the only layout that can fit 2100mah LiFe and AR7100RX.
ID:	370053   Click image for larger version
ID:	370054   Click image for larger version
ID:	370061   Click image for larger version
Old 11-30-2012, 11:17 AM   #57 (permalink)
I tried a similar size pack to yours, but the canopy wouldn't fit on mine. Went for a smaller pack in the end.
Cheers,
Simon
Si_B is offline        Reply With Quote Quick reply to this message
Old 12-04-2012, 04:19 PM   #58 (permalink)
Can't wait to start the build. Thanks for your tips at the field, Pinion!
Enya 35X (not sure if adequate, may upgrade to OS 37)
Gaui 30 Pipe
R6202SBW
Futaba CGY 750 FLB + gov
Align 515 x3 cyclic
Align 525 tail
Align 520 throttle
Edge 425 Main and Tail Blades
RotorRage 30%
Turnigy NanoTech 1450 2S LiFe
RevGlow
Header tank w/ align 3way filter
Bubbleless clunk
- Morgan Fuels Cool Power -
T-Rex 600N - YS 60SR / ProModeler servo / Futaba CGY 750
T-Rex 700N - YS 96 SRX / ProModeler servo / Futaba CGY 750
MikeG4936 is offline        Reply With Quote Quick reply to this message
Old 12-05-2012, 06:43 AM   #59 (permalink)
Yeeeeesssss! Anytime my friend.....
Gaui X7, X5, NX4, X42, X3
Gaui USA, Empire Hobby, JR Americas, Cyclone Blades, MKS Servos USA, OptiPower Batteries,YS Engines,
PowerMaster Fuels
Pinion is offline        Reply With Quote Quick reply to this message
Old 12-05-2012, 12:25 PM   #60 (permalink)
I just received my kit today and it looks awesome. I'm a huge fan of Bobby Watts designs, I'm currently building a Whiplash nitro and have been flying Whiplash E, Furry 55 and Furion 6, the designs are so simple and easy to work on and this one is very similar. I bought the combo with Gaui servos and Vbar, now I gotta get the Whip finished so I can build this one.
ChuckL is offline        Reply With Quote Quick reply to this message
