Go Back   HeliFreak > R/C Electronics Support > Hitec Radios > Hitec Gyro/Servos
Hitec Gyro/Servos Hitec Gyro and Servo Support
Old 02-24-2009, 05:33 PM   #1 (permalink)
Default JR or Hitec, Digital or non?
Im thinking of ditching the stockers,
Here are my chioces
Hitec HS-5065 MG or Hitec HS-65MG
OR
JR DS285MG
Which would you guys choose and why?
Why oh why, did it fall from the sky?
E -Flite Blade 400 3D and MCX, Align TREX 600NSP, Traxxas Nitro 4-TEC 3.3, Traxxas Nitro TMAXX 3.3, Enforcer 48" 30cc Gaser Deep V fiberglass boat
Arsenix2001 is offline        Reply With Quote Quick reply to this message
Old 02-24-2009, 05:44 PM   #2 (permalink)
I'm fighting the same debate! Some love the HS-65's, with or without metal gears. Some seem to love the JR DS285's, with or withouot metal gears. I want great centering and precise smooth movements while being a little tougher. The way i understand it, i would need digital for the precision and centering, but the price of the HS-65HB's is hard to beat! especially with all the added torque they offer! I don't know....
Specter 700 V2- Pyro 750-56, Kosmik 200HV, Torq servos, CGY760R
Tron 7.0 - Pyro 750-56 Comp, Kosmik 210 HV-I, Torq servos, CGY760R
Dirtmagnet400 is offline        Reply With Quote Quick reply to this message
Old 02-24-2009, 05:55 PM   #3 (permalink)
Neither.... Hitec HS-55's $13.99 a peice....will fit the stock spots like a glove ...prob one of the most tried and true servos out there...not glitzy, not digital, uses the same power & space but performs 10X's better than the stockers.....
| TREX-500 SUPERCOMBO|
| BLADE-400 | MD500D Fuselage w/ Lights |
| TREX-450-SE/V2 |Align 3GX|Fusuno MD500E Fuselage|5 blade|
Blade~400~er is offline        Reply With Quote Quick reply to this message
Old 02-24-2009, 06:05 PM   #4 (permalink)
Hmmm 55's you say... I shall investigate those right now.
Old 02-24-2009, 06:08 PM   #5 (permalink)
55's are GREAT servos but they are slow and not as durable as hs-65mg, but other than that they are AWESOME servos i use them in lots of planks
Forza 450
M.Huerta is offline        Reply With Quote Quick reply to this message
Old 02-24-2009, 06:12 PM   #6 (permalink)
I may just go with the 65MG's non digital. I am assuming you can still use sub trim and end points in the radio correct? Im thinking cost savings plus I dont want to use an ext BEC with my align 35G unit, so the standard servos should draw less juice. Looks like the digital and non digital versions have the same travel speed... .14 at 4.8v. Should these fly alot better than stockers?
Old 02-24-2009, 06:14 PM   #7 (permalink)
that is the best path and YES your heli WILL fly WAAAYYYY better, because it will not be slamming into the ground because of a stripped servo
Forza 450
Old 02-24-2009, 06:37 PM   #8 (permalink)
JR 285 either mg or reg.
Doesn't really matter because you can upgrade to the mg anytime you feel like it .
Also unlike the Hitec 65 the JR 285's fit without any filing
Another thing you have to watch out for with the Hitec 65's is that a lot of people were having problems with the stock ESC going into thermal shut and having to add a separate BEC to correct the problem so thats something to consider depending on your funds.
Blade400 Scorpion 2221-8, JR 285MG ,Spartan DS760 Jr3400G ,CC35 ESC ,CC10amp BEC
T-rex 500 Hitec 5245MG .JR g770 3D Futaba S9254 .Medusa 1600kv, KDE upgrades, Spartan DS760
totsandman is offline        Reply With Quote Quick reply to this message
Old 02-24-2009, 06:49 PM   #9 (permalink)
the only thing im not diggin is the JR's seem alot slower than stock.. i will be running at 5.1v so im only looking at .18 speed, vs .14 for the 65's Any one run the 285' son 4.8 volts?
Old 02-24-2009, 06:50 PM   #10 (permalink)
this is true but it is a good idea to get a seperate bec no matter what because my esc overheated and shut down with the stock servos.
Forza 450
Old 02-24-2009, 07:04 PM   #11 (permalink)
Specs, JR 285
Type: Digital Hi-Speed Sub-Micro
Torque: 16.9 oz/in
Speed: .18 sec/60 degrees @ 4.8v, .14 sec/60 degrees @ 6.0v
Dimensions (WxLxH): 0.45"x0.87"x0.85"
Weight: .32 oz
Bearing: n/a
Motor Type: 3-pole ferrite
Gears: Nylon
Application: Electric aerobatic planes, sailplanes, micro-helis and other special applications
Hitec 65's
SPECS: Length: 0.92" (23.6mm)
Width: 0.45" (11.6mm)
Height: 0.94" (24mm)
Weigth: 0.44oz (12.5g)
Speed: 0.14sec/60� @ 4.8V
0.11sec/60� @ 6V
Output Torque: 24.99 oz-in (1.8kg-cm) @ 4.8V
30.55 oz-in (2.2kg-cm) @ 6V
Old 02-24-2009, 07:06 PM   #12 (permalink)
Anybody running 290g's on the cyclic? I know there was someone on the board who was happy running similar sized Hyperions on the cyclic.
Torque: 13 oz/in @ 4.8V; 16 oz/in @ 6V
Speed: .08 sec/60; .07 sec/60 @ 6V
Dimensions (WxLxH): .45x.87x.85
Weight: .25 oz
xspare is offline        Reply With Quote Quick reply to this message
Old 02-24-2009, 07:17 PM   #13 (permalink)
I think i am leaning toward the 5065mg's... best of both worlds, digital and fast on 4.8 volts... .14 sec. Plus a few bucks cheaper than the DS285's ta boot. Decisions, decisions.
Old 02-24-2009, 07:56 PM   #14 (permalink)
the digitals are not needed, the best 450 pilots fly with the analogs and look at the precision of their flying.
Forza 450
Old 02-24-2009, 08:18 PM   #15 (permalink)
I use HS-65HB's. I believe they are the same as the MG's but with karbonite gear(s)?
Never had a prob even after a few heavy duty crashes.
sepoinak is offline        Reply With Quote Quick reply to this message
Old 02-24-2009, 08:39 PM   #16 (permalink)
Has anyone had both the DS285's and the HS-65's? My main concern is high quality centering. I hope both servo's do this well, but i would really like to know. i am hating the sloppy return to center of the stock servo's.
Old 02-24-2009, 08:41 PM   #17 (permalink)
i've stripped 2 hb's 2nd gear in switched to mg my last crash actually busted the front of the gear case off but the gears are still good just need $7. gear case. It's to bad they are hard to install put they take a licking and keep on ticking. Perfect for newbees or people with shakey hands. I love not replacing striped gears all the time and flying is so much easyer
schoep is offline        Reply With Quote Quick reply to this message
Old 02-24-2009, 10:13 PM   #18 (permalink)
yes i have both
my personal opinion all based on 6v
HS-65
fast
powerfull
decent centering
hi current draw
needs a lil modding to fit
a lil heavier
DS285
decent speed
ok power
perfect centering
no mod
not much lighter
the ds285 has a smother operation than the hs-65 may be due to the speed diffrence
with both nylon gears its usually the 2nd one to strip and in both gears are cheap
IMO id go with the ds285's insane locked in feel
but in any rate no matter what you choose anyservo seems to blow away the stock servos
B400 DS285/3400G/401/-8/40Aesc/sonicCNC/CNCframe
TwinRexx: 6xHS-65/2xGY240/jfg500/TH2
CH-47D/UH-1H Crewchief/ Mechanic
sokal is offline        Reply With Quote Quick reply to this message
Old 02-25-2009, 12:08 AM   #19 (permalink)
just pulled the trigger on ds285mg's I want the locked in feel more than speed at this point, and the mg for durabilty... hope they arent too slow on 5.1 volts...:o Used free, long time wait shipping... who cares, thanks to spektrum I wont have a transmitter for a few weeks!
Old 02-25-2009, 12:49 PM   #20 (permalink)
Well scratch that last post, I cancelled my JR order and decided to give the 5065's a try, with thier speed and now being digital, id imagine they will hopefully have that locked in feel too. At this point, alittle bit of frame grinding is the last thing I am worried about
