View Poll Results: Has your tail servos failed? Counting # of bad servos on 300x.
Yes 91 66.42%
No - please leave unmarked, this poll is to get a # of bad tail servos 28 20.44%
Blade should send out better tail servos for all 300x owners. 48 35.04%
Multiple Choice Poll. Voters: 137. You may not vote on this poll
Old 09-27-2012, 10:59 PM   #61 (permalink)
Originally Posted by mixfisto View Post
I meant to say move the servo via the rudder stick on your tx... or you could probably just move/turn the heli left/right to work the servo (while its trying to keep the tail 'inline'). Basically I'm thinking that if the servo is about to go bad, once it's being used/active, it shouldn't take more than a min or two to fail.
Oh I got ya...The tail servo still is working and is actually performing pretty normal with the tail blades on it that it came with (not sure why the yellow tail blades from blade would do that??). I do however have some wag only when giving right rudder input.
Thanks for your input!
bk.heli.man is offline        Reply With Quote Quick reply to this message
Old 09-28-2012, 12:58 PM   #62 (permalink)
32 Flights. Stock Tail servo "melted" on spool up for flight 33
450X | 450 3DX | 300X | 130X | Mcpx BL | Mcpx | SR | 350QX | Mqx | Nano Cpx | Nano Qx | 120 SR | And one DX8 to rule them all.
Blackanthem is offline        Reply With Quote Quick reply to this message
Old 10-07-2012, 07:28 AM   #63 (permalink)
Default Hitec 5084 on tail
Besides setting endpoints, what else needs to be set when installing the Hitec 5084 on the tail of the 300X?
traxxdigger is offline        Reply With Quote Quick reply to this message
Old 10-14-2012, 06:58 AM   #64 (permalink)
Depends on how you mount it, but i put mine in just like the eflite was mounted and had to reverse the setting on the bx.
Sent from my SGH-I757M using Tapatalk 2
Too many Heli's to fit in my sig, current favorites: Whiplash 700 Gasser, Gaui X2, X380 and X480, Trex600e-dfc
Hexperience is offline        Reply With Quote Quick reply to this message
Old 10-14-2012, 07:24 AM   #65 (permalink)
Since the 5084 is heavier than the stock servo, I moved it forward as far as possible. You will want to install in mount with output shaft of servo toward the rear of heli. This will allow the use of stock length pitch change rod. Will have to reverse rudder servo in Tx.
Before I started the swap I placed a reference mark with the stock servo installed and servo wheel centered. This will help in determining how far forward you can move the new servo.
Ensure setup menu D (tail servo frequency) is Red solid (270Hz)
Ensure setup menu C (center pulse length) is Blue solid (1520 us)
Gaui R5 Kosmik 200, Scorpion HK 4235-630
TDR (build in progress)
Raptor G4 720e xnova 4530-525 Kosmik 200
Gaui X5 Jive 100 Scorpion 910, Jeti DS-16
john2kx is offline        Reply With Quote Quick reply to this message
Old 11-20-2012, 05:51 PM   #66 (permalink)
HF MR Support
well replacement tail servo number 2 just bit the dust, so back to the trusty align servo I go... Now I shall go beat myself up and question why I ever put an e-flite tail servo back on my second 300x knowing they are junk. Only good thing is it did it on the ground just before I took off. so no carnage
clouseau is offline        Reply With Quote Quick reply to this message
Old 11-20-2012, 10:31 PM   #67 (permalink)
Default Tail Servo
Mine literally smoked on flight 45. Replaced it with DS35 per threads; flies great!
normarndt is offline        Reply With Quote Quick reply to this message
Old 11-20-2012, 10:39 PM   #68 (permalink)
Sorry, wrong help.. this was a 130x that smokes.
Old 11-20-2012, 11:09 PM   #69 (permalink)
Well... in your case, the ds35 was a good call.....
I bought my 300X used without the ar7200bx. Threw a sk720 on, set it up and flew it. On about the third flight the tail servo let go in the middle of a flip and it augered in hard. Stripped two cyclic servos and the maingear, bent the tail boom and broke the tail box and a blade grip. It's now wearing a set of Savox cyclics and a Hyperion ds11-gcb on the tail. They work like a charm.
MARTY
Team Newb pilot
Trex 500 fbl -Tarot 450 Pro fbl- 300X - 130X X3- mCPX brushless X3-Nano cPX X 2- Nano QX
65L88 is offline        Reply With Quote Quick reply to this message
Old 11-21-2012, 12:25 AM   #70 (permalink)
Replaced mine with a TNG-306-G, awesome servo so far.
petedee is offline        Reply With Quote Quick reply to this message
Old 11-21-2012, 06:44 AM   #71 (permalink)
I've got an align 425 servo laying around from my 250 kit if anybody is interested. $15 and she's yours. I went with a MKS 95i and couldn't be happier, not cheap but worth the coin. PM me if interested in the servo.
THIS IS MY SIGNATURE. THERE ARE MANY LIKE IT BUT THIS ONE IS MINE.
Mojappa is offline        Reply With Quote Quick reply to this message
Old 11-02-2013, 07:20 PM   #72 (permalink)
Default blade 300x servo failures
All four servos on a new blade 300x have failed. No flights. Blade should supply better servos that don't fail upon initial startup.
SCPO-Flyr is offline        Reply With Quote Quick reply to this message
Old 11-02-2013, 08:30 PM   #73 (permalink)
Old thread, but my tail servo failed on the 5th battery pack as did the stock ESC.
I think it would be less expensive in the long run for Blade/Horizon to use better quality parts than to be replacing parts as often as they do.
Just my opinion but a lot of the parts on the 300X are just junk.
Align: Trex 550 Pro DFC, Trex 500 Pro DFC, Trex 450 Pro DFC, Trex 250 Pro DFC, Trex 150 DFC, Blade: CX2, mSR X, 120 SR, Nano QX, 300X. Spektrum: DX6i, DX8, DX9
DWill is offline        Reply With Quote Quick reply to this message
Old 12-13-2013, 05:20 PM   #74 (permalink)
Default 300x tail servo fail
Flew my 300x a few days ago its done about 40 faultless flights and tail started to wag
thought it strange as its usualy rock steady thought it must be a bit of a breeze then it began to yaw thinking it going to spin had to land her but tail was spinning faster so brought her down as gently as i could but tiped over and blades struck the grass while spooling down. Got it back home and servo was dead pluged another on in and was ok so tail servo had died, and started dying while in mid air, the heli looks like brand new and look after it opposed to my others, phoned horizon up and said if i sent servo bk they would replace it but i said i dont know what other damage it may have caused to the heli
tonywv12 is offline        Reply With Quote Quick reply to this message
Old 12-14-2013, 12:34 AM   #75 (permalink)
I'm not saying you cannot get a bad one, but I have run a stock tail servo (and cyclics btw) for +200 flights no problem.
If you go through the ar7200bx setup and make sure your limits are ~1mm less than max (so they will not bind), make sure that everything mechanically is loosey-goosey (including a drop of triflow once in a while), only use only enough tail gain that you need (to the wag is too much imho), and dynamically balance your tail blades to minimise vibs, you will be good imho.
Cheers,
TomC
Blade nQX,mCPX-BL,450x,500x Bell 222(bd3sx),550x(bd3sx)
TT X50E, 10s, bd3sx
Now also a FPV addict; Quads and Planes (soon to try heli's!)
TomC is offline        Reply With Quote Quick reply to this message
Old 12-14-2013, 02:04 AM   #76 (permalink)
I agree with Tom except for his very last statement "you will be good imho"
The servos are not up to the job even with a perfectly setup tail, unless you get lucky like Tom has.
Blade 180CFX | 300X
MSH Mini-Protos 3S, Spirit FBL
Parkmaster 3D, Funjet, Sbach 3D, FrSky Taranis, FPV260 Quad, Pheonix Sim
stevebaker is offline        Reply With Quote Quick reply to this message
Old 12-14-2013, 02:44 AM   #77 (permalink)
And me, I consider my self lucky also. 250 and counting.
terryv83 is offline        Reply With Quote Quick reply to this message
Old 12-14-2013, 04:36 AM   #78 (permalink)
Some times you make your own luck mate!
Cheers,
TomC
TT X50E, 10s, bd3sx
Old 12-17-2013, 09:54 PM   #79 (permalink)
27 flights but it was a quick overhaul.
Mike
__________
XK K110, 150s
DX8 G2, Qx7s
MLFLY is offline        Reply With Quote Quick reply to this message
Old 12-22-2013, 03:42 AM   #80 (permalink)
one week later
Yep, lost my tail servo today, any tips on replacement?
...now consider yourself unlucky
Blade 180CFX | 300X
