Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 02-04-2013, 12:16 PM   #141 (permalink)
I received a replacement bushing from Empire and installed that and have been flying my NX4 religiously every weekend since then. Tail still holding up well. I also got a bushing from Taus and if my stock slider ever fails again, I'll install his. I really believe this was a factory assembly problem and not a design issue with the part itself... at least that's what I'm hoping!
After my last flight yesterday, I was removing the canopy and the patch job I had done to re-enforce the grommet holes crumbled! I guess nitro does some nasty stuff even to the mighty JB Weld!
Rush 700 * Trex 700N x 2 * Trex 600Pro * Goblin 570 * 450L Dominator - V-Bar on all
AMA #934662
caralmar is offline        Reply With Quote Quick reply to this message
Old 02-04-2013, 01:09 PM   #142 (permalink)
We recently received a few of the new pitch sliders from Empire, they are from the new shipment/batch that empire received a couple weeks ago. Hard to see through the package what has been changed, I can confirm they are assembled though.
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN G380/R420/G500-x2/R580/G650/R700/G770 (and many others)* Swinging Rotortech Blades * OMP M1 & M2 * MSH Brain * * iX12*
akamullen is offline        Reply With Quote Quick reply to this message
Old 02-04-2013, 04:42 PM   #143 (permalink)
I also received a new one from empire that is assembled.
joallen001 is offline        Reply With Quote Quick reply to this message
Old 02-07-2013, 12:26 PM   #144 (permalink)
Default Replacements
The new replacements are assembled.
Sorry for the confusion.
Regards
Team Empire
JC Zankl
Heli-Professional/YS Engines/Futaba USA/1st Blades/Scorpion Power Systems/Bavarian Demon/Xpert Servos/AeroPanda/ThunderPower RC
jczankl is offline        Reply With Quote Quick reply to this message
Old 02-07-2013, 12:44 PM   #145 (permalink)
Hey , one replacement whas with my new x4 kit , arived last week , but when i want to change to the new one , the old one is straight off broken , only 1/8 off a turn and snapt off ( heating up with the gun ) ,
the old part is broke inside the tail ,, imposible to take the old one out ,,, i have tryd almost all what is posible , its stuckt in the tail part ...
i need to order one compleet new one from the x5 .bad luck ..
Greats to all menbers , Thanks for all help ..
hepat911 is offline        Reply With Quote Quick reply to this message
Old 02-07-2013, 01:12 PM   #146 (permalink)
I had the same problem. It took me a while to get it out, but I finally got it out by applying a lot of heat and then I used a flathead screwdriver that was narrow at the tip and wider as it got deeper into the threads until it engaged the brass part. I was then able to slowly turn the screwdriver and back out the brass insert.
AMA #934662
Old 02-07-2013, 02:53 PM   #147 (permalink)
I have three kits and didn't get any replacements. How are you guys getting replacements?
Citizen 106
Protos MAX V2 | Forza 700 | Goblin 570/500/380 | Gaui NX4 Nitro and Gasser | T-REX 600E PRO DFC | T-REX 550E V2 | Dominator 450L | Blade 130/180 x/cfx | JR XG14/XG11MV | Icon
GasNerd is offline        Reply With Quote Quick reply to this message
Old 02-08-2013, 10:54 AM   #148 (permalink)
My pitchslider failed in flight last weekend, luckily the only damage was a set of blades and tailgears. The slider was out of stock were i use to shop so i looked around in the old parts box an found a busching from a Raptor 90 slider that looked nearly identical. It took some massive amounts of heat and a knife to get the old one out. The threads on the Raptor busching were longer and the "head" fatter, anyhow it was a perfect fit. Overall it was 1,5mm longer than the Gaui busching, a little less throw but not noticeble.
viktorsx is offline        Reply With Quote Quick reply to this message
Old 02-09-2013, 12:41 PM   #149 (permalink)
JC and empire hooked me up with replacements! Great support from both of them
-GN
Citizen 106
Old 02-16-2013, 08:23 PM   #150 (permalink)
Default My X5 FES slider just broke
Just to add me to the list.
I was landing and the tail just went.
It was a clean break, exactly like everyone elses, at the root of the threads.
I built my X5 from the kit and it has about 30 flights on it.
This was before Christmas and I ordered another one from Helidirect on 11 Dec.
1 x Gaui 208369 CNC Tail Pitch Slider Set (for 5mm tail output shaft) - X5/X5 FES (208369)
I have just had the chance to fit it and test the X5.
All seems OK for now.
Mine came fully assembled in the bag.
I just found this thread (well, Google did) because I usually hang out on the X5 areas.
I have written to JC about a replacement.
Cheers
Tim
Having fun. Slowly learning.
Protos Max v1 (800) - 7HV v2 - X7 - Trex 600 ESP - X5 FES - Logo 480 XXtreme - Protos 500 CF Stretched x 2 - Trex, CopterX & Blade 450s - CopterX 250 - MCPX - Nanos - XK 110. MD500 (Funkey / Align 600).
TimM is offline        Reply With Quote Quick reply to this message
Old 02-17-2013, 12:00 AM   #151 (permalink)
Originally Posted by caralmar View Post
Wow, you got lucky to get it down in one piece!
When I had an X5, my pitch slider also failed. I wasn't able to save it. I installed the Trex600 slider and used the inner hole on the tail shaft and a spacer on the ball to get the geometry right. Never had a problem with it after that. Who knows... there are a ton of X5 owners who never run into this problem...and then there are a few of us that do. About the only thing that makes sense to me is that the brass material is just too thin once you machine in the threads there's almost no meat left.
I really like how Tauseff has solved this problem. His approach does away with the threads and just "pins" it like a rivet. This makes the piece very sturdy and the same thickness all the way through. The downside is that the bearing and the CNC arm are now "married" and if you need a new bearing, you will need to replace the whole thing... but I would rather do that than have another in-flight failure... Just the canopy and blades will set you back $150!
I have been flying using the same part. The regular CNC tail pitch slider i mentioned i ordered. I think it's the G-208369 part. Anyway, My original failed on Flight 132 (6 min flights). I am currently on flight 194. I am thinking about removing the slider nowish to check for any stress on the brass. I don't think i want to try and disassemble. But i think i might be able to see down inside if there is any cracking. I might just replace it now all together for the $16 before it wears and fails again. The slide wear combined with the thread cuts is what i suspect to be the culprit. As well as the obvious possibility of over torquing. But this leads me to a question...
What is the difference between this part for $17:
G-208369
And this quoted "new version" for the NX4, which is $22
313042
If the only difference is that you have to assemble it yourself it's pretty F'ed up that they charge more for it. So i'm really confused and worried i'm going to pay extra for the identical part that has been sold previously for less.
I didn't see an official announcement on a recall yet from Gaui ( http://www.gaui.com.tw/html/news.asp )
Has anybody got a replacement yet via the recall ( that hasn't crashed first ) or heard back on any inquiries regarding it?
-GN
I got in touch with my distributor (clubheli.com) and he directed me to empire or someone else. I never sent them an email, maybe i should? I figure with my post and video showing the issue, maybe they will replace the part? I would hate to have this issue occur again after all the wonderful things i have said about Gaui.
Integrity Handywork is offline        Reply With Quote Quick reply to this message
Old 02-17-2013, 05:30 AM   #152 (permalink)
Broken Nx 4 bushing and Raptor 90 bushing
Old 02-17-2013, 06:59 AM   #153 (permalink)
Default Thanks for those photos - very clear
Very easy to compare those sliders, thanks.
Old 02-18-2013, 09:07 AM   #154 (permalink)
@Integrity Handywork,
JC from Empire/Gaui should be able to help you - he has been very helpful with me and especially with this issue and getting me the replacements.
I feel much better with my NX4 now with the new slider!! Great support from JC/Empire/Gaui!
If you still don't feel comfortable, Luca Invernizzi from Lynx told me that they have a replacement tail slider coming right after the Chinese holiday! I may try that on one of my NX4's at some point as I have been pretty happy with the Lynx stuff that I have experience with.
-GN
Citizen 106
Old 02-18-2013, 07:34 PM   #155 (permalink)
-GN
Well, I sent an email to JC yesterday (Sunday) and the replacement parts are on their way to me already !
VERY fine service for a VERY fine Helicopter (X5 FES BeastX)
So I am VERY happy about it.
Old 02-28-2013, 02:14 PM   #156 (permalink)
Add me to list of Pitch slider failures! Flight 7 on my nx4, started build around black fri.
Took my time and just recently had its maiden, 4 flights,(basic hover) to break in motor.
Took it out couple weeks for quick tuning flight, and another last week. ( weather and time have not been on my side) Finally took out today to start to get the real feel of her. Nothing crazy, just full th. and some piros, pumps, about 3 min into flight, fast bank turn, UH OH!
Tail let loose, managed a safe auto, bent landing skid only, Not sure what at this point, tail was operating properly, maybe my ICON?? Started up again,checking tail slider operating appropriately, gets light on skids,,blow out!. turn off and there she was separated slider. The scary part was i moved rudder and it grabbed and didnt seem to have problem till some force was applied.
About 1/8" of bushing, same MO. Sent Experience RC an email couple weeks ago when I heard they were all being replaced from Empire but they have not yet replied.Now that it's broke, Hope they will respond quick or should I go to Empire directly?
Rick,
Team pilot ,
EGODRIFT, KST, Helidirect, Lynx/Oxy
crickr1 is offline        Reply With Quote Quick reply to this message
Old 02-28-2013, 05:39 PM   #157 (permalink)
WOW Gotta say KUDOS to JC and Empire hobby Cust service.
Just received tracking info on my replacement slider. JC read my post sent me pm w/info for replacement.
Anyone not sure weather to get NX4 or not,,GET IT! Empire has been standing behind there product and support is fantastic!
Rick,
Team pilot ,
Old 03-17-2013, 11:35 AM   #158 (permalink)
Default How to contact?
So call me stupid/ignorant but how do you get in touch with JC/Empire? I had mine shear in two yesterday just hovering. Scared the crap outta me, but was able to safely auto while piroing. Don't ask how haha, but I got it down.
Anyways, how do I contact?
mCP X ||| mCP X BL ||| 130X ||| 250 FBL ||| 250 FBL #2 ||| 450 Sport V2 FBL ||| 450 Pro FBL ||| X5 ||| DX6i
Airman0386 is offline        Reply With Quote Quick reply to this message
Old 04-15-2013, 10:25 PM   #159 (permalink)
HF MR Support
+1 same here! Today mine broke clean in two on 6th flight. I wish I would have seen this thread as a sticky...
I too was able to auto her down from about 40' while still pirouetting and amazingly done no damage. I just had enough momentum that it tipped over slowly on it's side just as the skids slid on the the grass.
Man, I don't know how I done it either, but the slow pirouetting auto was actually so awesome, I couldn't do it again to save my first born... lol
Know I dying to try autos like it on the flight slim.
clouseau is offline        Reply With Quote Quick reply to this message
Old 04-17-2013, 11:29 PM   #160 (permalink)
i feel ya man. I was like, HOLY )(@$ DID YOU GUYS SEE WHAT I JUST DID??!!! while at the same time going cause it just let go.
