Go Back   HeliFreak > R/C Electronics Support > HobbyWing ESC's
HobbyWing ESC's HobbyWing ESC Support
Old 01-23-2015, 12:09 PM   #1 (permalink)
Default mini vbar + hw v3 pro 100a
Hi!
I am going to install a hw v3 in to my logo 400 with scorpion 4017 1070 a mini vbar(with an sbus rxc-->Rx), MKS 9660 and a futaba bls on tile.
The question is:
-i dont know if i need to connect the bec and where
-i dont know how to connect the sensor of rpms on the vbar
in addition the rxc is occupied with the sbus, so cant use it (i think)
thanks
skndol is offline        Reply With Quote Quick reply to this message
Old 01-23-2015, 12:27 PM   #2 (permalink)
Originally Posted by skndol View Post
Hi!
The question is:
thanks
If you don't have a separate tx battery, then you should put Bec wire of HW into RxB to feed your ecectronics (never put it into RxA). I can't advise on the RPM sensor wire, but I have heard that Governor in HW is very good. So, if I were you, I wouldn't put RPM sensor anywhere.
STAZZ is offline        Reply With Quote Quick reply to this message
Old 01-23-2015, 12:51 PM   #3 (permalink)
Thanks for your time
Ok, i understand that i can put the bec in the rxb or rxc
But in the rxb i have the esc and in the rxc the sbus
Which is the option of the tx battery?
Old 01-24-2015, 06:09 AM   #4 (permalink)
Use an Y-wire on one of the servos and connect the BEC this way.
The biggest problem with the mini V is it being one slot short for power.
If you don't like Y cables, don't use the mini V.
Or go Spektrum and use sats, this leaves RX-C for power.
One other option is to plug your throttle cable into your S.Bus receiver.
It works, however you can't use the mini V governor.
I use this setup on my Gaui X5 and run the internal YGE governor.
Pick your poison.
TSH Gaui X5 FES, Spirit, S.Bus, HW100A V3, Formula swash/head
TSH Gaui X3, Spirit, 6S, S.Bus, HW50A V3
Futaba T7C (I admit, also a Spektrum DX8 and some planks.) ;-)
Phoenix R/C v5
helidude71 is offline        Reply With Quote Quick reply to this message
Old 01-24-2015, 06:57 AM   #5 (permalink)
- RX A: RPM Sensor
- RX B: Throttle Cable (will also deliver BEC-Power)
- RX C: SBUS-Cable
The Throttle Cable deliver BEC Power.
The second BEC-Cable from the Controller should be connected to receiver.
Now you have both BEC-Inputs connected to the MiniVbar.
One directly (Throttle Cable) & second through the SBUS-Cable.
overle is offline        Reply With Quote Quick reply to this message
Old 01-24-2015, 07:16 AM   #6 (permalink)
Another option.
Doesn't work for me though.
I have an external BEC (with two output wires) on my X5.
The internal BEC, the red wire, from the YGE ESC is disconnected.
(Not used because it's too weak.)
Phoenix R/C v5
