mCP X Blade Micro CPx Helicopters Information and Help |
06-08-2014, 06:41 PM | #1 (permalink) |
Unexplained pinion and main gear mesh
This is how my mCPX runs. Does not skip teeth as far as I know, main motor screwed in (original Blade motor not knockoff) and original main gear that is not stripped and has no play in any direction.
Yet I have this distance between the pinion and main gear. Frame is solid and not cracked either. Tried adjusting motor but theres no room for adjustments its a very snug fit. What are my options cause I can see how easy it is to strip main gear as it is. Thanks for any advice. |
06-08-2014, 09:06 PM | #2 (permalink) |
I have no play whats So ever its tight as hell and its only 1 day old ,yours looks good
BLACKOUT MINI,ZMR 250,TBS Discovery ,Zephyr 2 TARANIS X9D + ,ez-uhf jr mod GauiX5 Gauix3 |
06-09-2014, 04:37 AM | #3 (permalink) |
Shouldnt they be a tiny bit closer though?
06-09-2014, 09:24 PM | #4 (permalink) |
When its tight it will cause vibs and mtr will burn up faster
06-09-2014, 11:59 PM | #5 (permalink) |
The mesh in your photo looks too loose. Mine is much tighter and has been fine for over two years.
These are not adjustable. A new main gear may have a tighter mesh. If not, a new frame may have better alignment.
MCPx V1, MCPx V2, Eflite Extra 260 and GP Extra 300SP (fixed wing) DX6 Garry |
06-12-2014, 11:33 AM | #6 (permalink) |
Take the motor out and rotate the whole thing 180 degrees and reinstall it. They may have drilled the holes slightly offset when this motor was produced and if so you may get better mesh.
Worth a try.
Team MSH USA - Cyclone Blades MSH Prôtos 380 Brain 2 MSH Prôtos Max V2 Brain |
