Go Back   HeliFreak > R/C Helicopter Support > Audacity
Audacity Audacity Pantera Helicopters Support
Old 02-21-2015, 02:43 PM   #1 (permalink)
Default Hmm I got some vertical play in start shaft AUD0035-2
The heli sharts fine but it has probably 1/8th inch vertical play. i dont see anything in manual that would address such play. I dont think choking down on the hex adapter is the answer, It is still tight on its flat spot.
I dont see any washers or circlips in the manual that I missed
Garland is offline        Reply With Quote Quick reply to this message
Old 02-21-2015, 07:51 PM   #2 (permalink)
As I recall the starter shaft goes in from the clutch end and you use the starter hex nut to hold it all together. I could be mistaken as it's been a while.
Jer
Jerry Moore, AMA #878954,TARANIS OpenTX- Pantera 600 FB - Pantera .60 FB - Takes a licking and keeps on kicking! KISSAM = Keep It Simple Stupid: Affordable, Maintainable -
Visit Early and often - http://open-txu.org
Jermo is offline        Reply With Quote Quick reply to this message
Old 02-22-2015, 08:38 AM   #3 (permalink)
It probably slipped a bit. Getting it snug is tough to do with the motor still installed. If you drop the motor you can hold your thumb on the bottom of the shaft while tightening the hex adapter.
Sent from my SGH-T769 using Tapatalk 2
Matt
Pantera P5 50 RNFBL, Blade 130X, mcpx, Gaui X5 FES
flyingquisinart is offline        Reply With Quote Quick reply to this message
Old 02-22-2015, 10:34 PM   #4 (permalink)
so the hex adapter holds it in the vertical... OK there is lots of play vertically so something did loosen. I'll check it
Old 04-11-2015, 12:20 PM   #5 (permalink)
follow up:
Yes the starter hex was sloppy on its shaft flat spot. It looked like the whole start shaft had vertical play but I reloctite the hex adapter set screw and cinched it to shaft bearing.
All is good now!
