Old 08-14-2011, 09:06 PM   #1 (permalink)
Default Maiden and 3 flights went well...upgrade to pro...not well
I did my maiden flight and then three more flights on my 600se Mini V w/ Express 5.0. All went well, rock solid. I decided to upgrade to 5.1 Pro in order to have a few more options for flight characteristics. Now she has a bad vibe / oscillation. I have tried about every set of values in the gains possible (not every possible combo but you know what I mean). No matter the change it has the same problem.
I have checked and rechecked my build. Everything looks good as far as I can tell. I re-setup the Vbar from scratch, twice. No luck. On my last flight after landing while spooling down she jumped around violently and tipped over. Only damage was one Da-Vinci link.
Any ideas?
Logo 600se
Redlight11 is offline        Reply With Quote Quick reply to this message
Old 08-15-2011, 12:34 AM   #2 (permalink)
if you post your vbar file that could help people rule out or pinpoint if it is a vbar setting causing the problem.
Nikon D4/Sony Fs700/Cinestar 8/8FG super/Dx8
Twister773 is offline        Reply With Quote Quick reply to this message
Old 08-15-2011, 09:20 AM   #3 (permalink)
Have you balanced your mainblades and checked the main and spindle shaft?
Logo 700
Logo 550SX , V-Bar, 3xBLS252, 1xBLS251
ola.c is offline        Reply With Quote Quick reply to this message
Old 08-15-2011, 10:04 AM   #4 (permalink)
I will check the main and spindle when I get home and post my log. She did tip on her last flight but prior to that no hard landings or anything. I don't see how the spindle or shaft could have been bent prior to the tip. My problems began when I upgraded to pro.
EDIT: While I was thinking about it I did change to DSMX sats when I upgraded to Pro. In Express I was using the Hires sats option which binded in DSM2 not DSMX. That is the only thing I can think of that I did differently. Anyone think this could be the issue?
Logo 600se
Old 08-15-2011, 10:56 AM   #5 (permalink)
What headspeed? And blades?
Logo 700
Old 08-15-2011, 11:53 AM   #6 (permalink)
1550, 1650 & 1750 head speed. Edge 693 blades.
Logo 600se
Old 08-15-2011, 12:04 PM   #7 (permalink)
When I upgraded to 5.1 on my logo 400 my disc would bob up and down at low head speeds. It didn't do that with vbar 4.0. Had to up the HS up a little. I know this is no help but I would post in the vbar section. Might have to mess with the cyclic gain.
- Sent from my iPhone using Tapatalk
maarset is offline        Reply With Quote Quick reply to this message
Old 08-15-2011, 12:40 PM   #8 (permalink)
sorrey to jump in here is it complecated to upgrade to pro im running m/v5.0 as well
500espbx 550ebx 600lenbx logo 400se v/b 7c futaba
hooverit is offline        Reply With Quote Quick reply to this message
Old 08-15-2011, 12:43 PM   #9 (permalink)
It was simple.
STEP BY STEP:
[ame]http://www.youtube.com/watch?v=0xVPu8-IFes[/ame]
Logo 600se
Old 08-15-2011, 12:47 PM   #10 (permalink)
Seeing as how it flew fine before 5.1 It's hard to believe it is mechanical. And headspeed shouldn't be a problem. I run mine at 1050, 1500, 1850 with no bobbles. Posting your vbar file should hopefully help pinpoint your problem.
Old 08-15-2011, 12:50 PM   #11 (permalink)
Also as long as your dsmx sats bind in dsm2 and the correct sat option in vbar is checked that shouldn't be a problem.
Old 08-15-2011, 12:51 PM   #12 (permalink)
Thanks for the info bud. I will post it up later today.
Update: After speaking with Readyheli, they beleive the problem may be that I used a Mac for setup. They have heard of some setup issues when using a Mac. I am going to bring it in to work and give it a go on a PC.
Logo 600se
Old 08-15-2011, 12:53 PM   #13 (permalink)
I used a mac with no problems.
Old 08-15-2011, 12:58 PM   #14 (permalink)
Also for what it's worth, I remember someone posting that there was a problem with the newest vbar software 5.1.8 I think it is and using dsmx sat option. Supposed to be fixed in 5.2. Anyways, try binding in 22ms mode in vbar just to rule that out. I could be wrong but I am pretty sure I read that on here.
Old 08-15-2011, 01:07 PM   #15 (permalink)
They said that a lot of people have been successful using a Mac but have had a few calls with similar issues and most, not all, had setup with a Mac.
Logo 600se
Old 08-15-2011, 01:15 PM   #16 (permalink)
At this point I guess it wouldn't hurt to try setup on a PC to rule out whether it is mac related.
Old 08-15-2011, 01:33 PM   #17 (permalink)
Interesting. If you find that thread please post a link.
Logo 600se
Old 08-15-2011, 02:58 PM   #18 (permalink)
Originally Posted by Redlight11 View Post
It was simple.
STEP BY STEP:
do you have to pay for it
Old 08-15-2011, 05:11 PM   #19 (permalink)
Yes. $45 to upgrade from Express to Pro.
Logo 600se
Old 08-15-2011, 05:21 PM   #20 (permalink)
I just sat down to go through the setup again on a PC and noticed the swash is bent!!! The tip over last night must have damaged the swash. Dammit. I guess I will have to wait until I get the new swash to give it another go.
Logo 600se
