Go Back   HeliFreak > R/C Helicopter Support > Hirobo Nitro Helicopters > Hirobo Electric Helicopters
Hirobo Electric Helicopters Hirobo Lepton EX, Quark and other Electric Helicopters
Old 08-28-2006, 02:17 PM   #1 (permalink)
Default 5cell modified Lepton
I have just finished my last Lepton project.
I was not fully satisfied with the agillty of my Lepton.
It was not as sharp and crisp as I wanted.
So I have made a brand new Paddle for it...
The result is perfect. The cyclic speed is double, and the response time is also better. It is a little more wind sensitive, but same precise.
I also made some other modifications:
- Longer tailblades ( Shuttle tailblades trimmed to 65mm )
- Bottom carbon plate ( protect the rear side of the frame )
- ESC holder carbon plate
- New carbon fins ( longer vertical fin )
- 3mm carbon spacer to lift up the tail
- 19T pinion on the Hacker A20-10XL
- New, stronger 94T maingear ( real machined derlin )
- Carbon tailboom brace
- Custom made paddles ( 33*65mm, 5g )
All of the tuning parts designed and made by me. The CNC machinig is my second hobby.
The other config:
- 5cell Polly 3700XP
- Kontronik Jazz 55-10-32
- Medusa 2A/6V BEC ( not the 3,5A version!!!! )
- Multiplex Polo 4 Digi digital sero on cyclic ( really fast and strong )
- Futaba GY410/9650
- Futaba 149DP
Kövi
Kövi is offline        Reply With Quote Quick reply to this message
Old 08-28-2006, 03:32 PM   #2 (permalink)
Hello,
Thanks for the very interestings info. I can see that your Hacker motor has the fan dedicated to it. Is this fan a Hacker option or is it some aftermarket part? I will probably use a Hacker too. My Lepton is on his way to me...
Nicolas
rotodingo is offline        Reply With Quote Quick reply to this message
Old 08-28-2006, 04:53 PM   #3 (permalink)
Team Taco VP
NICE Kövi.....
Love the main gear!
The paddles look like you made them out of a set of blades? What did you do inside to secure them to the flybar?
I also see you have the balls flipped on the seesaw mixer arms to prevernt the links from binding. Did you notice and flight difference? I did not and am running mine like that as well since I dont like that they bind.
Thanks for sharing!
Bob
Old 08-28-2006, 11:46 PM   #4 (permalink)
Hi Nicolas,
Te cooling fan is original Hacker. Unfortunately it is only option part for the A30 series but standard accessory for the A20 series what i used in my custom built Trex.
It is very easy to install just 4 screw...
The temperature of the motor was around 40C after a hard fly.
Kövi
Old 08-29-2006, 12:25 AM   #5 (permalink)
Hi Bob,
Yes the paddles made of a SAB 320 rotorblades.
I made an ally part with threads to hold and fix the paddle. I used epoxy to fix it inside of the rotorbalde. It is fixed to the carbon too and not only the hard foam ( the inside is 24mm long and touch the carbon surface ).
I used CNC router for the blade cutting and a CNC milling center for the drilling so the balancing was unnecessary.
I saw the ball flipping at first on Your machine Bob!
I fipped them also and it works fine without the risk of the bindings.
I also bent the pushrod as you can see. It also prevents the bindings like on my Hirobo Freya EX.
The original maingear is horrible expensive ( same as the EX maingear for my Freya EX ).
So I made a new series. It made of derlin and really machined. It is much more stronger and looks very cool and just 3g heavier.
Kövi
Old 08-29-2006, 12:53 AM   #6 (permalink)
Team Taco VP
Kövi, should you decide to make and sell these main gears, count me in for at least 2
Good work!
Bob
Old 08-29-2006, 05:40 AM   #7 (permalink)
Default Hi
You can put me down for a main gear as well,and if you want to sell any other of your handy work I would also be interested in that. ....Bob G.
Italianbob2169 is offline        Reply With Quote Quick reply to this message
Old 08-29-2006, 05:56 AM   #8 (permalink)
I plan to sell my products, dut I live in Hungary and I can't use Paypal to receive money. ( I just can send ).
Kövi
Old 08-29-2006, 09:21 AM   #9 (permalink)
Kovi put me down for 2 and I will send you a money order or something.
Alvin
eheliflyer is offline        Reply With Quote Quick reply to this message
Old 08-29-2006, 03:52 PM   #10 (permalink)
Maybe pinions is what we first need from him, don't you all think?
Nicolas
Old 08-30-2006, 05:23 AM   #11 (permalink)
Default patrs
Hi Kovi....I can send a Money order as well...let us know...Thanks Bob G
Old 09-01-2006, 06:31 PM   #12 (permalink)
Kovi how about you try to make a new derlin main gear with a .5 pitch so that we
could use the mikado pinions. :cool:
Alvin
Old 09-01-2006, 11:09 PM   #13 (permalink)
Great idea. I could use 3 of them :-)
... Rob
Voyager is offline        Reply With Quote Quick reply to this message
Old 09-02-2006, 12:59 AM   #14 (permalink)
Not so good. .5 pitch is very fragile. A friend is often breaking his Logo 10 main gear at start-up because of that. It's the gear pitch of a T-Rex! I think some other helis use .7, maybe Eco-8 from Ikarus. Or maybe the Robbe spirit too. This could be a better idea since we ask the Lepton to be very powerfull.
Nicolas
Old 09-02-2006, 07:37 AM   #15 (permalink)
Some Logo's use a larger pitch. I had a Logo 14 that was 0.7, that would be the ideal pitch.
http://www.fxaeromodels.com/product_...roducts_id=437
... Rob
Old 09-03-2006, 08:18 PM   #16 (permalink)
Hirobo use 0,6M in the Lepton and 1M in the glow helis.
It works well in extreme conditions also.
Logo 14 use bigger module but the Logo 14 is much more bigger machine.
Off:
I visited the first FAI F3N Championship held in Germany, Munich.
The new Logo 14 was extreme powerful and the flight time was much longer than with Trex600 ( 8min vs 4-5min ). The Mikado team pilots used the "VStabi" digital flybarless rotor system. The Logo 14 was more powerful and more agile than Alan Sabo's Trex 600. The German pilots flies in extreme hardcore 3D style also but Alan was amazing....
Kövi
Old 09-03-2006, 08:27 PM   #17 (permalink)
Kovi when are your derilin main gear going to be available? I need a couple because I stripped the main gear, I had just a little too much back lash and it stripped the main gear.
Alvin
Old 09-04-2006, 04:05 AM   #18 (permalink)
They are ready to shipping.
Kövi
Old 09-04-2006, 10:52 AM   #19 (permalink)
Hi Kovi
How much for two main gear and one 19 tooth pinion and where can i send the money?
Alex
alexsand17 is offline        Reply With Quote Quick reply to this message
Old 09-04-2006, 02:34 PM   #20 (permalink)
Same for me! Kövi (19 or 20T pignion is the most important). Shipping to France in my case. You will soon have to stop you current job :mrgreen:
Nicolas
