Like Tree2Likes
Old 03-18-2014, 11:27 AM   #41 (permalink)
Originally Posted by Seasick78 View Post
It'll come with everything except prog disc and whatever connector type you decide to use for the batteries (EC5, bullets, etc.).
Great! Just had to ask. Thanks, Seasick.
_____________________
JRAY is offline        Reply With Quote Quick reply to this message
Old 03-18-2014, 12:04 PM   #42 (permalink)
Default Kosmik FAQ's
My pleasure.
Team - "Self Interests" -
Flying what I want to, simply because I enjoy it!
Seasick78 is offline        Reply With Quote Quick reply to this message
Old 03-18-2014, 06:23 PM   #43 (permalink)
I'd recommend getting the Bluetooth module. Easier to program the kosmik with it . Just my opinion
Dave
f2000ez is offline        Reply With Quote Quick reply to this message
Old 03-18-2014, 08:35 PM   #44 (permalink)
Dave
Just depends on what settings you want to change (if any). Some parameters are not accessible via BT.
Old 03-19-2014, 01:56 PM   #45 (permalink)
And the Cool is going in my Diabolo S, where space is at a premium anyway. Probably just grab the Progdisk. Thanks!
Old 05-18-2014, 01:18 PM   #46 (permalink)
Ok guys this is probably a stupid question but I'm going to ask anyways. I'm about to build a Goblin 700 Competition and will be using the stock gear and pinion with the Scorpion 4525-520 Ultimate motor. I've read that the Kosmik is happy around 80%. I'd like to have 1900 for normal, 2100 for IU1, and 2200 for IU2. Would this be possible without having to change pinions or gearing? I've only run CC ESC's before where you set your desired headspeeds so I'm new to Kontronik and I just bought the Kosmik from HD. Thanks in advance.
shaun.evans09 is offline        Reply With Quote Quick reply to this message
Old 05-18-2014, 09:40 PM   #47 (permalink)
yes you may have to go a little over 80% to achieve this but depending on the logs that is ok it is always a good idea to check the logs to make sure the esc is happy (hitting spikes to 100% pwm in your highest idle up)
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 05-19-2014, 03:22 PM   #48 (permalink)
Thanks for the input. Does the manual that comes with the Kosmik explain what to be looking for when looking at the logs? Since this is my first Kontronik product I want to be sure I am looking at the right things and staying within the "happy zone."
Old 05-24-2014, 10:50 AM   #49 (permalink)
I bought a used Kosmik 200. Can I send it somewhere to have it upgraded to the "Cool" case? If so, who do I contact and how much would something like this cost (approximately)?
NRPY is offline        Reply With Quote Quick reply to this message
Old 01-01-2015, 05:25 PM   #50 (permalink)
Smile
I have a Kosmik 200.
It has V3.0 software and I would liek to update to either V4.4 or V4.5.
Can I do it with my Progdisc or do I need to send it back to Kontronik to have it done?
Trex family.....100, 450L, 550E 3GX. Goblin 770.Goblin 700 speed machine. Goblin 380.
JR X9503.
PHANTMXR6 is offline        Reply With Quote Quick reply to this message
Old 01-02-2015, 01:55 PM   #51 (permalink)
Yes with ProgDisk, follow the sticky on the procedure.
VControl
Old hand at Planks
Peter
Old 01-02-2015, 05:12 PM   #52 (permalink)
Smile
100% guaranteed?
There are guys in Australia who have tried with V3.0 and it has bricked.
I don't want to be another statistic.
How many guys have upgraded from V3.0 to whatever version without issue.
I do have a Progdisc with the latest firmware as well.
JR X9503.
Old 01-02-2015, 08:42 PM   #53 (permalink)
Originally Posted by PHANTMXR6 View Post
100% guaranteed?
You will only brick it if you interrupt the update process. If the lights are still blinking on the program disc it is still going. Until it says done on the update do not stop it.
Richard Zappe
Old 01-02-2015, 10:12 PM   #54 (permalink)
Smile
Thanks mate. I'll give it a crack.
JR X9503.
Old 01-03-2015, 02:48 AM   #55 (permalink)
Smile
All sorted.
One from V3.0 to V4.4 and the other from V4.0 to V4.4.
Thanks for the step by step process EEngineer.
JR X9503.
Old 02-15-2015, 12:58 PM   #56 (permalink)
Kosmik 160. The SD card is being filled with .DAT files and the Error file but the .DAT files are empty.(0kb) Is this just 'cos it doesn't like the card? It has been formatted with SDFormatter. Also, on a scale of 1 to 10, how likely am I to get a shutdown at 1600 rpm on a 'running in' Urukay? All perameters normal on Telemetry. Thanks
buttles is offline        Reply With Quote Quick reply to this message
Old 02-20-2015, 07:22 PM   #57 (permalink)
I have two Kosmik 160's that I am using the BEC function also. Other than this, I have always used a separate 2S battery for my receivers. The two helis using the Kosmik BEC helis work great and are less hassle than my others with separate batteries.
I am rewiring my receivers as I'm switching from Spektrum to Jeti. I'm leaving my Castle ESC's the way they were with the 2s battery setup as I'm not so confident in the Castle ESC's. I have a Heli Jive on another heli that I want to eliminate the 2S setup and just use the Jive BEC.
What does it mean in the Manual when it states " For safety reasons a four cell NICd/NIMH battery must be connected to the receiver in parallel to the BEC?
Thanks,
Guy
Logo 800 // Logo 700 12S/14S// Logo 690 // Logo 400 // Mostro 700E's// Whiplash 700E// Gaui NX7 // Gaui NX4 // Gaui X4 // Gaui X3 //Goblin 570 // Trex 250 // TBS Discovery /Naza M2 // Jeti DS-16 // V Control // Jlog // BD3SX// VBar Neo// Lifetime AMA
guyguerra is offline        Reply With Quote Quick reply to this message
Old 02-20-2015, 08:53 PM   #58 (permalink)
Thanks,
Guy
a buffer pack is recommended but not required in the case of a failure either main packs coming un-plugged or failing or the bec failing. If you were using a 2s lipo before the helijive bec does not output the same voltage it is a low voltage bec and not meant for use with HV servos.It will work but the servos will draw more amps.
Richard Zappe
Old 02-21-2015, 06:57 PM   #59 (permalink)
I am using Optipower Ultra-gaurds on the two helis that use the ESC's BEC and am feeling that it is a safe setup. Would that be the consensus? As to the one I am rebuilding from a wreck it seems, from your comments, that I am still better off with putting it back together the way it was with the separate 2S battery. I'll do that, I was just getting spoiled with the other two as I don't have to charge and monitor the 2S batts. I appreciate your help again.
Thanks,
Guy
Old 05-31-2015, 10:32 AM   #60 (permalink)
I would not crimp them solder only. you only crimp wires that have lots of strands. the wire guage and small number of strands (2) is VERY bad for crimping.
I was researching a more compact way to connect a Kosmik ESC to a motor, and see that it was addressed here. There was a request for any pictures of this, which would be helpful. I haven't seen any in the thread and am hopeful someone can post one, just as a reference.
Secondly, Avant is showing a kit for this type of tight, vertical wire connection. Outside of the benifit of having the detachable connectors on the Avant kit, are there any opinions about a directly soldered wire haveing the same conductive and structural qualities as these Avant connectors? I can not locate an in stock Avant connector, and do not want to wait until one is available.
If anyone can post a picture it may make the first one go easier for me.
Thanks,
Guy
