Bantam Bantam e-Station Charger Support Forum |
03-25-2008, 06:32 PM | #61 (permalink) |
The 902 is not being discontinued as far as I know. Being without a built in balancer, sales have been low but constant. We are making the 902 a Special Order item at this time. I would be happy to bring them back in for stock if the demand is that.
03-25-2008, 06:34 PM | #62 (permalink) |
150 watts is approx 10 amps. You will not be able to run 2 BC-8's off it charging a 6S pack. You will need maybe about 450-500 watts.
04-11-2008, 07:16 PM | #63 (permalink) | ||
BC6 Recall
Hi
I had previously posted in this thread regarding the bc6 recall to which you offered some information (see below) I have repeatedly contacted the australian distributor (wattsuprc) with no success regarding a replacement of this factory detective charger, apparently they are unable to get any information from bantam. I have also contacted bamtam directly several times and after 4 weeks have received no reply from them. so is there anyone, anywhere in the world that can assist me with this problem ? I have just bought 6 new flight power packs and really don't want to un-balance them with this charger. Quote:
04-12-2008, 04:28 AM | #64 (permalink) | |
04-12-2008, 07:17 PM | #65 (permalink) |
I just got a bc6 but I dont understand how I change the modes aut and man mode when Im charging nicd/nimh, the only field that is blinking is the current Amps feild and I can never come to the aut/man feild so it is in man mode all the time.
am I just a newbie or is something wrong? |
04-12-2008, 08:21 PM | #66 (permalink) | |
04-12-2008, 08:40 PM | #67 (permalink) |
thanks for the quick reply on both of my questions, sorry for posting in two different thrieds though. I have the new version by the way I just saw that there was some kind of problem with the V on one of the version or upgrades, So I got a bit worried about mine being one of the them, but it is not then I guess?
04-12-2008, 09:04 PM | #68 (permalink) | |
04-14-2008, 08:04 PM | #69 (permalink) |
help needed with BC6
I wish to charge 2 Lipo 2150 3s 20c batteries and 2 Lipo 2100 3s 25c batteries. I wish to charge them safely.
Can someone show me the right hook up and the process I need to imput on my BC6. I have a stack of leads but cant understand what I need to plug in and where what I need to enter in the BC6 to charge them. Each time I read the instructions I seem to get more mixed up. If some one can simply run me through the process I will be very greatful. Pez |
04-14-2008, 08:17 PM | #70 (permalink) | |
Select Lipo Balance, 2.1 amps, 3S for the # of cells. Press and hold Start. Confirm R3 and S3, if the same then press start again. |
04-14-2008, 08:26 PM | #71 (permalink) |
What does the balance tap look like and is the eac connecting board those white plastic clips
04-14-2008, 08:33 PM | #72 (permalink) |
The balance tap is the 4 pin connector on your lipo battery. The EAc connection board is the board that sits between the battery balance tap and the 8 pin balance port on the charger. You do need to have the EAC connection board for your battery brand. If you do not have one, contact your Bantam dealer.
04-14-2008, 09:01 PM | #73 (permalink) |
What I have is a Y plug.1 white plug with 8 female input on one end and to 2 5 pin white plugs on the other end. I also have a black and red banana plug with 2 outlets with pluug on the end.
Thanks for assisting |
04-14-2008, 09:06 PM | #74 (permalink) |
I'm not sure what you are explaining, that does not sound like the correct parts. I suggest you contact your dealer.
05-20-2008, 06:26 PM | #75 (permalink) |
e-Station BC6-10 help
im new to LiPo's so need some advice please.
i just got a new BC6-10 this is to power a T-Rex 600CF i have a standard Align 7.4v 1100mah 9c RX battery and a Thunder power RC eXtreme V2 5000mah 22.2v (tp5000-6sxv) main battery 1st where can i get the plug to fit the align 7.4v to the bc6-10 and what is the recommended charging amps? 2nd where can i get the plug to fit a deans connector on the thunder power to the bc6-10 and what is the recommended charging amps for this battery and what Balancing board adaptor will fit it as it has a 4 and 6 plug connector. in the manual it has the MAX but i do not wish to fry the batteries |
05-20-2008, 06:30 PM | #76 (permalink) | |
Deans charge cable: http://www.rcaccessory.com/index.asp...PROD&ProdID=38 Charge at 1C. 1X the capacity, so a 2000 mah pack would be 2 amps. |
05-24-2008, 11:24 AM | #77 (permalink) |
BC6 and Loong Max Charging Setup
I have a BC6 charger and two new Loong Max 2250mAH 3 cell batteries https://www.hobbycity.com/hobbycity/...idProduct=5461. What do I need to connect to the balancing port of the BC6? Any help and charging advice is greatly appreciated.
05-24-2008, 11:30 AM | #78 (permalink) | |
Charge cable such as http://www.rcaccessory.com/index.asp...PROD&ProdID=38 Charge at 1C, 2.2 amps on the Lipo Balance program. |
