Go Back   HeliFreak > R/C Helicopter Support > Electric Helicopters
Electric Helicopters Dedicated to larger than Micro/Mini Electric Helicopters of any Brand
Like Tree1Likes
Old 01-06-2013, 05:15 PM   #121 (permalink)
WOW! I hate to hear that! I was extremely lucky! Blades, new canopy, batteries, all survived. I really was surprised the gear broke. I didn't think it was that bad, but it was far away quick was part of the problem, hard to judge everything.
_____________________
JRAY is online now        Reply With Quote Quick reply to this message
Old 01-06-2013, 05:31 PM   #122 (permalink)
Originally Posted by JRAY View Post
Blades, new canopy, batteries, all survived. I really was surprised the gear broke. .
The gear seems to take the brunt of the impact energy....better that i guess than the rest of the airframe.
6cuda6 is offline        Reply With Quote Quick reply to this message
Old 01-06-2013, 08:36 PM   #123 (permalink)
Yeah, it did. It just didn't look like it hit that hard. I could actually get the frames from Readyheli though.
Old 01-06-2013, 08:40 PM   #124 (permalink)
Yeah, it did. It just didn't look like it hit that hard. No worries, I'll get it back it the air soon.
Old 01-06-2013, 11:06 PM   #125 (permalink)
I do think the SHAPE is a really tough heli I've had 3 hard ones on mine & I have yet to change side frames, blade grips or main gear.
Shape 9.0, Trex 700 DFC pro** MKS Cyclics & Rudder Servos all round. Kontronik Pyro 750 Drives, Kontronik ESCs
Futaba SBus Rx, Futaba 8FG** transmission
seemore74 is offline        Reply With Quote Quick reply to this message
Old 01-07-2013, 07:30 AM   #126 (permalink)
That seems to be the case. I'm going to use this to re-run some wiring and move some things around. I had some wire tension on the connectors with certain batteries in it anyway, which probably contributed to my accident, so I want to change that. I love this heli, so I want to keep it flying for sure.
Old 01-22-2013, 02:31 PM   #127 (permalink)
OK, so I bought out a certain vendors 9.0 parts, so if I can help with anything, please let me know. I'll never use all of this.
Here's what I'll have:
  • SH90-103 Motor Gear 11T
  • SH90-024 Set Screw M3x4
  • SH90-040 Aileron Bellcrank Right
  • SH90-028 Locknut M3
  • SH90-029 Lock Pin 2x16
  • SH90-034 Gyro Carbon Mount
  • SH90-B023 Washer 7x13x0.3
  • SH90-035 Receiver Carbon Mount
  • SH90-T214 Lower Carbon Plate
  • SH90-048 Flange Bearing 7x14x5
  • SH90-058 Thrust Bearing 4x9x4
  • SH90-053 Conical Gear 22T Mod. 1
  • SH90-CANOPYR Fiberglass Shape Canopy Red/Blue
  • SH90-098 Hex Nut M2
  • SH90-092 Crown Gear, PA6 GF 30, 105T, Mod.1
  • SH90-104 Shim LK 25
  • SH90-107 Motor Gear 12T
  • SH90-112 Groove Bearing 4x8x3
  • SH90-116 Socket Head Screw M4x8
  • SH90-119 Bearing Block (Upper)
  • SH90-111 Servo Mount (Lower)
  • SH90-122 Servo Mount
  • SH90-131 Bevel Gear 21T Mod. 1
  • SH90-126 Groove Bearing 12x24x6
  • SH90-129 Aileron Left or Right Bellcrank Shaft
  • SH90-127 Elevator Bellcrank
  • SH90-030 Servo Mount Front
  • SH90-070 Landing Gear Support
  • SH90-100 Aileron Bellcrank Linkage Rod (79mm)
  • SH90-067 Carbon Frame - Left
  • SH90-109 Set Screw M3x3
  • SH90-089 One Way Assembly
  • SH90-075 Socket Head Screw M3x10
  • SH90-012 Socket Head Screw M3x8
  • SH90-017 Socket Head Screw M4x25
  • SH90-023 Washer
  • SH90-008 Locknut M5
  • SH90-063 Flanged Bearing 5x8x2.5
  • SH90-022 Socket Head Screw M3x6
  • SH90-025 Carbon Frame (Right)
  • SH90-105 Screw Plate (Gear Mesh Spacer)
  • SH90-091 Flat Head Screw M3x10
  • SH90-007 Socket Head Screw M5x30
  • SH90-B009 O-Ring 14x2 Shore 90
  • SH90-102 Motor Gear 10T
  • SH90-006 Washer 5x10x1
  • SH90-013 Main Hub
  • SH90-021 Washer
  • SH90-057 Cross Head Screw M3x6
Old 01-26-2013, 03:03 PM   #128 (permalink)
[QUOTE=JRAY;4651860]OK, so I bought out a certain vendors 9.0 parts
DANG! Were you preparing for DOOMS DAY?
Old 01-26-2013, 07:26 PM   #129 (permalink)
[quote=seemore74;4665525]
: well, what can I say, I'm fully vested now! It's really not that much. I could almost.build a spare frame, but not quite.
Old 02-06-2013, 08:43 PM   #130 (permalink)
Well got my new main grip thrust bearings from Boca today. FYI, if you have a 2010 (I believe) or older 9.0, they changed the main grips to the 800 conversion grips, so the thrust bearings and spindle shaft is different. Anyway, the Shape is ready to be airborne again!
Old 02-06-2013, 08:48 PM   #131 (permalink)
Make sure to take some pictures.
Old 02-06-2013, 08:51 PM   #132 (permalink)
Yah what he said.....lol......good show getting the bird back together!
Old 02-19-2013, 03:14 PM   #133 (permalink)
Already posted this pic elsewhere, but here it is newly repaired with it's new friend.....
For whatever reason, I'm not really digging this canopy anymore, so I swapped it for the new one that I acquired. Maybe after my TDR is finished, I'll get my blank painted.
Old 02-19-2013, 10:59 PM   #134 (permalink)
Default Shape 9.0
What's the go with freak ware I asked if its in stock (website showed it was) and they said sorry no stock and no idea when they will get them.
helicraze is offline        Reply With Quote Quick reply to this message
Old 02-20-2013, 04:54 AM   #135 (permalink)
I think Freakware doesnt actually stock the parts...it appears that its "on an order base only". I've been lucky with them and received without delay the parts i've needed.........
What are you looking to purchase?
Old 02-20-2013, 06:13 AM   #136 (permalink)
What Cuda said. Most of my parts didn't show to be in stock, but that had them in another warehouse, and shipped within a day. On a side note, according to what someone @Freakware told me, they are the manufacturer for Shape, not just the distributor. What do you need?
Oh, and better pic.....
Old 02-20-2013, 06:39 PM   #137 (permalink)
I wanted the whole heli!
Old 02-20-2013, 06:52 PM   #138 (permalink)
Wow! They are out?
Old 02-20-2013, 06:57 PM   #139 (permalink)
Geeze....really?!?
Old 02-20-2013, 07:07 PM   #140 (permalink)
I just checked, they show all three color choices in stock, just not the unpainted one.
