MSH Protos MSH Protos Helicopter Support Forum |
07-15-2009, 07:09 AM | #21 (permalink) |
Ill assemble mine in a day or 2.
I think you can adjust the angle of the arm since its fixed by screws. Let me see if I can avoid slider binding. Wesp
www.flyfreak.net - Croatian RC forum |
07-15-2009, 07:29 AM | #22 (permalink) | |
I forgot I also had to shorten the center sleeve for the arm bearings also. It was a tad too long. I did purchase a spare set of C/F tail box parts. Might try them to see if they help correct the issue. |
07-15-2009, 02:32 PM | #23 (permalink) | |||
Would be nice if they made stepped washers like that new boom clamp has now. Quote:
Can you reverse the carbon sides to elevate the shaft a bit? I guess my pitch slider 90° was closer to 90° than yours Its not perfect, my lever bolts touch the sides of the pitch slider so I had to unscrew top one for half a turn. Its as silk now. I guess Ill have to buy the preassembled one too Quote:
I sanded it a bit and it went in. I had some trouble mounting the tail box to the boom. I used a hex driver to open it up a bit. It went easier after that. I tapped it in, couldnt make it by hand. There is no centering guide, like in plastic box, since CNC is made from one part so I eyeballed it with vert. fin on. Its a really tight fit, even without tightening the clamp, so I dont think it would slide to the side like on Trexes. There is zero side to side play in my lever. Pics after test flight 2morrow. Wesp
07-15-2009, 08:40 PM | #24 (permalink) |
Played a little more tonight trying different sliders and arms. The best is still the stock (plastic) arm on the setup. The CNC arm doesnt touch, but still has a little binding in the travel. When I loosened up the arm mounting screw so it had a tad of play, it worked ok with a well worn slider.
I just decided to stick with the plastic one. Works great and I have a few spares. |
07-17-2009, 12:59 PM | #25 (permalink) |
Check this out.....
> We are sending you this email > because we just figured out two potential issues > with our CNC Tail Box > Unit [70320826] for Protos > : > > 1. The > tail guide pulley will > have a little side to side play in the new tail box. > This can be improved with two > washers (one per each side of > guide pulley) with inner diameter equal to the > bush's outer diameter, and > outer diameter equal to the bearing inner ring. We will > include these washers in > the CNC Tail Box Unit and also make a video to > show how to ease the > installation of these washers. > > 2. > We also noticed the screws > to secure the vertical fin will be different from the stock > ones and customers > may not be able to find proper screws for this purpose. So > we will also include > two M2.5 x 6 screws in the new tail box without extra > charge. > > As you > purchased the CNC tail box > upgrade recently in your order > #####, we will send the > screw (M2.5x6) * 2 and special washer * 2 to you today > via registered > airmail. Should you have further questions, please let us > know. > > Have a great > weekend! > > Regards, > Infinity > Hobby Now THAT'S service!!!! |
07-17-2009, 01:47 PM | #26 (permalink) |
Thanks for all the details, updates, and pictures Ecaf. It's truly a pleasure to read
A horse is a sphere if it makes the numbers easier |
07-20-2009, 01:01 PM | #27 (permalink) |
Any flight reports with the Infinity CNC tailbox installed?
07-20-2009, 01:45 PM | #28 (permalink) |
Got a couple of flights on mine.
I never had any static issues and that didnt change with CNC box. I just silicone the belt now and then. As Ecaf reported I also had a little binding when first assembled. I unscrewed lever arm lover bolt and did a few full side to side travels with pitch boss screws all the way in. That seated the whole assembly better. Re-tighten everything with boss at right extreme. I had to unscrew top pitch boss screw for half a turn (and locktite it) to make it silky smooth. New tail box performs well. I had major violent wag on my V-Bared Protos for a couple of flights now and tail box is still in one piece and in same spot so I guess there is no need for centering bolt, it holds really tight. Carbon part is a nice touch and bearings are up to the task. Pulley has a little play but it doesnt effect flying at all, it doesnt move that much with belt under it. Didnt want to crash it on purpose to see how CNC box copes Ant there is a bling factor, makes my Protos buddys jealous Wesp
07-20-2009, 03:10 PM | #29 (permalink) | |
Wespen, can you take a picture of your tail looking down the tail shaft with the hub removed? Id like to see how centered yours looks. Ill do the same tonight on mine. |
07-21-2009, 04:38 PM | #30 (permalink) |
Here are some.
Was flying this days so didnt have time to remove the shaft. hope you can make something out of it. Wesp
07-21-2009, 08:33 PM | #31 (permalink) |
Very classy tail Wesp The finish on those parts looks superb in the photos.
07-22-2009, 06:46 AM | #32 (permalink) |
Here are some pics of mine. As you can see, the bottom of the C on the pitch arm is closer to the pitch slider than the top. This is where it binds with the CNC arm.
Couple of ways I was thinking of modifying it to get better tolerances: 1 - Modify the arm mount by taking some material off the bottom bracket. This would allow me to put in a washer between the top bracket and the arm pivot point thereby moving it down. 2 - Create some new C/F brackets for the tail shaft , moving the tail shaft holes up a few mm. |
07-22-2009, 07:33 AM | #33 (permalink) |
Ok, Ill take off mine today and snap a few.
Wesp
07-22-2009, 08:17 AM | #34 (permalink) |
[QUOTE=Ecaf;1444165]Here are some pics of mine. As you can see, the bottom of the C on the pitch arm is closer to the pitch slider than the top. This is where it binds with the CNC arm. QUOTE]
Very nice Ecaf! The CF tailfin blends nice with those CNC tail components. Imagine a metallic paint scheme on the canopy to match the color of the tailcase .... one expensive looking chopper. The appearance of the finish in the photos reminds me of alloy components on a highend Infinity or BMW. Just dreaming here! Is the binding tolerable in the center portion but only a real issue at the extreme limits of travel? |
07-22-2009, 09:21 AM | #37 (permalink) |
I sent an email asking infinity-hobby support their ideas and if I can get a replacement arm mounting block in case there was an "issue".
Ill post any reply's when I receive them. |
07-22-2009, 09:24 AM | #38 (permalink) |
Ecaf, wait for my pics before you start to dremel away....
ill put them up 2night Wesp
07-22-2009, 05:05 PM | #40 (permalink) |
Ok, here are some closeups.
you are right, would be better if mounting block position is a tad lower. I think its less than a mm. Mine is not as bad as yours, file it a bit and use a shim on top. Should work. Try to flip the carbon ends first, Im not sure they are symmetrical so shaft can end up lower. Wesp
