Old 04-19-2011, 11:11 AM   #1 (permalink)
Default New parts - thrusted tail...
Just got this email from Corrado:
We just put on the site new 450 upgrades, including stretch kit for the Mini (350 blades), low flybarless hub and many other upgrades.
In the Protos upgrades you can find the new thrusted tail rotor.
Nice....
Ecaf is offline        Reply With Quote Quick reply to this message
Old 04-19-2011, 11:25 AM   #2 (permalink)
I wonder if this will bring any benefit from the Alex solution with the shoulder bolts.
I never liked Align's solution, as the grips had too much play. They seem to work fine, though.
With the Alex's mod for the tail, there is ablolutely zero play on the tail grips, and they spin freely.
Nevertheless it's nice to see TH bearings in the tail. I hope it fixes something...
BTW, what are those to small pieces on the right of the picture? Shouldn't they be locknuts?
MSH Prôtos CF FBL Stretch
E-flite HABU 32, Parkzone HABU 2
Ikarus F3A
Multiplex Parkmaster 3D
whisperdancer is offline        Reply With Quote Quick reply to this message
Old 04-19-2011, 01:07 PM   #3 (permalink)
Awesome! I hope these new tail hubs/spindles are better quality.
MSH Protos 500, SAB 630
alexf1852 is offline        Reply With Quote Quick reply to this message
Old 04-19-2011, 01:10 PM   #4 (permalink)
I think those are flat washers. I like that new tail hub though.
Old 04-19-2011, 01:35 PM   #5 (permalink)
You are right. Washers for the hub bolts...
I hope someone gets it and tell the difference.
Ikarus F3A
Old 04-19-2011, 03:33 PM   #6 (permalink)
I'll be getting the tail hub for sure:
http://msheli.com/Item.aspx?IDItem=314
I have 3 tail hubs that the hole is not centered.
Old 04-19-2011, 04:44 PM   #7 (permalink)
Do you think your bearing arrangement fits this hub?
Ikarus F3A
Old 04-19-2011, 10:53 PM   #8 (permalink)
It uses the same radial and thrust bearings. I'm not sure about the shims though. If you buy the tail hub, they come with the shims.
Old 04-20-2011, 04:00 AM   #9 (permalink)
Hello,
Originally Posted by Ecaf View Post
low flybarless hub
Whhhooooooooo, where is this one, :addtocart: :addtocart: :addtocart: :addtocart: :addtocart: :addtocart: :addtocart: :addtocart: :addtocart: :addtocart:
Regards,
Thomas.
Otatiaro is offline        Reply With Quote Quick reply to this message
Old 04-20-2011, 07:11 AM   #10 (permalink)
Originally Posted by Otatiaro View Post
Hello,
Regards,
Thomas.
That one is for the mini-Protos.
Old 04-20-2011, 07:28 AM   #11 (permalink)
Hello,
Yeah, Corrado just told me that by mail ... but it seems the same for the 500 is planned in the near future. Can't wait ...
Regards,
Thomas.
Old 04-20-2011, 07:49 AM   #12 (permalink)
Is there any advantage on a lower head block, besides the look?
Ikarus F3A
Old 04-20-2011, 07:56 AM   #13 (permalink)
Ahem ... besides the look ...
Takes less room in the car, to put more helis ?
It decreases the distance between the rotor disc and the center of gravity, more agility.
Regards,
Thomas.
PS : but the look is the first argument ...
Old 04-20-2011, 06:02 PM   #14 (permalink)
I am very glad to see a thrusted tail option for the Protos
I tried the Infinity Hobby conversion....
I STRONGLY recommend NOT doing that!!!
6 flights, it threw a grip.
The bolt failed in flight.
Took 3 weeks to find the CNC grip
Either convert using a Mikado hub and bearings, or wait a lil longer and get the MSH gear.
If you bling it, they will come!!
gorn is offline        Reply With Quote Quick reply to this message
Old 05-10-2011, 05:29 AM   #15 (permalink)
I have the MSH51330 upgrade in my hands but ... how to assemble it ?
urgno is offline        Reply With Quote Quick reply to this message
Old 05-11-2011, 06:59 AM   #16 (permalink)
... the same here!
Corrado pleaseeeeee!!!!
drader is offline        Reply With Quote Quick reply to this message
Old 05-11-2011, 09:20 PM   #17 (permalink)
Cant wait for the 500 to have them. Gorn that sucks that you had bad experience with the infinity hobby ones. I have the grips but have yet to buy the thrusted bearings.
Avant Aurora FBL, YEP 120/700MX 510kv, Cyclic S9255 CGY750/9254
JR NEX E8, YGE 90/700MX,Cyclic DS610,BeastX/DS650
Trex 450 DFC 3S, YEP 45/450MX,Cyclic DS95i(clones), BeastX/8910a+,
Frenzy 90(UNDER CONSTRUCTION)
ebonicrobot is offline        Reply With Quote Quick reply to this message
Old 05-12-2011, 02:39 AM   #18 (permalink)
Hello,
I shall receive the thrusted tail upgrade in the coming days.
But for how to assemble it, you can check the protos or mini protos manual, it should be the same sequence as for the main blade grips.
From what I see here :
from hub to blade :
- 1 normal bearing
- 1 or 2 large shim
- thrust bearing, larger inside diameter part
- thrust bearing, balls
- thrust bearing, smaller inside diameter part
- 1 small shim
- 1 normal bearing
- 1 thick shim
- screw
this is the standard and best way to assemble 2 normal bearings with a thrust bearing in between.
Regards,
Thomas.
[EDIT] Confirmed by Corrado, the exploded views are coming on MS Heli site.
Old 05-12-2011, 06:37 AM   #19 (permalink)
It looks like the MSH51330 is for the Protos as it is listed for the Protos upgrades. Not the Mini?
Please don't confuse my experience with pessimism!
Protos 500, HCP100S, Raptor 50, many more!
babyuh1 is offline        Reply With Quote Quick reply to this message
Old 05-12-2011, 07:24 AM   #20 (permalink)
I prefer not to guess about the correct order
I'll wait for Corrato
[EDIT]
Corrado just posted this link
http://www.msheli.com/manual/MSH51330_Tech_Data.pdf
